Did you actually measure 900 lumens on turbo? For me at 30 seconds, the output drops down below 500 lumens, maybe 600 at best at turn on. When I fully charge the stock cell, keeping it on turbo for a few seconds, the beam tint starts turning blue. This happened on 2 of these lights bought from different sources - Amazon and Banggood. Others are reporting the same problem.
In a review, when you say "TURBO 900 lumens", I expect that's what you measured. If you didn't, you should just say "TURBO mode". I like the light, overall quality, UI features, though the up->down, down-> up sequence of modes is annoying.
The head is removable from the battery tube, as well as the bezel being removable, but some units appear to be very tight or possible glued.
To me, this light is greatly over spec'd for turbo output and has a design flaw in having way too high amps for the LED they chose to use. If the beam tint turns blue, the LED is being very stressed, could suffer permanent damage, or greatly reduce it's lifetime.
I have heard this very same problem with a friend of mine in another group on FB, he said he heard something break and then the light tint turned blue after a few minutes on TURBO. And no, I haven’t measured as I don’t have a lux meter yet. I just put it as the advertised lumen count. Thank you for your input, will do that next time
On my 18650s, on turbo on a fully-charged cell (even the cell that came with the light), the output would turn blue and dim down to maybe 100 lumens in less than 5 seconds. After further testing I determined that this only happened with some cells. Some older higher resistance ICR cells did not have this problem. I emitter swapped mine to XPL HI and the problem went away. Now it works on any cell with zero tint shift.
Bottom line: yes, the emitter they chose just doesn’t tolerate the current. They should have used a different emitter.
That said, apart from this easily fixed LED issue, I quite like the light. It’s extremely short for a light with a tailcap button and has an unusual tail-cap mounted driver. The UI is ok, but could be better. I don’t like the long-press for off in illumination mode.
This light would be a “must buy” winner if Folomov made a couple simple changes:
change the emitter to something that can take the current. XPL or XPL HI work fine.
change the UI in non-tactical mode to something like Olight with single-click on-off and shortcuts to moon and max.
Overall I’m impressed with Folomov’s efforts. They’re a relatively new manufacturer, but they’ve come out with a number of innovative original designs recently. The 18650s is an excellent improvement over some of their prior lights, but isn’t quite where it needs to be yet.
I have to say the tint colors are all over the place. As others have said, turbo turns a whitish blue. Every tint below turbo seems ok. Also this thing gets hot fast. I do like the light. I will like it better with an xpl of some sort, just have not decided which emmiter to use yet. May even try an SST-40, once I figure out how to change the LED on this mcpcb.
Changing the emitter isn’t too hard, but is a bit tougher than a standard star.
The bezel is unglued and the star is screwed on. There is just one leadwire to desolder when removing the star.
The star itself contains:
The emitter (XP footprint)
Two resistors
A post on the back of the star that serves as positive contact to the battery.
You can’t just put the star on a hotplate and heat it up. Doing so would cause the post on the back to fall off.
I used a small table vise rotated so the jaws were parallel to the table. I used the vice to grip the post, not the star. The star itself sat on the upper edges of the vise’s jaws.
I heated up the LED with a hot air reflow station. A soldering iron touched to the edge of the copper star would also work, but would be more difficult as the star would be more likely to move around when the solder melts.
Once the solder melted, I used tweezers to remove the old LED and insert a new one.
The entire star was loose at this point since the solder holding the post to the LED had also melted. I gently pushed the star back into the correct position using toothpicks and tweezers.
Let it cool enough for the solder to solidify and you’re done.
SST-40 uses an XML footprint I think. As such, it wouldn’t fit on the stock star. Since the star has resistors on it, modifying an XML star to work in this light would be quite difficult and probably not worth the effort.
If you wanna use a luminus led it’ll have to be an SST-20 (nothing wrong with that choice at all though) as it’s their only XP footprint led.
Personally, unless you need that bit extra throw I like the LH351D > SST-20 but I think most people who have used both would say the opposite (I mentioned it cause it’s another XP footprint option what would fit on the stock mcpcb)
Mine failed after 5 months. Contacted Folmov and they are unable to help with replacement parts. Even attempting to send it in for warranty which they did not offer would cost too much. I really like this light for EDC but it will not be replaced because of the unique assembly of this light. In other words if the driver fails like mine did it is not replaceable because it is a part of the tail switch. Guess I can put a regular tail switch in it and just run it at 100% with just an off and on. Something to think about when purchasing this light. Purchase date was 11-27-2018.
My unit luckily still works, I use it as my bike light (with LH351D 4000K 90CRI) and I really like it like that. So I hope that my driver keeps working
I see. Well I will see if I can find one someplace else. I have a few of the original ones. One has a LH351D in it and the other has a SST-20 in it. Mine have been rock solid so far. Would love to have one of the 219D 5000K versions.
