Since this group is my support group, I have to admit……….I may have a problem.
Is anyone having switch problems with their light? Mine came out of the box malfunctioning. The light won’t turn off. I have to remove the tailcap.
This sounds like a short to the ground wire of the LED. Very possible.
yes sadly a few so far had problems around 10-12 so far reported in the other gt thread, myself i got a new head from neal and a few others also that bought during group buy so its nice to see that they atleast sent out replacements. You should ask also for new replacement head, have zero issues now with the new so hopefully it will stay that way.
Switch problems i guess ? U bought from Neal or banggood ?
My GT Mini button feels spongy, is this normal?
yes the early batch of the gt mini feels more spongy, the newer replacement head it feels a bit less…
I got the GT mini today. Overall it’s a really great flashlight, but in my sample mode programming sucks. I’ve managed to set “UI - mode sets” and then I tried to program mode set. Here’s what happens:
1 click (in programming mode) - 1 mode (moonlight excluded)
2 clicks - 2 modes
…. same pattern - number of x clicks gets me x modes…
7 clicks - 7 modes
8 clicks - 8 modes (first WTF?)
9 cliks - 4 modes
10 clicks - 5 modes
11 clicks - 6 modes
12 clicks - 8 modes
That’s neither NarsilM v1.2 mode sets, nor those in manual I got with the flashlight. Anyone had same situation?
Everything looks correct. IIRC the manual that came with the light is an old version based on a different light. Look in post 1 here for the correct manual.
Ok, problem solved - thanks JasonWW!
Are all those “100%” modes driven DD with FET?
Good point, I forgot about that.
Yes, turbo / 100% are the same thing.
OK, thanks!
Does anyone know what LED they are using in the NW version??
I just jumped on this light without doing much research, thinking I would have to swap out the LED anyway.
After having it out a while tonight, I love it. I want to order some more LED’s of this tint.
Pierced the woods almost as well as my NW modded M2X Javalot even though it didn’t have the lux.
4000k XPL-HI in the 5A/5D chromacity bin, so under the BBL.
Thank you, Its performed well in the timber.
wow that is very good specs for a 4000k emitter. almost 1400 lumens is accurate also ?
It seems most have gotten about 1250 lumen for the CW. I would expect the NW to be a bit less. Assuming you use a good high drain battery.
You have to take all lumens ratings with a grain of salt.
okay that sucks komeko u tricked me i thought it was actual lumens he got from his.
