Yea I realize this charger is unable to but I already have high power USB hubs so I prefer chargers which I dont have to worry about power supply and cable. Just plug in to any port on my 5-6 slot USB hub.
USB C with power delivery spec or otherwise would be much better I agree but I think maybe one or none exist so far by any brand.
yes chargers have not USB C output, but the higher voltage and like 2.4A should be possible one side USB A and other type C to deliver enough power for this charger
even its not that powerful than the C4-12 it does not have the brick of external PSU which I do not like on the C4-12 and C2-6000 model
at least Dual input like Nitecore has for an external 12-15V PSU would be nice so it can be used in a car
I’m a noob when it comes to rechargeable batteries, and I’ve been looking at chargers for them, something for an Xmas present. I’ve been looking at chargers off and on for a year now, and finally settled on the Miboxer C4-12, until I seen this C4 plus.
I’ll proabbly mainly be charging 18650’s, I use a flashlight a lot at work, and they will mainly be for that to start. (I have to pick out a new flashlight too, but first a charger). I know I can get a cheaper charger that doesn’t have as many features as these two, but I am set on one of these, just in case I start getting more into it in the future.
My question for you with all the the experience, between the c4-12 and the c4 plus, which one would be better for a noob like me?
Add it to your Amazon cart. Click on cart and you will see a coupon. Click the coupon, then go to checkout and the coupon will automatically apply and lower the price.
Can you list this on the Amazon Australia website or on Aliexpress with the special discount code? Australian customers cannot buy from other Amazon stores around the world.
This looks like a nice modern charger that can accept the longest protected 21700 batteries…
Seems like an improvement to the Miboxer C4-12, with just slightly lower charger current (C4-12 handles 4x3A, while C4-Plus handles 4x2.5A) but 2.5A and 3.0A charging time shouldn’t differ too much except maybe when charging those high capacity 5000-6000mAh 21700 or 26650 cells, right?
One thing I noticed with mine is you can set the charge rate but it never charges at that rate. It’s always substantially lower then it drops rather quickly. Then the last 10mah takes forever. Shows a charge rate of a tenth or lower. Still seems like a good unit. I have plenty of batteries so I don’t have to wait on the ones charging. I know it’s designed so that it protects the batteries.
