Thanks for the report on this flashlight Dale
I never owned an X6, but this is surely a temptation, specially being even shorter than the original!!
You wouldn’t be you if you didn’t :smiling_imp:
Thanks for this review Dale. I like that they shortened the bezel. I’ll be sure to pick a couple of these up. I still have the x6 triple you built me along side my bed.
Killer review, I meant to pick one of these up from Neal on my last order and forgot…. :cry: Def looks interesting I think I am going to be picking up a few for Christmas presents. Also how does the NW and CW compare to each other? NW about 5000k and CW about 6500k?
Could you do some beam shots when you get a chance? Also with how you talk about the beam being so floody, doesn’t seem like it needed the other lens shown in pictures.
The pictures show my own triple build on a X6 with the Ledil CUTE-3 optic, polished. These have a lot larger individual optics so they have more of a hot spot to the beam profile. Not sure why they didn’t go with something like this, maybe availability of the Ledil components, or price. The Ledil CUTE-3 is taller as well, about as tall as the X6S optic plus o-ring plus glass lens.
Does it take flat top ??
Yes, it does take flat top 18650s.
And/or flat top 18350’s.
Button top works as well, but protected cells may be too long.
Thanks for the review, Dale. I thought this light was a great idea, when I first read about it a while back. But, I realized that I like the original X6 head size better than the more compact head on this light, when looking at them side-by-side in your photos. And floodier optics? :confounded:
Thanks… i ordered one 5 days ago… just need to get some more unprotected Sony VTC5A flat top…
Thanks for the review!
Is the heat sinking the same as a standard X6?
The fins are cut properly, the emitter shelf appears to be a bit thicker and the copper DTP MCPCB is pretty thick as well.
I will disassemble one tomorrow and get pictures and measurements of these dimensions…
Thanks for the review Dale !
I must try one
Great review and what a cool light!
Thanks for the review, Dale. These look very, very nice. They are also a great deal. It wasn’t too long ago that the parts alone cost a lot more than this, and maybe they still do. Decisions are getting tougher, with the FW3A if that happens, the Emisars, this, and others.
Thanks for reviewing, thumbs up!!
Thanks for the pictures and Lumen readings!
Where are your Kronos Flashlights for direct comparison?
Does they use the same threads as the Kronos?
Is there a clip included? there is much space for a clip.
They do come with a clip and lanyard, and a couple of extra o-rings and two extra rubber boots, a clear one and a sort of pinkish one.
Will the Kronos lights be a direct comparison? Aren’t they made by Manker? Interesting question, need to look at that…
Looking good Dale, and I see a lot of inspiration/homage
A better driver/firmware could transform them.
I like the rounded lines of the original (I have four), and the screwed-in pill, and reflector screwed into the pill. Of course with a TIR that’s not necessary.
The anodising… was not terribly good.
Actually I just like these, rather than the dreary industrial tubes, bigger tubes with fins on the head, huge tubes with even huger heads, the “how big can I make a reflector and put a SOA emitter behind it” game, etc.
When/where can we get them ?
I hope the head packs a bit of mass to handle the heat better. This makes my custom X6 triple have a decent runtime.
