Comparing the Emisar D4S and the BLF Q8 in Alaska:
Let me apologize for two things before I start:
- Someone might have already posted a comparison of these two lights in this thread. I have not had the time to go through the previous 44 pages.
- I don’t have photos to show what I will try to describe.
Here in Alaska the nights are getting very long and cold, making this a great time to get outside and try out my new Emisar D4S in vast dark wilderness beyond the edge of town.
The few nights ago I had taken out my D4S (XP-L HI V2 3A @5000K), comparing it with my other Emisar lights: the D4, D1 and D1S. My takeaway from those trials is that I can put away my D4 and D1 as the D4S has the brightness of the D4 and throw of the D1. The D1S throws a longer distance. I’ll keep that one around.
But it occurred to me the D4S seemed similar to the BLF Q8 in terms of light output (lumens, flood and throw). How similar?
Last night I took my D4S and BLF Q8 (XP-L HD V6 3D @4750K) to my favorite remote testing spot, the base of a shear rock cliff that is about 300 meters long and 100 meters tall. I stood at one end of the base of this cliff, comparing throw, flood, brightness and tint knowing I would not be disturbing any humans, the nearest living miles away. (I once bothered a curious moose and another time a massive Great Horned owl. Sorry fellas.)
The beams of the two lights are indeed very similar. Both provide a useful combination of a broad hot spot giving plenty of throw plus abundant spill/flood. In fact, that much flooding light (at turbo levels) reflecting on white crystalline snow can be too dazzling. Both lights throw a beam the full 300m length of the cliff with almost the same apparent brilliance. The Q8 is a teeny-tiny bit brighter than the D4S but it’s just about a tie. Batteries: Q8: 4-18650 Sony VTC6; D4S: 1-26650 Orbtronic 5750mah high drain. Freshly charged.
The tint of the Q8 (4750K) is a bit warmer than the D4S (5000K). Both look nice.
The biggest differences between the two lights are:
- Physical size and weight
- How they handle their generated heat and
- Batteries
Size and weight: The D4S is pocketable in my denim jeans. At 242g with battery, and only 4.1” short, it is almost an EDC – though it is not a shirt pocket carry. The Q8 needs a much bigger pocket – like the one in my overcoat. The Q8 is also too heavy (608g with batteries) to leave in my overcoat pocket. My car’s glovebox is a good place for it.
Heat handling: The D4S gets warm fairly quickly – though not as quickly nor as hot as the scorching D4. Quick heat renders the D4 less than practical. Not so the D4S: It can run at around 800 lumens without overheating (remember: I live in cold Alaska. You may need to ramp the D4S a bit lower to keep it cool). The Q8, with its greater mass, is a champ at heat dissipation. It takes a long time to get warm; it never gets hot.
Batteries: The four 18650 batteries in the Q8 will outlast the single 26650 in the D4S. But the D4S/26650 lasts a long time (compared to lights with a single 18650).
And the winner is……? Which light will I use the most? Which will I reach for first? Which will stay closest to me?
In terms of short to mid-duration light output (bright bursts up to a few minutes), both lights are equally capable. They are excellent flood AND throw lights.
So, for me, it comes down to carrying convenience. And here the D4S has the clear advantage. It is smaller and much lighter than the Q8. It goes where I go more easily. It also fits in my hand perfectly.
I predict Emisar will sell a lot of these.
Other thoughts on the D4S: The auxiliary emitters are nice (mine are cyan). I keep them on their low setting although the high setting creates a nice Blue Moon mode. I also purchased the magnetic cap. It is a strong magnet. It holds the light at any angle. It is fond of my key ring.
