Copper S2+ limited edition
598 posts / 0 new
Andrew_Debbie
Last seen: 1 week 6 days ago
Just ordered one with XML2 T6-4C. 7135*8 Biscotti. OP Reflector
I will probably change the driver and maybe the emitter. I thought about ordering a host instead but wanted a light that worked out of the box.
Late to the party… Again.
Lightbringer
Lightbringer's picture
Last seen: 3 hours 50 min ago
The 4C with the reflector is kinda meh, but throw in a 20mm TIR lens to blend the beam, and you’ll absolutely love it.
Andrew_Debbie
29 days later my Copper S2+ is here. Love at first sight Smile
The package was opened along the way, perhaps by UK customs?
The light arrived in perfect condition and in the configuration I requested. As expected it is a second edition.
Biscotti should tide me over until I get an A6 driver. I wonder if my 42W Weller is going to have trouble melting the solder on the retaining ring. It is ok with an aluminium S2.
Lightbringer wrote:
Throw in a 20mm TIR lens to blend the beam, and you’ll absolutely love it.
Any suggestions? Carclo part number??
adam7027
Last seen: 5 days 19 hours ago
If single LED… (no Carclo suggestions for now, but Yajiamei works good)
… if you want a buttery smooth creamy beam, go with these (probably 15 deg is very good; 30, 38, 45 are definitely floody; 85 is extremely floody with almost no hotspot):
https://www.aliexpress.com/item/Free-shipping-High-quality-cree-XP-E-len...LED-lens-Diameter-20mm-Frosted-surface/772881051.html
… if you want less spill, and more defined hotspot (but not with the ‘artifacts’, which are present with ‘clear’ optics), go with these:
https://www.aliexpress.com/store/product/Free-shipping-plastic-cree-lens...LED-lens-XP/219000_772880537.html
Also, everybody should check, that whether the front lens diameter is at least 20.5mm. Recent S2+ hosts I received, had something like 20.0mm diameter, and with that, the lens gets partially slipped past the green GITD silicone ring, which then results in tilted optics when I fasten the pill.
SKV89
Last seen: 8 hours 32 min ago
The new batch of copper S2+ looks different from the previous but I think I like it a bit more. It weighs 170.0g without batteries. I leaving it running on max output measured around 710 lumens to see if it can sustain it indefinitely. At about 10 minutes (didn’t time it) I touched it and it is almost too hot to touch. I guess despite it has the mass, there’s not enough surface area to radiate off the accumulated heat. The lighter aluminum version would heat up much quicker though. I wish there’s a copper light with a lot of heat fins.
This is a 7A tint, which is a very nice warm white matching the copper. No ugly yellow or green in the tint.
Andrew_Debbie
The one in my copper S2+ is about 0.802” or 20.36mm. No issues with fit. Unlike my aluminium hosts, the retaining ring was not soldered to the head. phew!
The glass is square with the callipers. Perspective makes it appear otherwise.
hcanning
Last seen: 2 months 4 weeks ago
Which is the nicest warm XPL HI tint to go for with this?
Also am I right in assuming the 7135*8 driver is the most powerful?
Thanks!
Notable lights: Q8 with 4 x 3V XHP50.2, bypassed springs, brass driver and tailcap screws, Anduril firmware, removed anodisation, AR glass, warm white switch LEDs (16,800lm)  |  Convoy S2+ with triple Luxeon V 4000k, Led4Power B4 Driver, Carclo 10507, bypassed springs (2900lm)  |   D18 in sand  |  D4V2 in sand  |  D4S in grey  |   FW3A with warm white XP-L HI  |   KR4 Mule in blue
DB Custom
DB Custom's picture
Last seen: 17 hours 35 min ago
Have a purple S2+ host due in on Thursday, also still have a Hoop copper triple sink/pill AND have an LED4POWER 12A constant current driver, figuring to use Samsung LH351D 80 CRI 5000K emitters for a triple in this one, should be pretty nice, not 100% sure that the LED4POWER driver is the best choice on a triple though, haven’t used many of these drivers and remember that there could be some heat issues? Not sure…
led4power
led4power's picture
Last seen: 16 hours 52 min ago
Not with this S2+ kit: https://led4power.com/product/ld-a4-thermal-enhancement-kit-convoy-s2/
But,this is for stock pill, for custom pill you could do the same sandwich 0.5mm TIM + Cu/Al + 0.5mm TIM.
Andrew_Debbie
Thanks!
7A is the warm tint. This low CRI tint has an odd-yellow feel to it. It might complement the copper body. Not sure. I like 7A in my desert sand S2. The super warm tints are not as bright as the others.
I have XML2 T6-4C in my copper S2+. This neutral white is ok. It isn’t bad but it isn’t good either. I’m leaning towards changing the emitter or swap in an optic. (See above) I’m still deciding what to do.
7135*8 is the most powerful driver you can get from Convoy. It is 2.8Amps on high. If you want more current, the BLF A6 7135+FET driver will work. Lots of threads with information about this driver swap.
Barkuti
Barkuti's picture
Last seen: 3 days 17 hours ago
… 7135*8 is the most powerful driver you can get from Convoy. It is 2.8Amps on high. If you want more current, the BLF A6 7135+FET driver will work. Lots of threads with information about this driver swap.
