Is my charger working?
This Rodee AD-108 charger is what I have been using for years for occasional charging duties for my 18650 cells. I only need to charge a couple cells a couple times a year.
https://www.dx.com/p/rodee-ad-108-lithium-battery-charger-for-18650-17670-14650-16340-5965#.W_AZSOJG2Hs
I left 2 cells in it overnight expecting they would be finished this morning, easily charging for 10 hours, but still had that red charging light showing this morning. I hooked it up to my Kill-A-Watt meter and see it is only pulling 0.07 amps. I swapped out the cells with a couple others and still the charger is only pulling out 0.07 amps from the wall.
Is it charging? I would expect it to pull more. My unit doesn’t have any specification printed on it to check.
Thanks
Read the reviews on the link you provided. “Strange Charger”
ok. seems like it is working then
Seams to be a slow charger, from what I read.
I’d check voltage of cell, then again after some time. See if there charging.
Sounds croaked, and not too hot to start with. You can get a decent Lii-202or 402 for a pittance at Bangood or Gearbest which would be a significant improvement, or you can go completely crazy, spend $20 and get an excellent analyzing charger. See HJK reviews. Table of tested chargers, comments?
Good pre-Black Friday sale going on at IMR. IMRBatteries.com | Rechargeable Lithium-ion 18650 Batteries, Chargers, and More
Just about any of the Xtars are excellent.
