Yes that happens in mine host. But for couple of seconds mine tested White flat 2mm at 9-10A has same or slightly better performance as tested White flat 1mm driven at 5.8A.
There is still that 10% of lux variations that can happen between emitters so if you got worse 1mm and better 2mm wf could actually win imho.
So this is obviously emitter for someone like you Enderman. Better cooling methods etc… Really don’t know why you don’t have wish to try it. You will have to wait for a long time until HX appears
The transient temperature response will be completely different for both LEDs.
The reason the 1mm is getting worse performance is probably because 5.8A is past the peak of the output curve, while the 2mm is still not at its peak at 9-10A.
The proper way to compare them is to put them on a proper CPU heatsink, make current-output curves to find the peak of the curve (at steady state obviously, not only after a few seconds), and then compare the peak luminance at those peaks.
Once the post strike in canada finished I will immediately buy a few CSLPM1.TGs to test and I’ll show you what I mean.
I have no idea how this project product compares to crystals, sintered phosphor, etc. PDF claims it has taken 445nm laser powers up to 30W/mm2 on metal and on glass substrates. Has 96CRI at 5500K tint option. Seems like it would be handy for replacing damage phosphor layers on flip chip LED’s.
The_Driver, could you please add Lumileds Luxeon CZ to the table?
It seems to have the lowest thermal resistance of any 1 mm² LEDs that I’ve seen. Though I’m not sure if they mean real or electrical resistance, the datasheet is unclear about that. If that’s electrical - it’s still very good but no longer special.
Though then there’s a tiny thermal pad which will spoil performance for sure. If indium solder really brings actual improvements, these are going to be relatively high with this LED.
ADDED: This Luxeon C document (not CZ) makes me believe they mean electrical resistance. I’m not really surprised….still, resistance is good and I think this LED should easily get intense enough to deserve a its place in the table on the first page.
