What did you mod today?
10919 posts / 0 new
Flashy Mike
Flashy Mike's picture
Last seen: 3 hours 16 min ago
… and when this imagined guy finally learned its only the paint he gets one of Dale’s overdriven lights with real red heat …
CRX
CRX's picture
Last seen: 1 week 4 days ago
Well, I'll be carrying this light around with me for the next six month's just waiting for the opportunity Innocent
Flashy Mike
Thumbs Up
pinkpanda3310
pinkpanda3310's picture
Last seen: 13 hours 11 min ago
That’s a super cool idea CRX Shocked Thumbs Up Thumbs Up
luminarium iaculator
luminarium iaculator's picture
Last seen: 2 days 23 hours ago
CRX creativity is just amazing…
-X3-
-X3-'s picture
Last seen: 2 weeks 23 min ago
Where did you find black pigments that turn to some color after heating ? All the pigments I found are turning white-ish after heating
"-X3-, is there any place in your house without a flashlight ?"
My Flashlight public album (mods, emitter swaps, eye candy)
My reviews channel (French language, Olight, Thorfire, Sofirn, Lumintop : 60+ lights tested)
My personal channel (including Olight SR mini, S1, S2, S1A and S-mini disassembly)
M4DM4X blog, saves you $$$
beastlykings
beastlykings's picture
Last seen: 2 days 14 hours ago
Maybe it’s a black pigment that turns clear, and he painted it over top of red?
Wieselflinkpro
Wieselflinkpro's picture
Last seen: 1 month 1 week ago
CRX wrote:
I used strips of orange GITD sticky tape, though it looks pink in the gif on the light and black/ clear thermochromic powder mixed with UV setting glue as the paint didn’t come in a colour change I wanted.
Its not the pigment that changes the color to red/orange after heating, its the orange GITD tape, that becomes visible when the pigment is turning white.
CRX, you are a wizard!!
-X3-
-X3-'s picture
Ok, I think I get it :
GITD orange tape is under the paint. When it turns from black to clear, the orange glow is visible through it.
But that means that most of the time, you’ll not see orange but just white.
Anyway this is cool !
staticx57
Last seen: 7 hours 35 min ago
That is so freakin awesome CRX!
CRX
CRX's picture
X3 wrote:
Ok, I think I get it : GITD orange tape is under the paint. When it turns from black to clear, the orange glow is visible through it. But that means that most of the time, you’ll not see orange but just white. Anyway this is cool !
Black is standby colour which turns clear with heat to then reveal the orange glow tape underneath, but since it is orange glow tape, it turns yellow/ green when exposed to light too, then fades back to orange or covered back in black if the light cools down Wink
Agro
Agro's picture
Last seen: 2 min 36 sec ago
How about doing it with red trits instead of tape?
CRX
CRX's picture
Yeah thought about it but seems a bit of a waste of tritium as will only be revealed when the light is hot, I use trits for finding the thing to turn on in the first place Big Smile
I just wanted a part of the light to turn red/ orange when it heated up and the PK Paladin seemed like a good candidate with the grooves near the front and a triple XP-G2 /FET driver setup.
Just a bit of experimenting.
DB Custom
DB Custom's picture
Last seen: 3 weeks 11 hours ago
Working on the big mod, what I’m calling the Q8 .441 MAG. Smile
Got the driver built yesterday, tested it this morning and had to do some tweaking on a couple of the slave’s 7135 channel but now it works fine, have Anduril on the original driver from the Q8 with the MOSFET and 7135 chips changed to match my slave boards. 4 Slave boards to run 4 quads with Samsung emitters, original driver running a de-domed SST-40 in the center with a 22mm reflector over it. Hence, 4 Quads and 1 reflector (441) at Magnum power (or Most Audacious Guffaw as a stab at “Giggles”) Also having a bit of fun with the naming as taken from the .454 Casull, using the 3 digit clarification just to kinda show it’s a serious monster. lol
I’ll run one each 14 ga wire up to share with 2 Quad boards, have 4 teflon covered 18 ga leads from the slaves to run these quads. Then 2 22ga leads from the original driver to the SST-40. All running the same MCU with Anduril. Looking for 20,000 to 25,000 lumens but don’t know if the 4 cells can deliver it. Will be trying the new carriers from Sofirn to see if 8 cells or even 12 cells will be able to deliver the amperage. Wink
Waiting on the Noctigon D4S quads and Angie optics, supposed to be here by Tuesday… Center pad is inset with a 25mm MaxToch MCPCB and the wire holes are drilled, need to place the 4 quad boards to see where to drill the holes. Also have a 95mm UCLp lens due here Saturday. Big Smile
I should probably get on the IMR site and order up a batch of cells to go with it. lol So, Anyone have any ideas about what cell can run 22A each in a 4P configuration? Yeah, gonna need about 86 Amps…
CRX
CRX's picture
Looks mean Crazy
BlueSwordM
BlueSwordM's picture
Last seen: 7 hours 23 min ago
Samsung 20S would be your best bet. Absolute monster.
