Kinda, yeah, itâs got 72 dies and dwarfs the 70.2. lol It can do a little over 16A direct drive for some 4300 lumens. Iâve had them in all sorts of lights, even a chopped miniMag with 2 14250 cells. (thatâs the 6V variant, I also have some 9V ones)
Iâve tried a dozen different 3000k emitters. The Oslong Square 96CRI, E21A, and SST-20 is the best. I never tried the LH351B 3000k 90CRI though and never seen any test report on that but fear it might be above the BBL yellow/green like the other Samsungs. You can get a SST-20 3000k 90CRI triple on 20mm mcpcb from KD and just swap it in the TO46R. I modded three TO46R that way. Very easy to do and direct fit. No physical modifications necessary. The SST-20 3000k 90CRI looks beautiful in this host. Does not look yellow at all.
Older eyes are generally more frazzled, even if they started off perfect. Particularly if the owners have spent a lot of time outdoors without protection from UV and high intensity. They wear out. Look after them.
10% of male eyes are defective to begin with. 0.5% of female eyes.
The blue cones are most easily damaged, hence I suspect a preference among some older people for colder tints, to try to make up for what they have lost.
My other Wuben To46R is getting the LH351B 4000K 90+ CRI soon
Texas-Ace is sending me one of his nifty Lumen Tubes and I want to measure the stock light before I mod it.
This was a super easy mod. The triple emitter, 20mm boards from mountain Electronics drop right in.
Remove tailcap and battery.
Unscrew the bezel. I pressed the bezel into a piece of foam and turned the body.
Pop the open tail-end of the light a couple of times with the palm of your hand to generate a slight increase in air pressure inside the light and the lens will drop out.
I used a fine tip pair of tweezers to remove the o ring and the optic fell right out.
Un-solder the red and black leads from the original triple emitter board, straighten the wires a bit so they donât catch, and the emitter board drops right out.
Thank you! Looking forward to seeing more! I have heard, as SKV89 stated, that the Samsung LH351 has a green corona, though Iâm not sure which exact LED it was so hopefully you have a better outcome.
Also thanks SKV89 for the tips on emitters. Iâm going to order a few and get my Weller out this Winter!
I have recently used a lot of the Samsung LH351D 80 CRI 5000K emitter, I donât see this green that has been much ballyhooed about when used in reflectored lights or certain optics, other optics do indeed shift the tint. I donât know if thatâs just the batch I got or what, but mine have been fairly pleasantly warm. This is a U6 power bin. The W6 power bin in 70 CRI 5000K is actually almost white and quite a bit stronger. I prefer this 70 CRI W6 to the 80 CRI U6, both in 5000K tint.
Thatâs great There are a couple of catches in there too
I think if you start off with decent eyes that they mostly carry on working, just fade a bit at the cooler end as we get older.
But other things can also start to go wrong.
It used to be that no-one used headlights in town, we had âsidelightsâ for that, only switched on at âlighting up timeâ, still do actually, still legal, but no-one uses them. A pity, because bicycle lights etc. now have to compete with car main-beams and glaring âdaytime position lightingâ, and as a motorcyclist I have had to add a couple more lights just to keep up with the lighting war and try to stand out, as well as a helmet cam, just in case. Whereas it used to be easy, just keep your headlamp on dipped beam.
It used to be in France that white headlights were illegal, only yellow tinted bulbs were permitted, and it used to be a ritual for my father to change them over, and mask out the LHD dipped beam with tape, just before we crossed the channel in our VW camper, back in the â70s.
I know several elderly people who are almost night-blind, but can still cope well enough around town, wearing yellow-tinted driving glasses. They were much happier when we still had high pressure sodium streetlights (orange), but the modern cold white LED ones donât suit them at-all (as well as being much dimmer).
This test is more subtle, but I can also pass it easily:
That is very insightful. Iâm 70 years old and spent 3/4 of my life working outdoors and the other quarter working indoors under fluorescent lighting. Not to mention I grew up by the beach in Southern Calif. and spent most of my free time in the sun without eye protection.
Iâm very susceptible to warm tints that so many here love as they are very distracting to me as well as green tints. CW without any blue or green is my preference by far and is the easiest and most pleasurable tint for me.
I rode a 750cc (Honda VF750S, V45 Sabre) for years back in the 80âs to 90âs, put 50,000 miles on it. Mounted an auxillary light under the main headlamp even then. Wanted to be seen, not hit!
Honda CB750 KZ when I was 20 (unconditional job offer from BAe before I graduated convinced the bank manager to give me the loan.)
Then more big Hondas, moved on to BMW. K100 RT, K1, R1100GS (still have the last two, the K1 being rather a classic. As well as a little Kawasaki KLX250 to put on a rack on the back of the camper.
Also swap these around with a trusted brother, modern BMW750 GS, classic R100GS PD in as-new condition, replacing the one that we wore out over a decade of long European tours with our GFs on the back. Honda XR400 (Australian import stripped down and tuned, doesnât even have a battery), Suzuki GSXR750. Honda Firestorm 750 twin, several big Kawasakis, etc. etc.
Canât really have anything 6000K or north without some blue, thatâs how blackbody radiation works after all. I would imagine worse rendering of the rest of the visible spectrum is what makes some emitters look so much MORE blue than others however.
Between a slightly green hue and tons of tint shift I will take the green every time. To me its the wild shift in colors as you move the beam/your focus that is really disorienting and makes colors hard to distinguish. XP-G3 HCRI is a great example of this, I would take MANY other emitters over that.
I thought my V45 was fast, then I rode with a guy that had the V65, dang thing would scream off away from me in 2nd gear! He claimed itâd do 110 in 2nd, I donât know, but it was greased lightning in the days before crotch rockets. Seeing him on his, the way the shaft drive would scrunch the wheel base shorter and make the bike stand up, made me realize my mono-shock wasnât working! Honda wanted $600 for a new one, back in â87 I think, early days of internet, I found one online at a bike salvage yard in VA for $200. Man was my bike so much better for it! (I was 135 lbs back then, thought the shock just was geared for a heavier driver, lol)
Methinks Fireflies needs to give us some flashaholic fodderâŚ
Until the camchain system failed, which they all did
As with my CB750KZ, I had to replace both of them, and the tensioners, twice in 60K miles. By then the piston rings were so worn that it could take a minute of cranking before it even coughed. And the clutch was barely usable (slipping at any moderate torque).
Never got more than 40 mpg from it either, usually 35. It had poor diaphragm carburettors with âpower boostâ jetting that guzzled juice.
Which Is why switched to BMW. To get 55 or 60 MPG (genuine), instant starting (fuel injection), no greasy chains to adjust and replace, double the service interval, a genuine 140 mph sustainable performance in comfort (those were the days, Iâd better say no more, but 800 miles in one day from UK to Southwest France was a regular run), topping out at just over 160 on the K1, electrically heated handgrips, Nivomat self-levelling suspension. And the first ABS brakes.
BLF members with better connections to the retailers should push for this specific model, as Nichia 219C 90 CRI 5700K is also a very gorgeous CW (actually feels NW just a bit on the CCW side) emitter. For me Nichia E21A 6500K, which is available from Clemence, is a bit too cold white, but it still handles browns and reds very well !!
So I will have very high expectations for the LH351D 6000K 90 CRI, just I wish, it would be available.
