I will tell you I have both. I like both but the MS04S was awesome. Given the distance the human eye can actually make out an object is less than what these lights are capable of. The MF04S would be the one I would pick (Personal preference/opinion). A neutral white will not wash out the objects as much either. You will not be disappointed with whichever you choose.
Agreeed…
I have both versions in Cool White and both are very impressive. If you want specialized throw, the XHP35 is awesome. If you want great throw with awesome output and generally just a wider area lit up at range, get the 04S.
Of course this is important: The 04 in XHP35 lasts much longer on Turbo and the other run times as well.
It is argued that the Warm White is better for less diffraction in humidity, I personally do not follow that argument as I have photographed lights hitting subjects at almost 2 miles and the Cool White light worked better even in a light rain. I even had my wife run the two lights and I traveled closer to the subject, took the photo’s from a few hundred yards away and off the line of light… the Cool White visibly put more light on the target. In spite of a light rain. So I know from personal experience that the folks shouting hurrah’s for the warmer tints are just opinionated.
Cool White makes more lumens, throws farther, glad to have resolved that debate for you.
Carry on.
Edit: Oh, yeah, you probably want to see for yourself… The lights were 1.9 miles from this tower, shining in from my left about 60-70 yds away from me (the beam line was that far to my left) I was about 300 yds from the water tower taking these pictures.
these are a …bit throwier than the GT/GT70…?
YES…they have to be, as the reflector is bigger and deeper then BLF GT…
It’s strange that mf04 has a larger hotspot and gives more range
I would go with mf04… mf04s xhp70.2 have a bit green tint.
As a matter of fact, my mf04s died… i think its the driver, carrier, or led… all of them…
The photographs you show for comparison were made during a clear night (there are stars in the sky background of the picture). If same models were used for comparison just with emitter CCT differences, these photos are truly convincing for clear sky/air conditions.
However, you could show photographs showing these beams hitting targets through light to moderate fog as well.
My personal experience, that when I use flashlights in mist/light to moderate fog, cooler CCT flashlights are casting a more disturbing beam into the air, making unnecessary glare, and reducing perceived contrast at the illuminated target.
Probably I need to experience with this topic for myself more, but I do find warmer tints useful in those cases. (I edited/corrected my previous post)
With maximum respect to your knowledge and experience, I feel these above a little bit offensive and unnecessarily arrogant.
Pretty sure he was just using hyperbole and speaking anecdotally there. It’s common for people in the states to have an acerbic, satirical, sarcastic wit however they usually mean nothing offensive by it. Just see it for what it is.
I havent email yet… i sent two email about my broken imalent ms12… ( with the video proof ). i never got any email…
I am sending email to banggood about the mf04s now.
Adam, facetious is the word… I put the big smiling smiley face to show I was saying that tongue-in-cheek. We all have our opinions based on our individual needs and preferences of course.
And it was indeed a misty high humidity night when I took those pictures, the misty cold rain I was standing in had me somewhat worried about the 60 mph traffic on the road right behind me. The cloud cover broke just to the North of my position which is why the stars are visible in the background. I was using a 200mm lens to bring the water tower closer as I was parked in an entry driveway and set up at a barbed wire fence several hundred yards away, the starry sky is also pulled in closer in appearance than it actually was.
We get a lot of weird weather, once I was driving into town in sunlight and literally in the middle of train tracks I had to cross it was raining heavily, the tracks divided a blue sky day from a bleary rainy day. From where we are I can usually see a storm system rolling in from 30 miles away in 3 directions.
Believe me, when I take a $5,000 plus camera out in the rain for pictures of a flashlight beam I do Not take it lightly!
That’s right. Maybe I am a bit too obsessed with non-CW flashlights - but not for nothing
I believe you now
By the way, does somebody have good MF04 vs MF04s beamshots to compare? (And MF02 vs MF02s).
It would be good to compare them regarding tint-shift.
Maukka measured huge/ugly tint-shift on the MF02s, and I am curious, how does it show up in a tighter beam (MF04s)?
Indeed, cool white = brighter = more throw BUT your pictures aren’t a demonstration because most of the time, in usual condition, you are holding the flashlight you are using and a thrower like the MF4(s) in cool white, because of scatered light, it makes a stronger white halo right forward your eyes sight and you won’t see the objects very far, illuminated with a dimmer light than the white halo.
Neutral white or warm white are dimmer, throw a bit less but let you see much better what is behind a much dimmer halo when you are holding the flashlight.
In your pictures, as you are away from the flashlights, the view is not blocked by the halo of the scatered light.
Personally, I am done with XHP35 HIs.
I have these lights~
MF02S
MF02
MF04S
MF04
^^ those pics tell it all.
I notice that on my MF02S there is a large dark spot in the center of the hot spot that is even visible when pointing it to a white wall. I often see it when pointing it to trees. Not the best beam in the world, but ok.
i love how balance between both options, look like he can’t make decision now
to me the mf04s is more pratical, it provides reasonable lumen and can throw far enough for most of people
