Fireflies ROT66 Flashlight
973 posts / 0 new
iamlucky13
Last seen: 7 hours 4 min ago
Thanks. Google photos can be a finicky host. I didn’t know the GT Mini diffuser could be bought separately, so I wanted to make sure my mod was visible. I wouldn’t say it is better than a cone style diffuser like the GT Mini version, but it is an option.
There was nothing particularly difficult about it as long as you have a reasonable way of cutting the plastic, such as a hacksaw or Dremel.
I cut mine a bit small, checked the fit, did some additional trimming with my Dremel until it almost fit, and then finished with about 10 minutes of sanding by hand. This gave me a snug fit so it doesn’t fall off when I move the light.
I wasn’t sure if I would be able to get a snug fit, but figured since the head of the ROT66 is wider than the bezel, the worst case would be the diffuser sits a little lower and could be knocked off accidentally.
Kingjohn
Kingjohn's picture
ToyKeeper wrote:
d_t_a wrote:
When the D4S aux-LEDs are configured to “High” mode, they’re nearly as bright as the main light on the lowest “Moon” mode (maybe 1 lumen or a bit less)? Certainly enough to walk around a dark room with.
I wonder how the ROT66’s Aux-LEDs look like (does it also have a Low and a High mode?)
The D4S aux LEDs go from about 30 uA to 1000 uA, on low and high. This is controlled by the firmware.
The ROT66 aux LEDs go from about 200 uA to 600 uA, ish. This is controlled by a screwdriver.
Does this screwdriver come with the rot66 ?
Our in other words: can this screw be accessed in a glued light? ( Without disassembling it?)
And if I was reading correctly between the lines, TK prefers more to turn the virtual screw Wink
JasonWW
JasonWW's picture
Last seen: 10 hours 1 min ago
You have to unscrew the bezel to get to the leds. So you need to order an unglued light.
ToyKeeper
ToyKeeper's picture
Last seen: 2 hours 40 min ago
The potentiometers are a good way to control the brightness of the aux LEDs, but it’d be nice if it could be turned down more, and if it could also do high and low modes like the simpler aux LED boards do. There’s also the issue of glue making the potentiometers inaccessible. And the issue of the aux LEDs interfering with firmware flashing, so either the user must lose the abilty to turn them off, or lose the ability to reflash without soldering.
So I’d make a few changes:
  • Adjust the pots and/or resistors to extend the range downward.
  • Connect the aux LEDs to a MCU pin so the user can turn it off via button presses.
  • Eliminate the circuitry used to run the aux LEDs at a constant brightness, or at least modify it so it doesn’t interfere with flashing and the “low” mode.
  • Adjust the aux board’s voltage response so it changes color at the correct voltages again (because powering it via MCU changes the voltage level it receives).
It could also be nice to rearrange things a bit so the pots would be on the spring side of the main driver, so the user could adjust it by removing the battery tube instead of the bezel and optics.
On a related note, I’d also change the way the button LEDs work. Instead of 2 which are always on and 2 which are controlled by the MCU, I’d make all 4 MCU-controlled. Because I want them to be off sometimes.
i42dk
i42dk's picture
Last seen: 2 weeks 5 days ago
Agreed, I wish the AUX leds could go lower.
(picture is slightly overexposed, IRL they are a little dimmer)
Heres my ROT66, turnt all the way down, compared to two D4S’es at low AUX setting.
The D4S have the faint trit glow, the ROT66 still lights up a dark room.
ToyKeeper
ToyKeeper's picture
I moved the button and aux LED wires to the same pin as the MCU-controlled button LEDs. This is for the same reason why I don’t use tritium vials any more — they’re pretty, but I want to be able to turn them off. Sometimes I don’t want a bright shining beacon announcing my location to the world; sometimes I’d rather go dark and not be seen.
goshdogit
goshdogit's picture
Last seen: 7 hours 41 min ago
Good idea. I’d like to do this to my non-glued ROT66.
Can you elaborate? Are there any pitfalls or side-effects?