For a 4P setup, you need to go all out.
Since you are very skilled, put dual BeCu springs in the Q8 and bypass that array for absolute maximum conductivity Smile
You want as low of a resistance as possible, and a bypassed dual BeCu spring array will do the job Big Smile
DB Custom
DB Custom's picture
Are the 20S better than the 25S?
Already have the large springs on the board with 22 ga (20ga? forget) bypasses. Wink
Edit: Forgot what I’d done on the bottom end, I simply pulled the tube and tail assembly from my XP-L2 build and put the large spring with bypass on the XP-L2 build. So the new one will have dual springs on a copper plate. Wink
BlueSwordM
Yes, it is the best 18650 cell in terms of power output:
https://www.e-cigarette-forum.com/threads/bench-test-results-samsung-20s...
DB Custom
DB Custom's picture
The Samsung 25S actually bests the Sony VTC5A by a wee bit, and at 2500mAh it would have quite the leg up on a 20S. 4 in parallel would mean the 20S would need a whole 5th cell to keep up.
Edit: According the HKJ, the Samsung 25S at 25 and 30 Amps really hammers the Sony VTC5A, which I thought was the best cell out there in the 18650 class. Appears I was wrong. So, I will need to get some Samsung 25S ordered. (more of them I should say.)
MRsDNF
MRsDNF's picture
Nice mods guys. This forum almost needs a name change that includes black magic. Beer
Petr J.
Petr J.'s picture
Last seen: 1 year 1 week ago
Small Mod. I bought a cheap charger on Aliepress. I found that it is suitable for long batteries 21700. Including super long with protection to Rofis MR30 and Wuben A21. I removed the electronics, added the furniture angles as contacts. He slightly trimmed the charger’s contact. Now I have the perfect reduction on the 21700 batteries in my OPUS charger.
Mike C
Mike C's picture
Last seen: 7 min 14 sec ago
Nice mod. I’ll be copying it myself soon enough Smile
Henk4U2
Henk4U2's picture
Last seen: 53 min 42 sec ago
Modded my copper Convoy S2+. Actually, re-lego-ed it.
What stayed: all copper parts with O-rings, The XP-L emitter, the lens and the opaque tailcap rubber.
What came in: long smooth reflector and short pill from a Convoy S2, X6/X5 driver and lighted tailswitch,
and a nylon M8 washer I got from a local DIY-store.
I got: a reasonably throwy almost neutral white tube light with a nice hotspot (a bit greenish in the very centre).
And while I suspect my LX1010B luxmeter consistently shows values that are too low, the output = 19 kCd.
You are a flashaholic if you are forced to come out of the closet, to make room for more flashlights.
djozz
djozz's picture
Last seen: 16 hours 43 min ago
Sounds very nice Henk! The shallow reflector of the S2+ has never been my preference.
pinkpanda3310
A quick and dirty mod tonight. I blued my AT40. Unfortunately I held the torch over the tail for extra long (that was where I started) and the colour went from blue back to pale. I let it cool and tried again but it just didn’t turn out. It’s blue inside the tail. Maybe if I sanded it back and tried again it might work…???
MascaratumB
MascaratumB's picture
Last seen: 2 hours 12 min ago
I am just modded by you folks Shocked
Great great mods, all different, all cool ! Great work, mates Hat
Cereal_killer
Cereal_killer's picture
Last seen: 2 years 3 weeks ago
Finished up the red utorch s1 mini for my wife.
Beam profile was exactly what I hoped for (why I used the SSL-80 version of Olson) but had pretty bad artifacts / rings on the wall so a layer of DC-fix on the inside of the lens fixed that right up
-X3-
-X3-'s picture
What happened to the heart positive contact ? Shocked
Cereal_killer
I thought I would be able to cut / file some 3mm thick Cu sheet (to replace the stock button) but that didn’t happen Sad
I wasn’t able to shape the thick Cu sheet well enough by hand (diamond files and shears) so then I thought I’d just make 3 1mm hearts cause I can shape the thinner stuff well but I couldn’t stack 3 tiny 1mm thick hearts and get them to solder together and solder to the PCB clean enough to feel good about it…
Instead I just reused the factory 3mm x 5mm round button and gave her one of the blank PCB’s. The pad is a heart, just the button didn’t happen.
I tried a solder blob first, you can pile on about 1-1.5mm of solder and have it retain the perfect heart shape but it wasn’t enough height to work Sad
DB Custom
DB Custom's picture
Sometimes the box needs to be shredded and tossed aside… why didn’t you simply solder the brass contact button to the top of the cell, leave the heart pad in place and let it show clearly at every cell charge?
You could also have went with the solder blobbed heart, solder blobbed the top of the cell to meet it. Seems a shame to have gone to all that trouble to make the heart pad only to obliterate it in the end. Sad
