Flashing driver using Arduino
Hi all,
I am new to the world of flashing driver.
My first attempt was flashing a ToyKeeper BLF A6 firmware on BLF A6 A17DD-L FET + 1 driver.
Since I don't yet have the proper hardwear, I am using Arduino board to flash the driver connected to the MCU using soldered wires.
While connecting to the Arduino everything works perfectly and also when I only use the arduino as power supply (only GND and 5V connected).
But when I disconnect everything and try to use a 18650 as a power source, nothing works - the LED is not turn on.
Voltage between terminal is 4v.
Do you have any advices?
Thanks
I hope you connected positive and negative correctly. Check the voltage at the Attiny then - perhaps the schottky diode is defect. You might also have left a solder bridge somewhere. Check all pins against ther neighbors for shorts.
Connection is correct
It is 4v, shouldn't it be same as terminals?
What should I check?
No shorts, pin 3 and 4, are shortly beeps and also 7 and 8 but it is the same with my other (new) driver
The voltage at the Attiny should be about 0.3 Volts less than at the cell due to the diode. You might have disconnected a pin of the Attiny when you unsoldered the wires. Or it might be fried but they are pretty tough.
Difficult to say what more could be damaged, perhaps if you post a picture.
Do you flash right fuse?
Thanks Mike,
I think it might be the diode.
I didn't desolderd the wires from the MCU, I keep them soldered in order to continue practicing flashing code. I only disconnect the wires from the Arduino board when connecting to battery.
I didn't notice the diode is in series to MCU, so when connecting to Arduino 5v I connected id directly to pin 8
Actually I don't know, the code sayes:
FUSES
 *      I use these fuse settings
 *      Low:  0x75  (4.8MHz CPU without 8x divider, 9.4kHz phase-correct PWM or 18.75kHz fast-PWM)
 *      High: 0xfd  (to enable brownout detection)
But I can't find where it is burned to the MCU
http://bazaar.launchpad.net/~toykeeper/flashlight-firmware/trunk/view/head:/ToyKeeper/blf-a6/blf-a6.c
After some reading in the Attiny Datasheet and other sources about the fuse, mrheosuper was correct and the problem was in the fuse settings.
In case, someone will have the same problem in the future:
The tutorials on the web for flashing MCU using Arduino include burning bootloader. During the burning of bootloader the fuse is also burned.
In order to use the same fuse settings as toykeeper set the BOD to 1.8v and clock to 4.8 MHz internal (under tools menu at the Arduino IDE).
Thanks mrheosuper for the Tip.
