I like the look of the FH1.
Is it MOLLE compatible?
I have a few flashlights that should fit nicely.
(Convoy S2+, S3 & S8, Haikelite SC26, Astolux S41, BLF A6, Skilhunt DS21 and some others)
And I can take half decent photos.
Yes, it is very nice and solid. I appreciate the buckle, sometimes more convenient than velcro which wears, but it is quite thick.
I bought two units of this exact same model several years ago with P60 Xeno flashlights. The holster model name is Xeno HD70, a bit expensive now.
Way better to protect the flashlight and easier to pull it out and put it back than with cheap holsters with elastic bands even if this one is much bigger
With flashlights head down, my Xeno HD70 ( = FH1 ? ) is perfect for a Xeno G5 (slight friction) and Sofirn SF36. A bit tight (more friction) for a SolarForce L2P with A001 head and too large for a Convoy S2+ (rattle).
SF L2P + A001 : long. 14.1 cm / larg. 3.6 cm
Xeno G5 : long. 13.8 cm / larg. 3.5 cm
Sofirn SF36 : long. 13.2 cm / larg. 3.2 cm
Convoy S2+ : long. 11.9 cm / larg. 3.4 cm
Wow, that's a nice photo. And thank you for your information. In fact there is a difference of fabric between Xeno and Weltool FH1. You will see when you have both of them. :)
You are already sending me a FH1 ( thankyou ) , if you don’t get the 5 responses you need for the FH3 ,I have a led lenser P7 it would fit & it looks much better than the lenser pouch , I would gladly take one to help you out
