Wuben P45R [videoreview + pictures ]
Hello my dear friends!
Wuben sent me a sample of their P45R and i made a short video (first contact)
added some pictures as slide on my blog:
http://m4dm4x.com/videoreview-wuben-p45r-tactical-flashlight/
beamshots
some pictures
nice, thick cardboard (with spelling error)
the specs
all this is included: flashlight, cell, charging cable,holster, user manual, warranty card and QC certificate
nice engraving and the backlite side switch
CE mark and serial#
the holster with the backup cell pocket
main switch in the tailcap and charging LED (red/green)
the micro USB port is glued in - so even if you loose the plug it stays waterproof!
RED inicates charging
GREEN means full
double spring in the tailcap
good lubed rectangular thrreads and Oring - and the (removeable) tactical ring
its just red loctite in the head ;)
positive contact on the driver
a look into the bright end
how i open most bezels...
the stainless Bezel
very thick, AR coated Lens
clear sealing ring
opened up
deep, shiny aluminium reflector
copper MCPCP with centering ring
Cree XHP35 HD - seems easy to swap the LED for another tinit or the HI
the switch board can be seen down here
included protected cell
LOW
MEDIUM
HIGH
TURBO
beamshotvideo added
So it is a special battery with plus and minus at the tail?
What happens if I insert a normal one?
And what if I try to charge a normal one?
no the P45R I using a regular cell
the light charges and works with any cell longer than 68mm (30Q flat top did not touch tail and head)
Wuben uses the body as plus and the spring as minus
