Mine arrived today, 6 November.
All appears to be in order & working well right out of the box. . :+1:
No smoke… No fire… No boom… Life is good. .
any news where find this ‘’square’’ O ring size?
I checked everywhere. But the only shops i could find such o-rings are shops for Business customers.
And they do not sell only a few to a privat person. But please let me know if someone finds a source for square o-rings.
Holy crap !?
So these crappy low capacity cells explode when you have a short circuit??
Then i will get rid of them immediately.
They was send as a “Gift”
this is the reason
Yes… Very nice gift, Banggood… :+1: :person_facepalming:
Imagine having a warehouse full of these… :cry:
The O rings closest in size I found are these:
https://www.aliexpress.com/store/product/LUJX-R-10pcs-Sealing-Flat-Gasket-White-Silicone-O-Ring-Seal-Washer-Bellows-Inlet-Hose-1/3144005_32893451772.html?spm=2114.12010615.8148356.9.5e302d41IBxLWL
They may be to big with 22x28x2 mm, but the O rings with the correct size are only round:
https://www.aliexpress.com/item/White-Silicon-1-5mm-Thickness-19-20-21-22-23-24-25-26-27-28mm-Outside/32803654515.html?spm=2114.search0104.3.15.4497dc10UcwLx1&ws_ab_test=searchweb0_0,searchweb201602_5_10065_10068_10130_10547_319_317_10548_10696_10192_5728811_10190_453_10084_454_10083_10618_10307_10820_10301_10821_10303_537_536_5733215_5733315_328_10059_10884_5731015_5733115_10887_100031_5733415_321_322_5730015_10103_5733515_5733615,searchweb201603_55,ppcSwitch_0&algo_expid=a130f1a1-3fa0-4d57-86eb-463f6d148e43-2&algo_pvid=a130f1a1-3fa0-4d57-86eb-463f6d148e43
Skylight this is not a bad find! But the OD to ID ratio is not right!
The OD of the light at the finning area is 36,7mm. So a 37mm OD o-ring would fit perfect and prevent ratteling. The main problem is, the finn spacing is 1,2mm but they are 1,7mm deep. This is the reason why it is not working with a round o-ring. Maybe if you use 2 flexible silicone o-rings ontop of each other.
But almost every flexible flat o-ring with a OD 28-37mm should fit, aslong the ID is ~3,5mm smaller than the OD.
A 1,2mm wide o.ring will fit perfectly but if you have one with a smaller OD (~28-33mm) you could get a 1,5mm one to fit (should fit after streching it to 33,3mm ID).
My main problem is to find one with this OD to ID ratio.
And it seems that now all Cometas are sold. The EU Warehouse is also showing Sold Out now.
My Cometa from Cinese warehouse has arrived yesterday. :partying_face: I have got to admit that I imagined the light much worse but if you compare it to cheap Cinese zoomies the quality is quite a few levels above. Already the anodising is different, a nice smooth black instead of the usual glossy black. Maybe I will get some O rings too or just let the zoom rattle as long as it is not the whole head coming of. It seems that they have solved the problems with this light now, just don’t forget to put the plastic washer in and the light will be save to use.
Thanks for Find these O-rings.
tomorrow will check well, now i’m tired.
Guys remember, my flat square Ring fit perfect for zoom.
Not too lose and not too hard when rotate head
measures 28 x 24,5 x 1,2/1,5 mm thick.
Good news,I have contact AE seller that can customize size of square O rings
for fix Cometa Zoom
Price is a bit hight(8 usd 10 pcs shipped with track number) but said discount for large quantity.
So we can do a group buy?
for fix Cometa Zoom
Price is a bit hight(8 usd 10 pcs) but said discount for large quantity.
Sounds like a plan……
yes a good option,but don’t know procedure.
For get a discount asked the seller if can produce like 100 pcs (10 pcs for each of us)
Sent to different addresses
But said discount only if a single buyer get more than 10 pcs
I got my own too! Finally after waiting for so many months.
for fix Cometa Zoom
Is that $8 each for 10 pieces (total $80), or is it $8 for 10 pieces (total $8). If the latter, that sounds like an excellent price for anything custom.
Sorry but from phone is hard.
first price $8 for 10 pcs (total $8)
now seller say $7 for 10 pcs (total $7)
Count me in!
my was just an Idea,don’t know how make group buy
Are you able to share the vendor? I can order on my own.
This is the seller able for customize Ring size.
https://it.aliexpress.com/item/LUJX-R-10-pz-di-Tenuta-Piatto-Guarnizione-In-Silicone-Bianco-O-Ring-Rondella-di-Tenuta/32893451772.html
You need talking with him for Customize measure as I do.
Please don’t change measure,
Right size good for my sample : 28 MM OD - 24.5 MM ID - 1,3 MM H, Flat-Square profile (silicone)
Try ask him for discount quantity
Mine came in day before yesterday; what a great light for $15.
Wish I had bought more
Sorry to bother you guys with absolute noob questions here.
I don’t know anything about flashlights or modding or whatever. I can put a battery in and turn the light on, that’s about the extent of my knowledge. I only signed on here because I received a faulty BLF A6 and tried to look for a fix.
Still I’m getting the “Cometa” as a throw-in “gift” from banggood. Now I don’t know what to do with it after reading this thread and watching a warning video on youtube.
I only have 1 Samsung 18650 Q30 battery. Is that a suitable battery for this light?
What would you do if you were me with this light, if “working on it” in whatever shape or form is not an option?
