Led4power.com : LD-4 CC linear drivers, ILC-0/1 illuminated tailcaps, optics, MOSX, copper DTP MCPCBs...
Have you ever considered making 20-22mm drivers or at least stocking 17~~20 and 17~~>22 quality spacers?
You can buy it on KD
17>20 2pcs
17>20 5pcs
20>22 2pcs
I have a 17 to 20 but who wants to use 2 spacers to go from 17 to 22. Thanks for the 20 to 22 though havent seen that
It would be handy, I would get one to mod my Amutorch VG10 :wink:
I plan to have all sizes for new driver iteration, so until then LD-x4 will stay 17mm only, sorry.
Trying to set the max power of my LD-A4. 10+ clicks enters main menu, OK, 5 fast clicks blinks and power goes down. 1 click enters current adjustment, OK, 1 blink and current goes down again. I click 7 times for 4.75A. I get 15 blinks in response. What’s up?
BTW 30 seconds of idle time was WAY too fast for me, I needed over a minute just to read the relevant section.
That’s right
Correct, now you are in the setting you chose
Wrong, in the “low light” setting, 1 click = return, >= 2 clicks: Setting
You now left the setting and went back into the menu
That should not happen as you left the setting and now are in the general menu
That’s wrong, you now should be in setting 7 (whatever that is)
You can always enter again.
But in that case, read first, note the settings you want and then start configuring…
[quote=zeroflow]
:person_facepalming:
I meant 5 fast blinks, not clicks.
Making notes, that’s a good idea. Still, I believe that making the duration much longer would make the adjustment easier.
LED4POWER, can you tell me tint bin of the LH351D 4000k 90CRI you are selling? It says SPHWHTL3DA0GF4T0Q6, which means tint bin is T0 but there is no T0 tint bin.
Oh NVM, I see description says T6.
Isn’t 12amps too much for a triple 219B? Did it run fine? How many lumens were you making?
Forgot to let my feedback on the things received! All good and some are already in use :wink:
BTW, it took me a while to figure out how to operate the driver configuration, but then it was all full speed ahead!
I’ll be getting some more soon and other stuff as well!
Thanks for you work :+1:
Ordered 10x Luxeon V2 4000K 70CRI from DigiKey, excited to try these out. I think the 5000K versions will begin showing up in less than a month it seems. I’m sure LED4Power is already on top of this :slight_smile:
The original 4040 Luxeon V has one of the most evenly tinted beams of any LED I have seen so if this is remotely similar it will easily become my go to 70 CRI LED choice for 3535 footprint.
I am not too smart.
6×0.5mm Gold Plated Brass Button Contact
This means 6mm not 6 contacts. Public service announcement. :slight_smile:
Don’t feel bad, I made the same mistake because I added this item at the last minute and did not pay enough attention :person_facepalming:
… +1 :person_facepalming:
I was expecting 6 and only 2 arrived! I should start reading things carefully :smiley:
But I didn’t need them yet :stuck_out_tongue:
LOL. Glad I wasn’t the only one.
Maybe L4P can update the description for us and create a “discount” pricing tier
Yup, adding a 2 x “6mmx0,5mm” would be more elucidating :wink:
I have one doubt about the LD-A4! I am using mine with a foward clicky switch on the OTR M1!
I have it configured with Moonlight + 3 modes, with the 2x clicks for Turbo.
However, when I double click it (half press as it is a FC switch), it doesn’t assume the “go to turbo” most of the times!
Also, sometimes I have to click 2 times after being on “momentary” moonlight so that it goes to turbo. Maybe this is related to being a FC instead of a reverse clicky switch?!
But another strange thing happens! Imagining I am on mode 2 (low, after moonlight) and I double click (half press), it will go to mode 4 (turbo) but it always take a bit longer on the mode 3; meaning, from modes 2 to 4, it always passes and “waits” on mode 3 to slightly step up to 4…
This happens both with FC and RC switches. Is this normal? Or can it be related to some bad installation I might have done?
Thanks and sorry for the confusing questions :stuck_out_tongue:
Actually I fell for this as well. :slight_smile:
Changed listing to "6mmx0.5mm (DxT) gold plated brass button contact" to prevent further confusion.
It's difficult to mimic reverse clicky with forward clicky switch, mostly you can do only simple operations.
