I've had this idea for a while, just got round to it.
I used strips of orange GITD sticky tape, though it looks pink in the gif on the light and black/ clear thermochromic powder mixed with UV setting glue as the paint didn't come in a colour change I wanted.
It's supposed to change colour/ become clear at 31°C, I think there are other temp ranges.
This is nice, you can see the heat creeping up the body.
Its not the pigment that changes the color to red/orange after heating, its the orange GITD tape, that becomes visible when the pigment is turning white.
Ok, I think I get it :
GITD orange tape is under the paint. When it turns from black to clear, the orange glow is visible through it.
But that means that most of the time, you’ll not see orange but just white.
Anyway this is cool !
Black is standby colour which turns clear with heat to then reveal the orange glow tape underneath, but since it is orange glow tape, it turns yellow/ green when exposed to light too, then fades back to orange or covered back in black if the light cools down
Yeah thought about it but seems a bit of a waste of tritium as will only be revealed when the light is hot, I use trits for finding the thing to turn on in the first place
I just wanted a part of the light to turn red/ orange when it heated up and the PK Paladin seemed like a good candidate with the grooves near the front and a triple XP-G2 /FET driver setup.
Just a bit of experimenting.
Working on the big mod, what I’m calling the Q8 .441 MAG.
Got the driver built yesterday, tested it this morning and had to do some tweaking on a couple of the slave’s 7135 channel but now it works fine, have Anduril on the original driver from the Q8 with the MOSFET and 7135 chips changed to match my slave boards. 4 Slave boards to run 4 quads with Samsung emitters, original driver running a de-domed SST-40 in the center with a 22mm reflector over it. Hence, 4 Quads and 1 reflector (441) at Magnum power (or Most Audacious Guffaw as a stab at “Giggles”) Also having a bit of fun with the naming as taken from the .454 Casull, using the 3 digit clarification just to kinda show it’s a serious monster. lol
I’ll run one each 14 ga wire up to share with 2 Quad boards, have 4 teflon covered 18 ga leads from the slaves to run these quads. Then 2 22ga leads from the original driver to the SST-40. All running the same MCU with Anduril. Looking for 20,000 to 25,000 lumens but don’t know if the 4 cells can deliver it. Will be trying the new carriers from Sofirn to see if 8 cells or even 12 cells will be able to deliver the amperage.
Waiting on the Noctigon D4S quads and Angie optics, supposed to be here by Tuesday… Center pad is inset with a 25mm MaxToch MCPCB and the wire holes are drilled, need to place the 4 quad boards to see where to drill the holes. Also have a 95mm UCLp lens due here Saturday.
I should probably get on the IMR site and order up a batch of cells to go with it. lol So, Anyone have any ideas about what cell can run 22A each in a 4P configuration? Yeah, gonna need about 86 Amps…