ToyKeeper
ToyKeeper's picture
Basically, move the permanent switch LED wire to the indicator LED pad. And move the aux LED board wire to the inner side of the switch LED resistor. The downside is, it makes reflashing not work without unsoldering the aux LED wire. And the aux LED board turns red about 0.25V higher than usual.
goshdogit
goshdogit's picture
Thanks, TK! Thumbs Up
I plan to do as you describe when I open the ROT66 again to change the aux emitters and flash my slightly tweaked version of Andúril.
Newlumen
Newlumen's picture
I rarely read manual.. while I was using my rot66, aux turn off and red led indicators appear.. just discovered all three cells were around 3.29v.
Very nice feature. Thanks TK.
BAF0-D65-F-D3-E0-42-A9-8011-D9411890-A262
JasonWW
JasonWW's picture
Lexel designed the battery warning function.
twisted raven
Last seen: 7 hours 35 min ago
Yeah it’s a great touch. I haven’t seen a low battery indicator quite a nice as this one.
ToyKeeper
ToyKeeper's picture
You’re welcome, but I didn’t do that. Silly
Lexel made the aux LED board do its voltage indicator thing.
komeko
komeko's picture
Last seen: 6 months 3 weeks ago
I have waited for two months for ROT66 and it will not happen, because even the statuses do not change. Firefiles, a few days ago, promised to send again and … silence, no response. Bad start. I guess I will have to write to paypal. Sad
Click on:        ANSI WHITE
Click on:        MY COLLECTION
Click on:        Q8, D4, D4S, D18, K1, FW3A, SDmini, Mini AAA, TIP, M43, H1, H03, TC20, TN40S, TN42, V6, H600Fw, SC600w, SC64w
cclight
Last seen: 2 weeks 1 day ago
They’re probably taken by the E-07 launch.
My rot66 arrived this week but defective, unusable. Probably some bad contact inside the head but I bought it glued. I wrote to Jack, let’s see how after-sales works for me Sad
nokoff
nokoff's picture
Last seen: 11 months 1 week ago
if you don’t get a response in a day or two try a PM on here instead. I think it works better than the contact option on his website; I don’t think that works. I wish I could help; he needs a daily presence on here to help coordinate. He does resolve every issue to each person’s satisfaction but sometimes it takes a minute.
Nokoff..still Made in China 山寨主義
Petr J.
Petr J.'s picture
Last seen: 8 months 1 week ago
My complaints have turned out well. I got new. Waiting for it was not pleasant. Faulty lamps are a great deal of how much they sold. In addition, it is always possible for a newly dispatched flashlight to be lost, it will have to pay VAT and customs fees (in the EU). Nevertheless, I believe FF for now and buy E07.
SKV89
Last seen: 4 days 4 hours ago
I feel your frustration because I’ve been there with my Enogear AA experience, which took months but ended up a satisfactory experience. I bought 4 ROT66 from him at different times. The first ROT66 I bought on day 1 it was announced, before the group buy started. That one took I think about 3 months. It was shipped out earliest and I had tracking number but I guess it might have been stuck at customs. The other ones came between 2weeks to a month. I know it’s hard to wait, but have a little bit more patience. You can PM Jack here. He takes weeks to respond to emails but he responds to PMs in a day or two.
gregor
gregor's picture
Last seen: 14 hours 6 min ago
Yesterday I placed an order on: http://www.ff-light.com
I did not get confirmation email which is very strange. Also no registration email.
Till now they did not send me FL. Do you know how quickly they normaly send FL?
Thank you
Kind regards
nokoff
nokoff's picture
Thank you
Kind regards
When I see FL I can only think of Florida, which isn’t in Romania, so it must mean flashlight unless you moved. Out of all the words to abbreviate Silly
iamlucky13
Thank you
Kind regards
I didn’t receive confirmation when I ordered mine until several days after placing the order. It is shipped from China by a low cost method, so expect to take several weeks to possible even a month.
Random Dan
Last seen: 5 months 3 days ago
My ROT66 continues to be weird. I was using it over the weekend and so I left batteries in it. Sure enough last night while sitting untouched on a shelf it turned itself on again. Now I can’t get it to work at all. When I first put batteries in it turns on and ramps up to max, stays there for a few seconds, then blinks and turns off. It is unresponsive to any button input, including trying a four-click to lock/unlock.
