Feeler thread / sneak preview: Wuben TO50R HC ("The Flashlight")
Interested :smiley:
It’s temperature regulated. It isn’t as sophisticated as a really well optimized PID, but it stays brighter longer when you keep it cool. Even bounces back after stepdown if you manage to bring the temperature down enough. At some situations this may result in slow oscillations as the light climbs back to full output and steps back down after heating up again.
Without cooling on turbo and high my sample steps down to about 820 lumens and stays there in room temperature (23c) without additional cooling. Surface temperature is about 50 degrees. Most lights this size can’t retain 800 lumens without cooling or burning your skin.
Thanks for the graph! I think if the light was set at 1,200 lumen mode, the oscillation would be farther apart and less pronounced. Maintaining true 800 lumens is really good for this size light. But it is 21700 host so should have more mass. Someone should suggest to Wuben to add a sustainable 800 lumen mode.
Na, i never make neighbours angry… :smiley:
Surly not my favorite color but still a must have… :innocent:
This looks really nice!
Any rough estimates on price?
The magnet in the tail is super strong (and useful). Although at times, it sticks to nearby stuff a bit too eagerly…
Just the way I like it!
I wish this is not a super expensive flashlight, ’cause the shape it is showing is the flashlight :heart_eyes:
Maukka do you have the weight without battery? I just want to see how it compares with the TO46R. The thermal performance of the TO46R is pretty good already but I hope this added a good amount more mass since the output is so much higher.
126 grams with the clip but without a battery.
Oh that’s not so heavy. With a little more mass, it should be able to sustain the 1200lm mode.
Is it going to be micro USB or USB C?
Interested
Interested
Interested.
Interested!
(I don’t have a flashlight that uses LH351D yet… and 5000K CRI 90 sounds good)
… at least until the FW3A gets released (hopefully in XPL-Hi and LH351D versions)
Large gap between 250-1250Lm. There is not enough mode ~700Lm, especially if in this mode the flashlight is thermostable.
Yes , interested
I now have 3 Wuben TO46R lights with different emitters in all 3. I replaced all the emitters because the factory Wuben LEDs are horrible, cold blue- definitely not the 90 CRI LEDs claimed on the box.
But I really like the design of these lights and I’m looking forward to the TO50R. I just hope Wuben doesn’t pull a bait and switch with the LEDs on the TO50R like they do with the TO46R.
Hope we get a group buy for this one
