Need some opinions for a 3D Mag build. I have two ways to go, help me decide. - 3D it is.
Ok, just as a note, there's a total of 6 Mag builds that will be floating around here, till parts get in.
One of them is a 3D dark Gray colored maglite. I will have a 3 LED setup for it. My problem is that I am torn between two ways to do it. Here's the two versions that I am deciding between.
First: Keep it a 3D and use the 3 XM-L reflector with 3 XM-L U2 LEDs and drive them with a Dry driver. The dry of course is 2.5A with turbo. So...... I am talking going 3 LEDs in series = let's say 3A and 9 AA NiMH (eneloops) = 10.8v (nominal).
OR
Second: Make it a 1D still using the same reflector and 3 XM-L U2s, but using three of the 8x7135 drivers master/slave/slave to control the LEDs. This would be 9A?, but with 4 AA eneloops, only 4.8v
Well I am torn between the two. On one hand a big 3 XM-L light that should run for longer than a few minutes and on the other hand a 1D sized 3 XM-L wow light with just a few minutes run time.
There's other ways and other mods, but these are the two that I have decided on and have parts coming for, so I need to pick between these two.
Your opinions of which way and why?
3D .
Runtime .
3D. You have enough 1D mags at this time. That DRY driver is a beast and will out do the 1D for wow factor.
I’m favoring the 3D because of the Dry driver myself. Hey I only got two 1D Mags going on right now. Oh, four if you count 1C mags, but that’s later…
I guess I will be the MagMan, since I have decided not to buy any more overseas lights and because Mags are so darned moddable.
3D because I just broke my fusion 38 drop in and need to mod my 3d
Well 3D it is.
