As it is just a suggestion, I thought, I just go here from the SP70 topic - because this is not related to the current SP70 specification set (yet).
I would like to +1 for Satan@103TFS, as if Sofirn makes SMO reflector for SP70, there should be definitely XHP35 HI options (e.g. a set of 5700K, 4500K, 3500K CCT) - and there should be at least one high CRI option (e.g. 4500K 80 or 90CRI).
And for the ‘C8’-ish flashlighs, let us ‘gauge’ the single cell compact throwers (now all with 21700 battery tube), so there could be C11 with a net reflector diameter of 55 mm (as C8 is ~40 mm), and there could be a C14 with 70mm diameter for extremists. Also, I could imagine a C14F as well :smiling_imp:
For me it would be nice flashlight with a SP70 head and 4 xp-l hi and a tube for one 26650 with a fet driver. Such tm16gt only more compact with a better price and probably stronger
My wish would be for Sofirn to stop gluing their lights together, so it would make life easier for users to perform their own mods in cases where it’s not feasible for Sofirn to produce alternative versions for sale.
Would love to see a larger head single emitter version of the 21700 C8F with Oslon KW CSLPM1.TG, KW CSPLM1.TG, or KW CULPM1.TG and USB C recharge. Sofirn should pay attention to how extremely popular the Emisar D1S and GT Mini is. This single emitter C8F with easily 400+kcd will be the farthest throwing production flashlight in existence for its size category and will sell very well.
It only takes an appropriate centering ring (Hoop is gonna make some of them for several flashlights soon…I can’t wait to get them) and a current-limited driver that makes sure the LED will not get more than 4.5 - 5.5 amps (e.g. Neven’s LD-A4 driver). :heart_eyes:
Hold on people, Sofirn takes things slowly ,at least that’s what it seems. I believe,the right thing for sofirn to asure sales is to check out the interest of the details on3 the3 customers ,like : wich one3 would you choose first : orange peel or3 smooth etc.,not to many makers do such thing,and in a tight market that so many manufacture nice budget flashlights,might be a good option to start in blf,as so many other reviews would come out for a good quality flashlight.
USB type c charger included : yes or not necesarily?
You will only gain about 200 lumen on turbo. Less at lower levels. Plus you will lose throw distance. I don’t think it’s worth the change. It’s probably better to keep the 50.2 and just change the color temp.
Would it make sense to collect the ideas and summarize/list them somehow (e.g. spread sheet) in the OP, so Barry, Tracy, Adelina or anyone else at Sofirn would have a convenient overview of our wishes?
Good ideas except I like the UI on the C8F 21700 much better than on the C8F 18650. Click and hold to turn off is just not intuitive.
I really don’t like the timed step downs that Sofirn is using on all of their recent flashlights especially considering they are using active temperature control now.
Sofirn needs more finning on their flashlights. Sofirn flashlights have too little fins for heat shedding. Need more surface to sustain higher outputs. Redesign the C8F with more fins!
Sofirn Q8 with 4x XHP50.2 makes more sense. For 3x XHP70.2, there already exist the Haikelite MT03 TA with excellent UI, output, and is one of the best flashlight host in the size range (heavy thermal mass and abundant fins).
What lag in Sofirn line up are real thrower the best they have is C8T with +/-100 KCD so I suggest
- Single 21700 with 55-60 mm. head + XPL Hi for +180 KCD or
- Single 26650 with 65-70 mm. head + XHP35 for +250 KCD/+2000 L
- SP70 SMO + XHP35 for +600 KCD/+2300 L
With the 2 switch (forward tail and light side SW) as C8F 21700 but add locator function in the side SW, omit USB charge to keep the cost low and risk of leak.
I like the idea of a smaller-sized 18650 light. Something along the lines of a Zebralight or Emisar D4 would be great. Doesn’t have to be a pocket rocket either.
A higher-powered Q8 (as mentioned above) would be great too. a quad of XHP50.2 emitters in NW would be fantastic! Lots of battery life, reasonable heat-shedding capability and a great deal of power! I recall someone mentioning this mod early on in the enormous Q8 thread and it stuck with me all this time. I wonder how difficult it would be to have a small run of a light like this?
And a new driver, and a new battery tube, and limited power/cost, etc.
@Barry, the one thing you could do is using tint mixing.
Using emitters like the LH351D 3000k and 5000k, like in the BLF lantern!, you could pull off a very very nice beam, that even BLF members will love, with very good color rendition.
