Thank you very much. And what is the scheme for setting the desired temperature? (if you need to change the temperature) One click is how many degrees?
Thank. Please specify.
These items (5.6) are required to perform or make “Click 10 times” (3) and perform “During the“ buzz ”, click 15-20 times.
“hence, click now to 30 (hence, click 15 times to get 45, or 20 times to get 50)”?
Thanks for the answer.
So you need to do it. Calibration
_2.Turn the light off.
3. Click 10 times.
4. The light should blink once, then flicker or “buzz”.
5.During the “buzz”, click 22 times to tell it the room is 22 C.
_
P.S. Please tell me where you can read about Runtime: in different modes - Turbo and other
[quote=ToyKeeper
Afterward, it should attempt to keep itself below 45-50 degrees C.[/quote]
ToyKeeper, DB Custom, nick779 !!!. Friends, thank you very much for your help. Now completed all the recommendations. How to check the temperature set by me?
This will greatly vary based on a number of parameters such as your ambient temps, specific battery being used, and emitters that you have, but some rough figures were provided by TK in the original post.
valera, we sometimes get caught up in the numbers as if it were an exact science. It’s really not. These parameters get us close and that’s about as good as it gets. You can measure the amperage your light is making at different levels and then use this information to estimate run time based on the capacity of the cells you are using, but again this an approximation and not an exact science as the diminishing cells will yield lower and lower current and the run time will gradually extend accordingly.
The D1 uses RampingIOS v2 which is a custom firmware.
On the other hand, the D4S uses RampingIOS v3 which is just Andúril with some minor changes requested by Hank.
If you compare the code or the manuals, you will see, that currently there is no way to get the current set max. temperature.
You can of course, update RampingIOS v3 or Anduril to do that. But you lose your current setting when flashing.
In RampingIOS V2, the limit was set by letting the light get hot. It could also display the value, to help the user see if they got the specific value they wanted. In practice, this would often take a few tries, and people had to guess until they got close enough.
In RampingIOS V3, the user can set the value directly, instead of using the sloppy “release when hot” method. So there is less need to display the value.
Well, just finished an infuriating flash session with my D4S.
It absolutely REFUSED to flash with the 219c attached. Desoldered them as I was switching to XPL-HIs and it immediately flashed with 0 errors. Not sure if I got lucky the first time, but I repeatedly got transmit errors around the 1% and 60% mark. Im thinking its more hardware related as in with my laptop, and the low vF emitters or something. Really weird.
Could the 219C have been reflowed in an incorrect orientation? A short there would have prevented the flash. Low Vf wouldn’t have done it, at least I’ve never had that be an issue in all the multitudes of one’s I’ve flashed…
