can this be used with an OSLON WHITE/BLACK LED?
Looks great Hoop, using the retaining ring holes to thread the pill in makes sense but what about removal?
It’s a triple heatsink, though I have a program for singles also. The white flats should work with this kind of setup but not the black flats. Black flats are basically obsolete now though.
Good thinking Dale. There will need to be a provision inside of the pill which will allow it to be turned out. The ret ring would unscrew, then the driver turned sideways, then removed via inside provision.
Yippie
They are truly works of art and I am glad that you are offering them again.
I will be in for a couple.
Bob
I like it!! :+1:
If there is to be a ‘purchase list’, please put me on it.
Like! Please put me on the list.
How about a Cometa copper pill? Recently there have been sold quite many so the demand should not be bad.
I made a duplicate copper pill for my Jaxman Z1 and made it a bit more robust, I think it really helped in the light I built it for and it needed all it could get as I had an SBT-70 in there making a lot of heat. Pretty straightforward build really, I don’t know how many Hoop would sell or if it’d be worth the programming time…
Edit: It was like this Hoop, whatcha think?
I made copper Z1 heatsinks. I think I sold maybe three of them. Still have a few. Cometa heatsinks would probably sell similarly.
Ah, yeah, that’s about what I thought. BUT, with some of the new emitters these may be making a comeback.
Might be worth a poll to get an idea the numbers involved? I mean, you already have the program and all…
( would like to officially speak for one of those few remaining Z1 copper pills… please let me know)
Color me impressed Dale. That pill and retaining ring was a bit tricky to make I’m sure. Nice work. :+1:
Thank you. I guess it’s alright for an amateur. I DO try…
Now if I could only get that fit and finish the true pro’s show off… (pointing at YOU of course!)
Definitely interested for S2+.
PM sent about ‘Copper Z1 Heatsinks’.
IF you were to do one for the Cometa, I would be interested also. . :+1:
Still interested in the Z1 heatsink I pm’d you about
teacher, I didn’t buy into the Cometa thing but I’m pretty sure it’s the same light as the Jaxman Z1. Should be the same pill AFAIK…
If the Z1 copper pill fits the Cometa, I’ll buy two. :laughing:
IIRC Negative on the interchangeability……with the Z1 or X6… with the very first Bombetta’s
Bombetta on the left, Z1 on the right, as if I had to point it out… :person_facepalming:
Edit: above. The lens were interchangeable
Kawi, you mean that the Cometa is NOT a Jaxman Z1? Sure thought it was, even read something recently about that very thing. Me and my memory. Sorry about that teach…
Edit: Ahhh, the Cometa was a Manker clone of the Jaxman Z1….
