Same or even better in throw than white flat 1mm with more lumens and wide screen tv die projection
Edit: Why I said it may be better than white flat 1mm? Because I can not measure that with mine fet driver configuration since it pulls a lot of current and thus generates a lot of heat which could have influence on performance.
Some regulated configuration in multi cell lights with better cooling potential will show real nature of this emitter.
If I would have to place a bet who would win between 1mm or 2mm White Flat I would place a bet on this new White Flat 2 mm.
Since it is not suitable for my fet driver single 18650 light configuration I am really looking forward for real builds BLF members will bring with this new White Flat 2mm.
Comparison pic between new White Flat 2mm(sorry I really canāt remember full name) and XP-G2 S4 2B DD
Itās the same LED technology but with just a bigger die.
Since the physical size is the same it will always perform worse than the smaller emitter because it has a larger die area and therefore requires more wattage to achieve the same cd/mm^2
More watts and same cooling pad area = worse performance as you increase the current.
The boost HX aka CULPM1.TG which has a physically larger size has the chance to perform better.
The datasheet says the die is 1.59:1.25, (1.272:1) which is 12.72:10. Much closer to 4:3 regular tv aspect ratio (1.33:1) than 16:9 widescreen. (1.77:1)
Yes that happens in mine host. But for couple of seconds mine tested White flat 2mm at 9-10A has same or slightly better performance as tested White flat 1mm driven at 5.8A.
There is still that 10% of lux variations that can happen between emitters so if you got worse 1mm and better 2mm wf could actually win imho.
So this is obviously emitter for someone like you Enderman. Better cooling methods etcā¦ Really donāt know why you donāt have wish to try it. You will have to wait for a long time until HX appears
The transient temperature response will be completely different for both LEDs.
The reason the 1mm is getting worse performance is probably because 5.8A is past the peak of the output curve, while the 2mm is still not at its peak at 9-10A.
The proper way to compare them is to put them on a proper CPU heatsink, make current-output curves to find the peak of the curve (at steady state obviously, not only after a few seconds), and then compare the peak luminance at those peaks.
Once the post strike in canada finished I will immediately buy a few CSLPM1.TGs to test and Iāll show you what I mean.
I have no idea how this project product compares to crystals, sintered phosphor, etc. PDF claims it has taken 445nm laser powers up to 30W/mm2 on metal and on glass substrates. Has 96CRI at 5500K tint option. Seems like it would be handy for replacing damage phosphor layers on flip chip LEDās.
The_Driver, could you please add Lumileds Luxeon CZ to the table?
It seems to have the lowest thermal resistance of any 1 mmĀ² LEDs that Iāve seen. Though Iām not sure if they mean real or electrical resistance, the datasheet is unclear about that. If thatās electrical - itās still very good but no longer special.
Though then thereās a tiny thermal pad which will spoil performance for sure. If indium solder really brings actual improvements, these are going to be relatively high with this LED.
ADDED: This Luxeon C document (not CZ) makes me believe they mean electrical resistance. Iām not really surprisedā¦.still, resistance is good and I think this LED should easily get intense enough to deserve a its place in the table on the first page.
