Definitively bad stuff. Open dispute and grab all the evidence you're able comparing them to your blacks discharging in the Zanflare C4. Take good photographs. Fight like the Tsar Bomba.
Buying cells from AliExpress, let me say, is maybe even worse than from eBay. At least in eBay you have PayPal which saves your arse. This is not always the case in AliExpress, and raises cost to some extent. AliExpress is great to buy a nice, good fake. :-)
The Shockli 26650 5500mAh battery from 192led.com are fake, our company never provide any battery to the 192led.com and will not provide them in the future, please be careful of the purchasing.
Please leave message in the forum or email sales@shockli.com for any questions, thanks.
Andrew_Debbie, beware! Since you said “C4” I initially thought you had a Zanflare C4 (which is a lot like the Lii-500), but no! You meant to say “ISDT C4”, which is quite bad. See HKJ's review: Charger ISDT C4 @ lygte-info.dk
Quoting Henrik:
[Quote=HKJ in Charger ISDT C4 review]The charger discharges to 3.1V and it looks like it is adjusting the current trying to keep the voltage at 3.1V.
[/quote]
:facepalm:
[Quote=HKJ in Charger ISDT C4 review]The batteries are charged, discharged and charged again. The charge is not done correctly it is missing the CV part (See below about software update). …
[/quote]
After the update to 1.0.0.11 firmware in the review, with li-ion cell:
[Quote=HKJ in Charger ISDT C4 review]…
A CV voltage has been added to the initial charge in analysis mode and the discharge mode do not slowly reduce current anymore, instead it drops to 0.5A from there sloly reduce current. It looks like the charge failed, there is no CV phase. …
[/quote]
It discharged at 1.5A down to 3.35V, reduced ratio to 0.5A, and finished discharge at 3.05V with a slight tapering…
Without charge top-off tests are invalid unless you start with a properly charged cell (at ≈4.2V resting voltage), and since its discharge behaviour is odd I'd definitively mistrust its figures.
I do. I’ll run the analysis again. At the moment the cells are on my desk at work and the Lii-500 is at home.
I don’t want to risk cycling the blue batteries unattened. Will have to wait until I can be around to monitor them. Analsys is going to take a long time at 1A.
FWIW THe gold and black cells all tested to over 5000mAh on my C4. THe blue cells fall well short of that. Even if the cycle is ‘wrong’, I’m testing all the cells on the same cycle.
If I had the money I would get a proper test rig set up. Can’t manage that right now. Especially for 4 batteries I’ll probalby never use or buy again.
If someone needs such a charger that most competently and soundly fills batteries with capacity, then it is better to choose NiteCore D4.
Soon it will be removed from production, so I can advise you to purchase it as soon as possible. It is replaced by chargers with large charging currents, which not only can not fully charge the batteries, but also cause accelerated damage to any batteries. New devices with large currents are also not suitable for the subsequent long-term storage of batteries - they have an accelerated self-discharge. The old Nitecore D4 has unique charging current forms, circuit design which they received from Japan itself. Today, this is already considered an outdated technique, but it is much more efficient and nobler for a gentle charge than current chargers, which have only one goal - to reduce the charge time in any way (mainly for advertising purposes, not the quality and durability of your expensive batteries). Take yourself an inexpensive and cool D4, you can still find the original on sale!
I choose D4 and can recommend it for the reasons given above. Now, if you decide not to choose D4, then I would also like to hear your opinion about this, otherwise spam is your words, not mine :smiling_imp:
I do not know where you saw that the D4 was Japanese design or manufacturing, does not insult the Japanese manufacturing quality (which by the way is excellent, see the best in terms of electronics), the design/manufacturing all the products Nitecore is purely Chinese, and in terms of precision: do you want to laugh? I have two of the latest models released by Nitecore, the SC2 and the SC4 (Superb Charger product range), and worse than these chargers I’ve ever seen, let me explain: to start these two charger extremely heat, charging voltages not respected for both (batteries never charged at more than 4.15~4.18v, charge mAh meter (SC4) is totally inaccurate it’s big no matter what (I charged Sony VTC6 with, I I got the results between 1400~2000mAh for charge them : approx. 3.0v to 4.20v (variable as I said before) while I should rather around 2600~2700mAh at least for a charge of this cell model) , on the SC2 as the SC4 there is an unpleasant sizzle noise coming from the internal transformers of the two chargers (a really painful noise) The only thing I agree with you is the fact that the builders of chargers are increasingly opting for fast charging in no way the life of batteries, it’s true and it’s a shame, they should necessarily leave us a feature to choose the amperage load. But personally, I never recommend Nitecore to anyone, even XTAR does better on the electronic side.
Long live to OPUS and SKYRC, chargers that at least they are worth their price.
