CRX Rotary - 6th Annual BLF/ Old Lumens Contest Winner
149 posts / 0 new
CRX
CRX's picture
Last seen: 4 months 4 weeks ago
Well I suppose I should make a start on this years, The 2018 Annual BLF/ Old Lumens Scratch Made Light Contest entry.
I am feeling the pain already from all the filing & sanding to be done, though I like it really... Wink
This is a competition where BLF members take part by making a flashlight or light emitting device from scratch using materials and a design of their own choice.
The yearly contest was started in 2013 by popular member though now deceased (2016) Old Lumens who loved using his hands making & modifying flashlights and is now run by BLF member _the_.
There are two categories, Machine made and Hand made.
Again I will be entering the hand made category using only small hand held tools to make a more traditional looking light this time, but with a twist...
Tools & materials I will be using for the build:
I have a rough idea of what I want to make but I am just working as it comes to me with no drawn out design plans
CRX Rotary - Complete.CRX Rotary - XPL-HD 3D - RSD - 18350 - Rotary Lighted Tail Sw - 1560lm.Specifications:
Copper & Titanium construction
Cree XP-L HD v6 3D emitter
GITD O-ring & LED surround
20mm Copper DTP MCPCB
19mm x 8mm solid copper heatsink
20mm x 12mm SMO Reflector
22mm x 2mm dual coated ARC glass
Lighted Rotary six mode tail switch & Momentary button
Dual colour Tritium indicators
Lockout-able
Diffuser/ protective carry case
Magnetic cell contacts
18350 cell compatible
Removable USB charging unit
Length – 94mm
Width – 25mm
Weight – 180g (With 18350 cell)
Parts Made - 80 (Approx)
Time to build - 101 hours
Modes, Operation & Light output:
Pressing the momentary button or turning the rotary tail switch clockwise gives these approximate outputs:
Mo Switch - 1560 lm
Mode - 1 - 1500 lm
Mode - 2 - 450 lm
Mode - 3 - 180 lm
Mode - 4 - 45 lm
Mode - 5 - 3 lm
Mode - 6 - FF lm
Max cd - 9000
Max Throw - 190m
The rotary tail switch can be operated through 360° in either direction starting in the highest or lowest mode.
The use of a lubricated o-ring underneath gives just enough friction for smooth operation.
The tail push button gives momentary access to the highest mode.
The tritium markers give an indication as to switch position/ charging mode.
When the two green tritium vials are lined up on the outer shell   , the light is in the off position.
When the green indicator on the rotary tail section is turned to line up with the red indicator in the body section   , the light is in direct drive mode, or in charging mode if the head section is then disconnected and the USB charger port is exposed.
Other than that the tritium indicators let me know where the switch is positioned.
Operational GIF
CRX Brass Art, CRX Stratis Lumina, CRX Rotary2016, 2017,& 2018 competition winners.
Upgrade Edit: 31:08:2019CRX Rotary - XP-L-HI v2 3A 5000K - RSD7 - 18350 - Lighted Rotary Tail Switch Momentary Button - 1300lm
I modified the CRX Rotary with a 3K carbon fibre jacket, swapped the XP-L HD 3D emitter for an XP-L HI 3A 5000K, re-made a new momentary tail switch cover, dual o-rings and added a seventh moonlight mode.
Carbon fibre, titanium & copper construction
Cree XP-L HI v2 3A 5000K emitter
20mm x 12mm SMO reflector
Lighted seven mode rotary tail switch & momentary button
Dual colour tritium indicators
Lockout-able
Length – 94mm
Width – 27mm
Weight – 192g (with 18350 cell)
New Modes, Operation & Light output:
Momentary Switch - 1300lm
Mode 1 - 0Ω - 1269lm
Mode 2 - 1Ω - 380lm
Mode 3 - 3.3Ω - 162lm
Mode 4 - 15Ω - 44lm
Mode 5 - 180Ω - 15lm
Mode 6 - 820Ω - 4lm
Mode 7 - 1200Ω - ML
Max cd 15000 - 245m
CRX Rotary revised runtime graph in modes 1 & 2.CRX Rotary Runtime Graph
CRX carbon fibre, titanium & copper triumvirate flashlight set.CRX Copper & Carbon Fibre Triumvirate (Eidolon)
Building the CRX Rotary flashlight. (Start - 01:11:2018)
The text & images below provide direct links to the various detailed build stages.
Preparing the outer & inner core copper tubes to fit together.
Making the copper pill.