There are other driver options, like the last one reviewed by Henrik per request of me which is LD-25 new version. Available at the Convoy store and at FastTech. Fully linear (PWM free) in all modes and current adjustable, which in my opinion is a lot better than any 7135 @#$%:
Cheers Party
Please avoid fully quoting lenghty posts, namely with nested quotes. Trim quotes down to the essential. Helps with neatness and legibility. Thanks.
The human mind, and its programming, is at the forefront of a particular battle of The Light vs evil dark forces. Nearly every human being on this beautiful planet “Earth” has some sort of negative mind programming in its mind. And you better take care of your mind programming, or someone else will in this wicked world.
Viruses DON'T cause diseases, they rather are a consequence of them. Read the book “Béchamp or Pasteur” by Ethel Hume for more information.
Andrew_Debbie
Interesting. Looks like a good match for one of the high CRI emitters.
I’ve been thinking about a 3-channel driver with PWM only on moonlight. Maybe the LD-25 is better.
hcanning
I’ve ordered one with an XPL Hi 4A, 7135*8 and orange peel reflector. I love my grey S2+, so I can’t wait to get this Big Smile
Nooner
Last seen: 10 hours 46 min ago
Just received my copper S2+ yesterday.
It is from the 2nd production run.
I’ve not seen many images of it online.
Thought I’d share some pics for anyone interested.
It’s pretty!
Colour is a little more red (coppery Big Smile ) in real life.
I like it!
hcanning
Damn that looks nice. Can’t wait to get mine.
justanotherguy
Last seen: 9 hours 9 min ago
its a very nice Cu light.. I EDC them at work.. They are taking hits now but they still look sweet
Diodek.pl
Diodek.pl's picture
Last seen: 11 months 2 days ago
Hi. I have literally a few photos of myself, but without madness – https://diodek.pl/miedziany-convoy-s2-copper-s2-prawdziwa-waga-ciezka/.
If someone wants, I can do it on request, just let me know Smile
PS. This flashlight host is great!
www.diodek.pl Convoy, Astrolux etc. flashlights test and more. My YouTube channel.
d_t_a
Last seen: 1 day 6 hours ago
Not sure if this has been asked or answered already. How’s the weight of the S2+ copper? and compared to the S2+ aluminum versions?
Does it feel heavy to hold (eg. like carrying a bigger flashlight)?
justanotherguy
It’s in here somewhere..I think mine was 170-180 grams
Macka17
Last seen: 11 months 1 week ago
Anybody thought of turning up a C8+ ‘Copper” or Brass torch.
That would be worth having.
The 1in waterpipe torch I find soo ho-hum.
C8+ Brass/copper, with triple head. 26650 cell. side switch and no rear sw.
Really would be a torch worth showing around.
I have a Grey S2 and a Silver S2+ both new. I just bought, battery fitted to test . Then sitting in Bedroom cupboard.
Never used or taken outside. Offers if interested But I’m in Australia.
Freight would kill to most I think.
That’s why I dumped 18 in garbage last month. We live Rural.
$5 to $18 initial cost per.
At second hand price plus AUST, freight. Nobody interested.
My torches are either mid range keepers. or disposables at delivery.
with 3 or 4 surprises.
charles lin
charles lin's picture
Last seen: 5 days 7 hours ago
Weight with battery:
Convoy s2+ copper – 221g
Compare to other lights:
Convoy S2+ – 126g
Astrolux S41 – 157g
emisar D4Ti – 172g
Lumintop prince copper – 168g
d_t_a
Thanks, Charles Lin for those info!
Dobtruckers
Guess I was asleep and missed this one. Anyone know who might have bought these Copper S2+ lights for resale? Or if there are any plans for a third run?
Thanks,
Dennis
eas
eas's picture
Last seen: 2 years 3 days ago
Dobtruckers
eas wrote:
Huh? Convoy’s AliExpress shop says there are 42 pieces available.
I just got an e-mail from Simon after I asked when more would me made and he said that he found some more stock of S2+ lights….and that I could place an order ….which I just did …. 41 left?
Andrew_Debbie
The weight is something you notice right away and is part of what makes it feel higher quality than an Al S2+.
I’d think twice about adding one to a backpack. I’d rather carry an extra battery. Debbie really likes mine but said she wouldn’t want to carry it in her purse. I ordered her a purple S2+ instead.
Steeldog
Last seen: 2 years 1 month ago
I’m interested in this. Can someone recommend which emitter is good for throw in neutral or warm tint with the smooth reflector? What are the differences between the drivers?
RobertB
RobertB's picture
Last seen: 3 days 2 hours ago
Thats what I thought when I saw this. Yesterday it said “Sold Out”
Lightbringer
As far as S2+es, I way prefer TIR lenses in ‘em vs reflectors.
With reflectors, you’ll get a fried-egg beam (yellow hotspot, blue-white spill), whereas most TIRs will blend the colors for a way nicer beam.
5° and 8° TIRs are available, and they’re easily interchangeable in case you want to swap in a 60° for more flood, etc.
Lightbringer
Anyway, the stock 4C is a nice temp/tint, just-warm-of-neutral sunlight through a TIR.
Else, go crazy with a 219, 351, etc., in whatever ct/tint you want.
