I have two KL02. Small and light, it fits in every pocket. Very good if you have a limited budget.
Of the more expensive Niterore LA10 and Klarus FL1A.
Nitecore NU05 is a cool little light. It has a slow red beacon at 4lm, fast red beacon at 4lm, slow white beacon at 37lm, or constant on at 37lm. Comes with a headband but can also clip on to just about anything. I have seen them for about $15. Though I see Amazon has them as a add on item for $8.48 right now.
I was going to bring that one up too. Totally neat and lightweight tiny light! It also has an internal USB rechargeable battery. I paid $15.00 for mine and at $8.48, itās a fantastic bargain.
Besides the NU05, Iām also trying out bicycle tail lights. Color tint isnāt so nice but theyāre small and cheap. Check out those by Machfally or Pagao https://m.gearbest.com/bike-lights/pp_622321.html
Blip is a red blinker but still thanks for sharing!
Glo-Toob is also a backup option due to the higher price but purpose wise it is a perfect match. TheEDCgear outdoor survival LED light - EDCGEAR Glo-Tube AAA green review (budget Glow-Toob clone) - might be usable but its out of stock everywhere
I have a Nite Ize Spotlit carabiner clip-on ābeaconā light. Itās now 10 years old. Still works fine. Now Nite Ize is targeting pet owners, for clipping on a collar for night walks. Good idea. It used to come in just red and white options, but apparently you can get it in a variety of colors now (itās a white LED but with tinted translucent casing). And apparently thereās now a multi-colored LED option, for about double the cost.
The brightness is actually pretty soft, enough to gently illuminate a small room with āmoonlightā while still not screwing too badly with night vision. Plus the rugged casing is nicely doneāno anodizing to get scratched, no glass to break, no accidental activation. It requires a good firm squeeze to activate. Once on, I think up to 10 secs a 2nd press will activate the rapid blinking mode. If you wait longer the 2nd press simply turns it off. This makes for a great travel light in your carryon bag. Itās bright enough that itāll help you find bag contents without casting off bright light that might disturb others around you.
The total runtime is 20 hrs, on 2xCR2016. Not badā¦ but Iām wondering if there might be something else available that is more efficient. Any ideas? Or is this the only light like this of its kind?
Interesting. Maybe Sofirn discontinued them. Canāt find any sign. A āringā of COB LEDsāsounds like it might carry quite a lumens punch for the size on high.
One other detail on the SpotLit ā the two domed translucent discs are made of some kind of TPU material (not silicone). Semi-matte finish, so thereās some grip to it. But really resilient. No sign of yellowing. Itās supposed to be water resistant, but I wouldnāt put to use in water activities (like clipping to a life preserver). The LED side has a slight optic-like quality at the center. On the reverse side, itās slightly flattened and has a raised āpower onā icon that you can feel with your thumb, so itās easy to figure out orientation in the dark. One could say an āoverbuilt squeeze light.ā
And donāt forget the dreaded KL02. Swap the resistor for a higher value to reduce current to a glow, and itād last a long time. Use a ā123 instead of 16340.