Copper pill fitment inside core tubes.
Making the mechanical rotary tail switch.
Redesigned rotary switch contact board.
First test of rotary switch unit.
Magnetic pill contact board & wiring.
Interlocking copper core sections made.
Magnetic copper charging unit.
Core body midsections soldered together & lighted rotary tailswitch installed.
Titanium & copper tail switch cover made.
Temporary brass casing made.
Titanium casing started.
Contact points marked out & Titanium casing finished.
CRX Rotary Assembled & Tested.
Diffuser/ protective carry case made.
Edited by: CRX on 09/04/2019 - 01:52
raccoon city
raccoon city's picture
Last seen: 3 hours 6 min ago
I'm looking forward to this...
I hope your hand heals soon.  :BEER:
MascaratumB
MascaratumB's picture
Last seen: 5 min 52 sec ago
It’s all about the blood, the sweat, the copper Wink
Looking forward to your build, and wish your hands recovery!! Thumbs Up
pinkpanda3310
pinkpanda3310's picture
Last seen: 4 days 7 hours ago
Ouch Shocked Maybe it’s good thing you don’t have machinery Oops
FmC
FmC's picture
Last seen: 6 months 4 weeks ago
“It’s just a flesh wound”…. Big Smile
Looking forward to the build Beer
thijsco19
Last seen: 2 days 4 hours ago
FmC wrote:
It’s just a flesh wound….
Damn! The competition is hard this year Big Smile
Good luck CRX, not that you need any.. Beer
gchart
gchart's picture
Last seen: 1 min 59 sec ago
Ouch! Good luck, not that you need it. I’m looking forward to watching this come to fruition (despite knowing that it’ll put me another rung lower on the ladder Ughh )
Lux-Perpetua
Lux-Perpetua's picture
Last seen: 7 hours 48 min ago
Wish you a speedy recovery CRX!
In case of more severe wounds there's some good advice from Mr. John Rambo Wink
MtnDon
MtnDon's picture
Last seen: 1 hour 22 min ago
Thumbs Up Good to see you start. Reducing metal diameter with sandpaper sure is tedious. Beer
Flashy Mike
Flashy Mike's picture
Last seen: 3 days 13 hours ago
Hi CRX, I’m very curious about your next beauty.
Slayer1
Slayer1's picture
Last seen: 1 day 5 hours ago
Ouch, hope it doesn’t hurt as much as it looks.
Looking forward to seeing the awesome build.
DavidEF
DavidEF's picture
Last seen: 3 hours 44 min ago
I’m looking forward to this too. Your creations never disappoint! Crown Thumbs Up
- The YKK Philosophy
Agro
Agro's picture
Last seen: 4 weeks 1 day ago
Looks interesting, nice to see you enter. Smile
MtnDon
MtnDon's picture
It appears we have the exact same caliper.
CRX
CRX's picture
I started off with two hours of fun, freehand filing some copper tube to reduce the diameter of the smaller tube as I want them friction fitted together.
The larger 21.96mm OD x 20.40mm ID copper tube is a cutting of plumbers pipe.
The smaller 21.22mm OD x 18.98mm ID tube, a comrade sent to me last year.
This tube needs to be reduced in diameter to fit inside the other.
Tube measurements prior to work:
Outer tube - Outer Diameter - 21.96mm
Outer tube - Inner Diameter - 20.40mm
Inner tube - Outer Diameter - 21.22mm
I filed evenly around the inner core tube using a hand file to reduce the diameter by about 0.84mm.
Pro Tip: Do not use left hand as filing guide Wink   Inner tube filed down, sanded, light polish and a comparison to an unworked tube.
Tube measurements after work:
Inner tube - Outer Diameter - 20.38mm
Inner tube - Inner Diameter - 18.98mmNow we have two copper tubes fitting nicely together.
Lightbringer
Lightbringer's picture
Last seen: 5 hours 28 min ago
Lux-Perpetua wrote:
In case of more severe wounds there’s some good advice from Mr. John Rambo Wink
NC would still burn even after being soaked with blood?? Naaah.
Worst I ever did was sear off all the hairs on my forearm when I let a flame get a little too close to an “empty” bottle of IPA. Heard a nice slow “fwoooosh!” and… no more armhairs!
Ever since, I could never recreate my (unintentionally) improvised jet-engine.
MRsDNF
MRsDNF's picture
Last seen: 1 month 1 week ago
That file was a real Bastard. Silly
everydaysurvivalgear
everydaysurvivalgear's picture
Last seen: 4 hours 26 min ago
Looks good! No doubt the finish product will be top quality.
