It’s good to see you pushing through with the build, despite the sad news.
I don’t think I’m up to making any more videos. Even I have to admit they’re not that interesting.
I have a tail now … If you look back at the very first pic of all the parts you’ll see the bar stock has knurling at each end. This is one of those ends. I nearly ran out of stock I seem to have produced a fair amount of waste.
Some of the threads look dirty because I used some metal polish to work the threads and smooth out the gritty feel. There’s also a few things to clean up like cutting the tail to exact size and a recess for the o-ring etc… Once it’s all cleaned up then I can start assembling and soldering. Nearly there
Very nice!
Looks terrific pp. Love the style.
Looking nice!!
You should have seen the amount of wood dust and chips I produced making all the small pieces for my lantern.
I got copper fever
Wonder what the scrap value is? I save copper cutoffs from all the solar system wiring I do. If I strip the insulation the last batch brought almost $2.50 a pound.
Hmm… Aluminium, copper and wood. Sounds like something Moose would use in one build
That Moose guy sounds like an old fool.
Mostly done with this light now. Lathe work is all done. Driver has a little heatsink plaster to hold it in place. Led is soldered. Tail is finished.
It turned out longer than I was expecting but at least it can take protected cells as well as tail stand. The UI of this driver (FX-35) is not so good (H-L-S), if it was just H-L I would be happy with that.
Quick beam shot with the phone. Sorry I didn’t notice the reflection of light in the glass door until I looked on the pc. It has a smaller spill and hotspot than the E14 and AT40
E14
AT40
The only thing left is a pocket clip. I found one on hand but I’m not sure if this one will be strong enough for a light this size.
Good to see your torch finished pp. Congratulations.
With the clip you used I double up on them as they bend very easily. Two fixes that problem.
Good to see another build coming to fruition
Congrats on finishing the light
That’s a great idea. I never would have thought of that. Especially since this is the only one I have on hand :person_facepalming:
I’ll order some more, if it gets here on time great, if not then I think it still qualifies as finished.
Thanks guys
Looks complete to me. Great!
Yes, another sadly missed member. RBD was very clever and skilful.
Ah yes, another master builder. I am but a grasshopper…
well done pp. soz about your pooch