Anybody know what’s going on? Should I try to return or warranty the light? I like the tint of the Nichias but I have a hard time ever trusting this light to be useful when I need it.
aginthelaw
aginthelaw's picture
Last seen: 17 hours 29 min ago
Mine flashes all by itself now, coming on briefly or blinking, main and auxiliary LEDs. The batteries were at 4v when this happened. Jacky is sending out a new board
never fear shadows…it means a light shines nearby
Tom E
Tom E's picture
Last seen: 17 hours 13 min ago
Random Dan wrote:
My ROT66 continues to be weird. I was using it over the weekend and so I left batteries in it. Sure enough last night while sitting untouched on a shelf it turned itself on again. Now I can't get it to work at all. When I first put batteries in it turns on and ramps up to max, stays there for a few seconds, then blinks and turns off. It is unresponsive to any button input, including trying a four-click to lock/unlock. Anybody know what's going on? Should I try to return or warranty the light? I like the tint of the Nichias but I have a hard time ever trusting this light to be useful when I need it.
Boy the e-switch sure sounds like the culprit . S%$#@ happens, and sounds like it happened right in that switch. Might be some cleaning agent or flux, or something gunked up, or maybe the wiring/PCB/etc. I think the ramping up to shutting down is by design. Sounds like something I did (and/or TK) to handle the case of a stuck switch - think I made my timeout 20 seconds, where it would go into lock-out mode if that ever occurred. This is to prevent the light from being on if the switch was jammed in the ON position, like in a bag or pocket.
Tom E
Tom E's picture
This sounds like a power flicker/outage, like you see sometimes when tightening up the tailcap where intermittent power contact is occurring.
Random Dan
Tom E wrote:
Random Dan wrote:
My ROT66 continues to be weird. I was using it over the weekend and so I left batteries in it. Sure enough last night while sitting untouched on a shelf it turned itself on again. Now I can’t get it to work at all. When I first put batteries in it turns on and ramps up to max, stays there for a few seconds, then blinks and turns off. It is unresponsive to any button input, including trying a four-click to lock/unlock. Anybody know what’s going on? Should I try to return or warranty the light? I like the tint of the Nichias but I have a hard time ever trusting this light to be useful when I need it.
Boy the e-switch sure sounds like the culprit . S%$#@ happens, and sounds like it happened right in that switch. Might be some cleaning agent or flux, or something gunked up, or maybe the wiring/PCB/etc. I think the ramping up to shutting down is by design. Sounds like something I did (and/or TK) to handle the case of a stuck switch – think I made my timeout 20 seconds, where it would go into lock-out mode if that ever occurred. This is to prevent the light from being on if the switch was jammed in the ON position, like in a bag or pocket.
Thanks for your input. I just ran a test again and I noticed that the switch always has 2 lights on, never 4. This would seem to confirm your theory that the switch is stuck on.
Tom E
Tom E's picture
I haven't looked carefully at the ROT66 but so many of these lights have very tight tolerances on the switch wiring pads. So it may look good from a visual inspection, may even work fine at the factory, then after shipping, ever so slight shifting may cause a short. Or again, some contaminating agent after time gets more conductive.. So many things can happen.
There's been issues with e-switches, but just by design really, really prefer them. Over time, mech switches are prone to more likely failures, plus a lot of amps going thru thin metal and small contact points internally in the switch is not a good thing - e-switches don't have high power. The only somewhat superior mech switch is FET based, so high amps is not going through the actual switch, but these are more pricey, probably bigger, and I just don't see these offered as replacements anywhere.
ToyKeeper
ToyKeeper's picture
Random Dan, that definitely sounds like a problem with the e-switch. It sounds like it’s shorted to make it think it’s always being pressed. It could probably be opened up and fixed, if it’s not glued, but that’ll definitely require some soldering.
Random Dan
Thanks for the troubleshooting help Tom and Toykeeper.
Since moving I no longer have access to tools, so I will probably try to send the light back to Fireflies once I return from holiday travels.
onieanjal
Last seen: 2 years 3 months ago
Is there a way to turn off the blue aux LEDs? It doesn’t look like it’s covered in the basic UI diagram but I understand there are lots of ‘varsity’ features buried in there. Thanks!
