I shaped the end of a 4â bar of 6061 to fit down into the Q8, seating firmly on the original emitter shelf and threaded into the bezel threads. There are more threads in the light than the bezel shows so it takes several revolutions to screw this piece all the way down. The two screws that once kept the reflector from turning now lock this new head in place.
With 4 Samsung 25S cells the light weighs 3 lbs 2 oz.
I had a 3s lipo pack kicking around I made it into a phone power bank. Itâs not huge capacity but it will do QC2 Only issue is I have to charge it with a hobby charger through the balance tap. Itâs all hard wired and epoxied. Iâm thinking I couldâve shortened the cable I little too but never mind.
I put a LH351D 4000K 90CRI in my A6. Measured 1552 lumens OTF. Bought from led4power and was a 5 minute job. Tint is very even with a bit of green, colours pop nicely under it
I was inspired by thisnameisvalid and decided to rebuild my very first modded light, my A6!
I put in a Luxeon V2 4000K 70CRI (a 3535 package brand new LED). I think I got the first 10 available from DigiKey here
According to my shoebox I got 1,367lm turn on and 1,094lm at 30 seconds using a VTC6. I decided not to try my VTC5A yet in case I kill it.
I tried to measure amp draw but I think the thin tube on this A6 makes it hard to get good contact. I think it was ~6.5A on the same VTC6 after about 45s of turbo use. This is with a bypassed tail and blue small spring (no bypass) on driver side.
The beam is similar in tint to Luxeon V1 (the 4040 one) but exactly as you would expect, a bit more throwy and less power. Comparing it to a LH351D 4000K 90CRI I would say the Luxeon is MUCH more ârosyâ, no hint of green, and just overall more white. However, iâm a little disappointed in the output. I expected something a lot closer to a LH351D as the datasheet and everything matches it very closely.
This week iâm going to build a Sofirn C8F with this LED and drive it as hard as possible (30T probably) and get a better tail reading.
Yeah. The die is quite a bit smaller than the one in the Luxeon V. It also has a smaller footprint, so canât scale as well due to thermal limitations.
Yea just wishful thinking. The output is great either way and iâm pretty sure this will be my goto LED when i dont care about CRI and want a 3535 LED.
I put a âwhite flatâ into a VG-10 style light.
Iâm using a 3A buck driver for now. I plan to upgrade to a ~4.5-5A regulated driver at some point.
I used some UV set resin to narrow down an XP centering ring, then a small triangular file to open it up enough for the emitter.
I think there is probably still some focusing work I can do, but the first guess turned out pretty well. I donât have decent beam shots. I can say that the diameter of hot-spot is just a little bigger (~10%) than that from a XP-L HI in my Convoy L2. At 3 amps, the output is lower, so the intensity is lower than the L2, but at higher current, they should be more comparable. Not bad for a light with a 23mm reflector.
I always seem to run into some new problem every time I mod something. This time I either corrupted or erased the firmware on a new driver without noticing. Build up my light, nothing. Redo all connections, check for shorts, check e-switch, the whole nine yards. Then I think, hmm let me go to a different version of Anduril just in case. Bingo. Re flashed and all works fine. I thought in the back of my mind it flashed âtoo quicklyâ the first time but ignored it.
Anyways, as promised. I put a 3x Luxeon V2 4000K 70CRI in my C8F 21700
21700 VTC6A - not quite topped off
0s 3,461 with 12.5-13A tail reading
21700 30T - just about fully topped off
0s 3,792
30s 3,019 (may have been throttling, not sure)
To put this into perspective I built a similar light with LH351D 4000K 90CRI and got 3,486 at 0s on a full 30T.
I couldnât take a picture side by side and make the tints appear true to life, not sure why but the Luxeon V2 does feel closer to the BBL than the LH351D in that there is less green. It also looks like there is more intensity in the hot spot.
I have a pile of 4000k XM-Lâs destined to replace the emitters in several older lights. First tried it on a crelant 7g5l2 that I hated, reflowed the LED successfully using a pizza pan on the stove with a thermal gun but couldât solder the leads with my 25 watt iron and ended up breaking leads. Later took a look at my broken rrt-3 jetbeam (burned out emitter) and with all of the space in there was tempted to give it a go. Reflowing the LEDâs didnât go so well, the uneven heat on the stove warped the mcpcb, and then again couldnât get the leads to solder without having contact with the reflector. Argh.
Bought a proper weller soldering station and all of the supplies mentioned by texas ace in his videos, flux, solder, etc.
Tried to have a go assembling a convoy s2 with driver and mcpcb on the pill, failed and ended up unsoldering the components of the driver trying to solder it to the brass pill. Got everything back in its correct places (7135âs) but when assembled no light.
Took the whole thing back apart, watched another of his videos that I wish Iâd had seen before I started, as it appears you need to heat up the pill before trying to solder it. I was getting cold solder joints, and getting it to solder made it hot enough to where things started coming apart.
So now have a temperure controlled electric griddle on its way, with a new (and much cheaper) driver, hope to have more luck and get my first assembly done but if i break it it will hurt less than the $17 driver i ruinedâŚ
Probably will pick up some solder projects from microcenter, need to work up my skills to where Iâll be comfortable replacing the leds on my tn30, tn31 maybe, tm11, and a few others.
Losing the rrt-3 really hurt because that was my first ârealâ flashlight back then and wasnât exactly inexpensiveâŚ
jimF, I feel for you. Iâve been soldering on and off since I was about 10. As an adult, Iâve gotten a lot better at it, but there are often times where it feels like Iâm soldering for the first time.
A decent iron and tips are one of the things that really helped me, so good that you have that on the way.
One of the things you can do with a decent iron is turn it up when soldering to things that soak away heat quickly, like a copper MCPCB mounted in a light. ~20°C can make the difference between a thick, gloppy mess and a nice clean joint. Turn it down when you donât need it that hot though, itâll prolong the life of the tip.
Speaking of the tip, the ritual of cleaning and re-tinning it as you work really helps, especially when you are running it extra hot.
Good solder is also a huge help.
Tinning contacts and wires before making the joint also helps a lot. For example, tinning a brass pill before soldering the driver to it, or tinning the pads (actually, in this case, I do more than tin it, I make a little blob) on a MCPCB before mounting it on the light.
Extra flux really helps with rework, especially of older joints, but I often add a little before soldering leads I just tinned to a star I just tinned.
Unless there is something really odd about it, a replacement MCPCB for your jetbeam shouldnât be too hard to arrange. Also, in general, DTP MCPCBs are pretty inexpensive. I rarely reuse old MCPCBs, and never if they are just non-DTP aluminum.
I put an Osram âWhite Flatâ in my brand-new Olight M2XâŚ
Now thatâs a thrower ! Still not as powerful as my M3XS Black Flat but it DOES throw and is really compact :
