Cyan makes a great moonlight.
Thank you Texas Toasted.
I´m shure it is very good, but i´m one of them that hate blue leds, in car stereos and everywhere.
I´m an old tech radionerd från 1958, and really prefer the amber and orange (my favorite colour)
The green leds looks cool in a green flashlight, so it will be green or the amber. Have too Google.
Or wait for more reply´s here :)
I can see the amber looking great in the green light, the green and gold of legend.
Welcome to insanity grand central, be forewarned that flashaholism is an addiction that gobbles up plastic and all the cash in your wallet at amazing speeds!
If you don’t like blue LED’s, then stay at 5000K or below. By 5700K the light is a bluish-white in appearance and above 6000K it’s very very noticeable. Many here like below 4000K, but that will be entirely up to you of course. You might find the lower Kelvin temperatures easier on your eyes.
If you can get Anduril flashed to your D4S it is easy to set the ceiling in Anduril so you can avoid heat issues with a simple lowered ceiling in the ramp. A double click to Turbo easily allows full use of the light when needed. Anduril also allows more complete thermal control through the firmware. AND it adds a candlelight mode and lightning mode that you would love to use, especially if you go with a warmer white tint to begin with. Candlelight flickers like a candle, you can set the brightness level easily and you can also set a 30 minute timer to turn it off, or double it to an hour… pretty neat having an electric candle…
Thank you DB Custom.
That was the information needed to finish my order, also mailed Hank about firmwares.
I have to solve that later on, i know how to soldering but at this time not how to update it.
Will have to search BLF for that, but i´m shure that i will try other firmwares 2018/2019
Crazy spending: I know exactly, have done the same with "needed" vapestuff since 2015
Here: www.vapeforum.se
MRsDNF wrote this 10/24/2018 - 17:12 @BLF
"Budget light hobby proudly sponsored by my Mastercard and unknowingly paid for by a hard working wife"
I really like that:)
Order now completed: Emisar D4S 26650 High Power LED Flashlight
- Magnet in the tailcap - Yes
- Color - Green (smooth surface)
- Aux LED - Amber
- Led & Tint - Neutral White - XP-L HD V6 3D, 5000K
- Battery - 1 * LiitoKala 5000mAh 26650 cell
Greetings. (May Good bless me and my wallet)
Happy to have been able to help. You’re going to love your new flashlight, it’s an awesome smallish handful…
I know you’re new here so please just remember, ToyKeeper is the light of this forum, always look to her and you’ll never go wrong. That’s the pure and simple of it, right there.
Indeed! So Eloquently put my good man! :+1:
I bought this light several months ago, and it seemed that I had pretty much found the Holy Grail of flashlights (at least for my main purpose, daily dog walks).
Unfortunately it started flickering pretty badly about a week or two ago - mainly just after turning it on, or after changing the brightness level. There is also considerable stuttering when I try ramping. Sometimes it won’t ramp at all, or it will just jump from one level to the other instead of ramping smoothly, and it will also flicker on those occasions. It seems to be getting worse, and I am worried that it will soon become unusable.
Is there any remedy for this? Apologies if this has been asked before, as I have not got the time to read through all the comments on this post.
Flickering is almost always a ground issue. Make sure any retaining rings are snugged down and that all contacts are clean.
There is a known bug with the switch in firmware when the presses have bouncing or something simmilar.
It may sound strange, but is there a possibility, that you do not press the button “properly”? For example, the bug mentioned before can only be reproduced by hand by pushing the button “strange” e.g. from an angle and very soft.
In that case, the light registers multiple button presses where it triggers a different action than expected.
Just FYI, but cyan is not blue, although between most cameras’ poor white balance settings and possibly your computer/phone monitor’s color profile miscalibration, it may appear blueish in the photos.
> flickering
Besides making sure everything that should be tight is tight and all the threads are clean, consider putting a dab of conductive gel on the theads and on the tip and base of the battery.
Sometimes the springs may be making intermittent contact if the metal was cut at an angle, so make sure that contact is smooth and meets the battery at a broad flat position, not at a knife edge or pinpoint.
Cyan is halfway between green and blue on the color wheel. It’s primarily seen as a blue family and is a key ink cartridge in many printers. It is a mix of half green and half blue, but that makes it 75% blue as green itself is a blend of blue and yellow.
Yes, i will have an eye to look for ToyKeepers posts, also have to search this forum to learn more.
Have been here many times before, ended up with an account to make questions possible for me.
Very fast response i must say, that response was mucho needed to awoid mistakes with my order.
To be, continued.
Nothing has changed in the way that I press the button, but I will follow the suggestions and report back. Thanks.
EDIT:
That was easier than expected - everything working nicely now, and I can no longer reproduce the flickering. Thanks for the advice - it really is a fantastic light, and I couldn’t wish for more (I’ve got the XPL-Hi version in NW).
SST20 6500K, 5000K, 4000K 95CRI options added for the D4S.
SST-20 6500K: 4200lm / 58,000cd
SST-20 5000K: 4000lm / 55,000cd
SST-20 4000K 95CRI: 3000lm / 41,000cd
I’d love a 3000k warm
These numbers look seriously good, especially compared to XP-L HI (which I considered the best so far).
How about adding Osram KW CSLPM1.TG option? Looks like a direct drop-in and should really shine in this host….Vinh claims 4800 lm and 110 kcd.
Yes, we can offer that, please place the order on the site without choosing the LED & tint, then leave us a note about 3000K SST-20, customs order may take one week to ship.
Just when I thought 3 was enough….
Hank, how about a dedomed SST20 version for even more throw? Would that be feasible?