CRX
CRX's picture
True LOL
Before people mark you rude for sweary… File Types.
Jerommel
Jerommel's picture
Last seen: 1 year 4 months ago
^ fun read. Barstead?
In NL we have “bastard sugar” (basterd suiker) which is a mix of fine and coarse grains of sugar.
The brown variant is most popular, it has some syrup / molasses mixed into it.
I recently had a mysterious bastard file on my SD card…
Very strange. 0 KB size mp3 file, and i had ‘no permission’ to delete it either..
So i deleted the folder it was in.
But that only worked after re inserting the SD card and not opening that folder first !!
Very odd.. I suspect it was attached to some GIF i downloaded. Not sure. Weird..
Anyway, looking forward to more pics and progress of your build, CRX. Beer
CRX
CRX's picture
Filed down a scrap piece of 20mm copper bar and brass ring to 18.92mm.
Parts soldered together.
Soldered the parts together with some copper sheet insert and copper wire using a dual flame jet lighter with the parts placed on a ceramic tile with solder paste in the joints.Cleaned up with wire woolsandpaper then metal polish.
First a scrub all round with coarse wire wool then a rub on some 800 grit sandpaper, keeping the face flat down to finally a polish on some old newspaper with a dab of liquid polish on it.
Cleaned up.Showing the pill inside the inner core tube.
This will eventually be cut to shape and fixed in place. Showing preliminary core flashlight parts.
This is an old reflector used for checking fitment only.Pill inside inner core inside outer core with MCPCB & reflector in rough positions.
Jerommel
Jerommel's picture
C.R.X.
Copper Rubbing X-cellence. Smile
pinkpanda3310
Jerommel wrote:
C.R.X.
Cool Thumbs Up
gchart
gchart's picture
MtnDon
MtnDon's picture
I like how you simulated wood grain in the copper surface. Facepalm
DavidEF
DavidEF's picture
CRX is over-the-top with his sanding and polishing. I’m not that patient. Tired
MRsDNF
MRsDNF's picture
I’m sure this will be amazing as per usual for CRX. Smile
Where do you get your copper from?
CRX
CRX's picture
It’s really only a quick three stages I do for shining the metal after filing – sandpaper, wire wool
then liquid polish on newspaper.
I’m not too fond of polishing, I’m more of a filing hacking & sawing kinda guy yi know Big Smile
The larger copper tube is standard 22mm plumbers pipe, the smaller stuff was sent to me by kiriba-ru a while ago. Same stuff I made this with.
MRsDNF
MRsDNF's picture
I was just wondering if your metal supplier new what you did. Smile
CRX
CRX's picture
Well the plumbers don’t as they probably wonder where their scrap pieces disappear to… unless they have a suspicion the spark on the job has a copper cutting fettish or something Big Smile
CRX
CRX's picture
Copper washer.
Using a scrap piece of 0.3mm copper sheet I drilled a 4mm hole and filed the outer edge into rough shape with the file before switching to the finer stone then a quick polish.
Sprung brass switch contacts & enclosure supports.
I used an old brass Zippo flint stopper to make a switch contact.
Filed the brass rod down a little, sanded and soldered to a silver coated spring from an old clicky switch.
Cut two contact enclosures from 3mm x 0.5mm brass tube and filed down to 5mm length then neatened up with the fine stone & sandpaper.
Two sprung pieces, only one is for making the circuit, the other is made to balance the switch disc, is non conductive and also showing a 5mm x 4mm brass tube to be filed down to 3.8mm length for the central pillar support.
Some switch pieces.
Rotary switch contact boards.
Using the FR4 copper board again, I drilled, cut & filed an 18.92mm diameter disc with a 4mm centre hole.
Using the first as a template I sanded down the second using an M4 brass bolt & nut holding them together.
Now we have two equal contact discs Thumbs Up
I marked six points on one as well as I could freehand.
Further marked, kapton tape applied to both sides then I cut out the tape roughly where marked with a scalpel blade.
I used ferric chloride to dissolve away the copper that was not covered with the tape, this takes a few minutes.
Pieces removed from the acid bath, cleaned and tape removed from boards to leave copper contact points hopefully where I want them.
A little more tidying up and ready for test assembly. It is not OSH Park quality but it is all hand made Smile Order of how the parts go together. The brass contact enclosures will be soldered in place to the disc later.The steel washer is temporary to hold the contacts in place and will not be used when everything is soldered.
