Test/review of LiitoKala INR26650-50A 5000mAh (Black)
ooops. My dial callipers aren’t metric. Math error. I also have to use sheet of paper to insulate the battery.
2.50669”
~63.67mm - the paper ~63.6mm
Take the sticker off mine and they say INR26650-50A underneath.
There are two “official” LiitoKala stores selling two different 26650s? “Two men say they’re Jesus. One of them must be wrong.”
https://lygte-info.dk/review/batteries2012/LiitoKala%20INR26650-50A%205000mAh%20(Cyan)%20UK.html
https://lygte-info.dk/review/batteries2012/LiitoKala%20INR26650-50A%205000mAh%20(Black)%20UK.html
You can also use your measurement units imho, let people deal with their own issues in this respect if they need to. There are conversion tools everywhere nowadays. I can even convert most of my usual stuff mentally.
Waaay too short for flat top 26650 cells. They usually measure 65mm or a tiiiny bit more. HKJ measured 65 and 65.1mm for the cyan and black cells, respectively. Mangled caliper?
Cheers :-)
It is possible. I bought them at a Navy surplus store sometime around 1982. Carbon fibre Tajima dial calipers. Need to measure some other batteries.
Results from the first analysis are in.
1.5A discharge. —>. 4651mAh
2.0A charge —> 4905mAh
Not good.
My Gold and Black cells all test over 5000mAh on the same C4 at the same 1.5A discharge.
(photo of one earlier in this thread)
5100mAh? Maybe under very special test conditions.
I’ll check the other 3 cells when I can.
Definitively bad stuff. Open dispute and grab all the evidence you're able comparing them to your blacks discharging in the Zanflare C4. Take good photographs. Fight like the Tsar Bomba.
Buying cells from AliExpress, let me say, is maybe even worse than from eBay. At least in eBay you have PayPal which saves your arse. This is not always the case in AliExpress, and raises cost to some extent. AliExpress is great to buy a nice, good fake. :-)
Shockli 5500mAh 26650s with fairly good price at 192led. Can pay with PayPal and shipping is cheap, at least for me. Give it a try if you will, I'm ordering Lii-100 chargers from them already.
Cheers :-)
Yeah, nothing to write home about for sure. :frowning:
Compared to the Original Liitokala 26650’s we first got a couple of years ago…. these suck. :wink:
Hi Barkuti
!!! Please Pay Attention !!!
The Shockli 26650 5500mAh battery from 192led.com are fake, our company never provide any battery to the 192led.com and will not provide them in the future, please be careful of the purchasing.
Please leave message in the forum or email sales@shockli.com for any questions, thanks.
Best regards—Simon
Cell 2 tested. Cell 2 is slightly better but well off what it should be.
1.5A discharge —> 4737mAh
2.0A charge —> 4968mAh
61mΩ impedance.
I am going to post negative feedback on AliExpress for this purchase. Lets see if they publish it.
Do not buy the blue “LiitoKala” cells from aliexpress store 133859
Cell 3
1.5A discharge 4735mAh.
Tell me, and to what threshold level of voltage (v) do you discharge these of your elements?
The Lii-500 charger does all the testing automatically. HKJ says it discharges them to a bit below 2.9v.
Whoops, you are not measuring on a Lii-500. I guess I got mixed up.
Andrew_Debbie, beware! Since you said “C4” I initially thought you had a Zanflare C4 (which is a lot like the Lii-500), but no! You meant to say “ISDT C4”, which is quite bad. See HKJ's review: Charger ISDT C4 @ lygte-info.dk
Quoting Henrik:
[Quote=HKJ in Charger ISDT C4 review]The charger discharges to 3.1V and it looks like it is adjusting the current trying to keep the voltage at 3.1V. [/quote]
:facepalm:
[Quote=HKJ in Charger ISDT C4 review]The batteries are charged, discharged and charged again. The charge is not done correctly it is missing the CV part (See below about software update). … [/quote]
After the update to 1.0.0.11 firmware in the review, with li-ion cell:
[Quote=HKJ in Charger ISDT C4 review]…
A CV voltage has been added to the initial charge in analysis mode and the discharge mode do not slowly reduce current anymore, instead it drops to 0.5A from there sloly reduce current. It looks like the charge failed, there is no CV phase. … [/quote]
It discharged at 1.5A down to 3.35V, reduced ratio to 0.5A, and finished discharge at 3.05V with a slight tapering…
Without charge top-off tests are invalid unless you start with a properly charged cell (at ≈4.2V resting voltage), and since its discharge behaviour is odd I'd definitively mistrust its figures.
Cheers ^:)
Lii-500 goes down to 2.8V, I can say it for sure since it is my analyzing charger. ;-)
Andrew_Debbie is using a ISDT C4, bad stuff. :facepalm:
I also have an Lii-500. I’ll rerun the Analysis and report back here.
My C4 is running firmware 1.1.0.10. They’ve fixed several problems since HKJ’s review.
The release notes aren’t great….
C4 V1.1.0.10
  1. Improve lithium battery charging.
C4 V1.1.0.9
  1. Improved NiZn battery charging algorithm.
    C4 V1.1.0.6
  2. Add detailed information display.
  3. Add charge current and discharge current setting in analysis and cycle mode.
    C4 V1.0.0.15
  4. Fix the bug of Fan does not stop working when Analysis Done.
  5. Start the fan when USB high power output.
    C4 V1.0.0.14
  6. Fix the bug of Discharge capacity calculation.
  7. Modify the discharge temperature detection exception handling.
    C4 V1.0.0.11
  8. Analysis function optimization
  9. NiMH charge optimization
Yes, my bad. For some reason I thought he had the Lii-500 charger.
I do. I’ll run the analysis again. At the moment the cells are on my desk at work and the Lii-500 is at home.
I don’t want to risk cycling the blue batteries unattened. Will have to wait until I can be around to monitor them. Analsys is going to take a long time at 1A.
FWIW THe gold and black cells all tested to over 5000mAh on my C4. THe blue cells fall well short of that. Even if the cycle is ‘wrong’, I’m testing all the cells on the same cycle.
If I had the money I would get a proper test rig set up. Can’t manage that right now. Especially for 4 batteries I’ll probalby never use or buy again.
If someone needs such a charger that most competently and soundly fills batteries with capacity, then it is better to choose NiteCore D4.
Soon it will be removed from production, so I can advise you to purchase it as soon as possible. It is replaced by chargers with large charging currents, which not only can not fully charge the batteries, but also cause accelerated damage to any batteries. New devices with large currents are also not suitable for the subsequent long-term storage of batteries - they have an accelerated self-discharge. The old Nitecore D4 has unique charging current forms, circuit design which they received from Japan itself. Today, this is already considered an outdated technique, but it is much more efficient and nobler for a gentle charge than current chargers, which have only one goal - to reduce the charge time in any way (mainly for advertising purposes, not the quality and durability of your expensive batteries). Take yourself an inexpensive and cool D4, you can still find the original on sale!
Are you spamming us?
So much of what you said sounds wrong.
I will definitely NOT be buying a D4.
