I agree with JasonWW. For me the VTC6 is not better than the 30Q. And when you consider actual OEM cell prices, Murata/Sony can lick my bird. Sony is not shy of providing peak temperature cut-off discharge ratings even sacrificing cycle life. Like VTC4's being rated 30A, but they're not 30A continuous. Of course this makes their figures bigger, though this does not make their products necessarily better.
70.2 - Single cell there so probably a boost driver. Sorry. FET drivers on 3 volt LEDs like XPL-HI. Can a high drain unprotected battery be used in both scenarios?
Boost drivers have regulated outputs, so you want the lowest resistance possible. Such as bypassed springs and high drain cells. Depending on the load the boost driver puts on the battery, you can sometimes have too much of a good thing and loose run time.
If you look at this review you can see a light that draws 15 amps. A high drain 30T allows for many full power turbo runs, but capacity is small. A high capacity 5100mah cell only allowed one full power turbo runs, but had much longer running time at lower levels.
Here is more data on the same high powered boost driver light with different 21700 batteries.
What I said earlier still applies to FET drivers. You have to take it on a case by case basis. You would need to be more specific about which lights.
JasonWW - Thank you! Needed to know if I should be sourcing multiple types of 21700. The answer is yes. I will read those threads after work. Appreciate it.
You can mainly read post #1 in each about the batteries.
So far there seems to be 3 main types of 21700. The high drain like the 30T, the high capacity like the 50E and the middle like the 40T.
Someone like DB Custom has tried the 30T with all kinds of emitters with FET drivers. He’s a good person to ask if a specific emitter is going to handle a high drain cell.
Samsung 40T battery #1:
Charge test (Opus BT-C100): 3511 mAh discharged at 0.5A
Internal resistance (Opus BT-C100): 106
Charge at 1.0A (Xtar VC4): 3566 mAh
Samsung 40T battery #2:
Charge test (Opus BT-C100): 3691 mAh discharged at 0.5A
Internal resistance (Opus BT-C100): 88
Charge at 1.0A (Xtar VC4): 3883 mAh
Also bought two (subpar) Samsung 50E in the same order:
Samsung 50E battery #1:
Charge test (Opus BT-C100): 4472 mAh discharged at 0.5A
Internal resistance (Opus BT-C100): 96
Charge at 1.0A (Xtar VC4): 4698 mAh
Samsung 50E battery #2:
Charge test (Opus BT-C100): 4427 mAh discharged at 0.5A
Internal resistance (Opus BT-C100): 93
Charge at 1.0A (Xtar VC4): 4650 mAh
I’ve emailed them the test results but have not heard back. Suffice to say, I won’t be buying from them again.
A manufacturer, MANUFACTURING something to have some performance.
This is determined by some limits set by a manufacturer.
If I exceed these limits, then we are not talking about yield that exactly matches the construction.
We are talking about off-limits.
If it is possible or not to operate outside the boundaries of a construction, it is something else.
- My car can reach 200klm / h - 6300rpm.
On the downhill will reach the … 300klm / h - 10000rpm.
But at some point the engine from high pressure …. will break …… -
This means that an engine has some tolerances.
If Mooch or any Mooch states that such a construction has such a performance, it simply tells his opinion.
My opinion is different about why something was being fabricated and what performance this construction took.
Personally, I will read Henrik’s opinion, because Henrik’s temperatures are the same or very close to manufacturers’ statements.
The differences between batteries today are small.
If I get from a battery 3.5 Volts, and from another battery 3.45 - 3.48 Volts, I think I will want to fool myself because I like the …… brand.
I think it’s right to compare the overall performance of a battery, resulting in …
force
duration
life
as an overall combinational image
Not just based on how many Amps it was able to perform on a discharge.
Cell 1: 4,782 mah
Cell 2: 4,714 mah
Cell 3: 4,698 mah
Cell 4: 4,524 and 4,566 mah (measured twice)
Cell 5: 4,834 and 4,870 mah (measured twice)
They are only being sold for a super bargain $5.99 right now. I also tested them in the Fireflies E07 and the LR2170SF outputs higher than the Samsung 50E and LG M50. Get them before they sell out or price increase!
I’m not sure, I have a strange presentiment, let him answer thank you, if I’m right I explain why I asked my question this way and you’ll understand quickly …
Ok thanks for your quick answer, why else did you do this measure of capacity twice on certain cells in particular? And did you change the test slot during the second capacity measurement of these cells? If no, what slot number of XTAR VP4 Dragon did you use? N1, N2, N3 or N4?
I measured those two twice because the numbers seem either too low or too high so I wanted to confirm it. I can’t remember whether I remeasured them on different slots or which slots I used. But I don’t think the slots matter because from my testing, most of my other cells were very consistent.
However, there is a fairly common problem that is revealed with the wear and regular use of XTAR VP4 Dragon (I am at the 3rd replacement of my VP4 Dragon, although I also have a SkyRC MC3000 (which also is subject to this type of problem with wear and time unfortunately, it is not specific to XTAR) and ZKETech EBC-A40L (much more reliable have no problems, but for a device that costs a little more than 180 usd I think it’s normal)), so the recurring concerns are the even-numbered slots, ie the slots 2 and 4 which with the time of use and the wear, end up having a reading wrong measures, which give either too low or too high results, which therefore push us to often re-perform the various tests by bail, but gives again erroneous results too inferior or too high, the only solution being to operate the Charger/Analyzer warranty if it is still running or buying a new one (I know something :cry: …).
I was going through the chart supplied by the OP and noticed a strong correlation between discharge rates and storage capacity. Probably the same thing for recharging lifetimes.
Interesting to me because I have some second hand li-ions that top out somewhere in the 1800mah. I’m in the market for new cells, but can’t make up my mind if I should buy the highest amperage batteries or more higher mah. Then the question, do I care if the lifetime is measured in a few hundred cycles.
Obviously, there I’d too much temptation to max out the light output.
Given history……after much thought and consternation…I will buy the cheapest.
Once again, a thanks to the OP for his great work for testing all these batteries.
I swapped the Cell 4, which was tested at 4,524 in Slot 1 into Slot 4 and it measured 4,520 mah. Slot 4 is where I measured Cell5 at 4,834mah. Therefore this rules out the potential problem you suggested.
