CRX Rotary - 6th Annual BLF/ Old Lumens Contest Winner
Had to catch up on a whole lot of story, amazing work, so many good ideas, so well exercised, so many patient hours of work. :+1:
I’ve no idea how you make such intricate pieces. One day you will make a video. :slight_smile:
I’m beginning to think he has some Elves cutting and filing over there—definitely some Magic Dust— :smiley:
Actual picture of CRX :
Now you know his secret :smiley:
very funny!!!
Jerks! :))
Now a little something for your insolence... ;)
25mm x 22mm grade2 titanium tube arrived today :THUMBS-UP:
I think this is much better than the brass, a lot lighter too.
Drilled & filed out slots for 6mm x 1.5mm tritium vials.
Roughly showing how the light will look with tritium mode indicators
:+1:
Maaan that’s some great skills and awesome ideas !
I love it !
What did you use to make the slots?
The trits are 6mm x 1.5mm and I only have 2mm or 0.9mm drill bits, (the thought only just occurred to me) so I used the .9mm bits to drill a series of vertical holes in wobbly lines :smiley: , then kinda drilled in from the sides of the holes at an angle moving the drill bits around to break the holes into one another then a diamond cone shaped dremmel bit to enlarge the slots so I could get the small rectangle diamond file in there, still needs tidied up & nothing is fixed in place.
Very excited though, first light I’ve made with titanium :slight_smile:
You can stop making it better now…. anytime now… It’s already really really awesome.
With all the awesome things you’ve made over the years I’m surprised you haven’t played with titanium yet. This first dabble with it is looking very nice already.
Just a couple more tricks, promise :innocent:
Thanks mate, yeah it is surprising also considering it is my favorite metal. I just never got round to it though I think we can expect more of it now :wink:
Tedious and time consuming. Orsm work. :beer:
Yeah, especially when the chuck is too big to even hold the bits...
So a little tip for this is I cut three pieces of 2.5mm copper wire and use them to brace the 0.9mm bit centre in the drill chuck.
Can be a bit fidgety to get them in place but it works ;)
Some more work on the casings today.
Cut, shaped & slotted a 3.5mm machine screw to make a grub screw for fixing the copper pill in place.
Drilled & tapped a 3.5mm hole through the inner cores into to the copper pill, installed grub screw and levelled off.
Drilled & filed another tritium slot into the front section titanium casing.
Marked final positions of the various contact points on the outside of the copper core in red & blue ink.
The thick red line on the very end rotating switch piece shows where the internal sprung brass contact lines up.
The thick blue line on the body shows where the flashlight will be in the off position.
The thick red line on the main body shows where the direct drive/ charging mode connection is.
The way these indicators will work is, when the two green tritium vials are lined up on the titanium outer shell, the light is in the off position.
When the green indicator on the rotary tail section is turned to line up with the red indicator in the body section , the light is in direct drive mode, or in charging mode if the head section is then disconnected and the charger port is exposed.
Other than that the tritium indicators let me know where the switch is positioned.
Nothing is fixed in place yet, still got some tidying up to do and fit LED & reflector.
Tritium vials installed in outer casing with UV setting glue & copper bezels in place.
I am running out of superlatives. :wink:
Good trick with the “too small” drill bit
Holy crap! You have outdone yourself again. That is beautiful!!!
Getting there. :wink: :+1:
Hum…I guess you won’t resist to make a CRX Rotary “family” (as you’ve done with the Stratis Lumina) inside or outside the constest, will you? :smiling_imp:
