No led light with 5$ discount? I will change the emitters anyway, so I will let others decide.
That would just be a host, but including the interesting DEL driver and TK firmware, and maybe an MCPCB.
It wonāt work with any other driver, it is an integrated design, the only straightforward modding potential is emitter swaps, firmware tweaks and TIR changes.
Difficult to see how that could be attractive to Lumintop, Just buy the cheapest version and get on with it, assuming that they are not glued up tight, like the GT.
Best just see it as a complete sealed torch, and buy a version that will do. Itās already modded to the max. (maybe beyond), difficult to see how to improve. Which is the point, and attraction, of the thing. The hard work has (hopefully) already been done.
Otherwise DIY a triple on e.g. a Convoy host, same result, maybe slightly better performance, but it will cost at least as much in parts, even if you know what you are doing, donāt make any mistakes, and donāt cost your time and materials, and tools.
Any news on what surface finish has been chosen ?
I vote 2
- Iām in no rush
Frankly, I think that having 2 LED options makes a lot of sense, just like for example Emisar does. If the XP-L is the first one to be out then fine, Iāll probably wait for the high CRI option with Samsung LEDs reading first reviews before ordering.
Itād just be sad if the light would be available with ONLY Cree emiters.
XP-L HI, I donāt want to have to mod this thing
Surely you jest
Like I said, without the LEDs :). But I will wait for the cheaper Samsung LEDs and change the emitters. Option 3
Option #3ā¦. make the XP-L HI model now. Wait on the Samsung model until the proper LH151D can be obtained.
Orā¦. just put a 5000K LH351D in it if they are available in a nice Rosy tint.
Option #3
- ā3. Make the XP-L HI model now, and do the LH351D lights laterā.
Vote forā¦
Hi Now.
HI now, high CRI with good tint when possible.
Assuming it has been finalized that there will be two emitter options, I absolutely think one should be made now, if that is possible, and the other should be delayed until it can be made without comprising on tint.
Option 3 please. Hi now. Better tint Samsung later.
Iām with everyone else: make the XP-L HI first and wait for Samsungs with nice tint. As Iāll be going for the Samsung version, this will allow other people to find any problems with the first batch.
My preferred option is:
Go for the XP-L HI lights right now, and worry about the LH351D lights later.
XP-L HI now, LH351D later.
I am all for the XP-L Hi as well, as long as it isnāt 4000K. 5000K or a bit better is good with me. So if the XP-L is going to be 4000K I would wait for the Samsung emitter if itās going to be 5000K or better. If both are going to be 4000K then I would prefer a light without any emitters at all. If none of that is a option I will buy another D4.
Good questionā¦. :+1:
- Is the XP-L HI going to be āat least 5000Kā (or a bit more??)
Release the XP-L V3HI 5000k or better and may God have Mercy on my Soulā¦ I want itā¦.I want to use itā¦. or at least have it, before Iām DEAD!
Is it too late to get on the list? If not please add me to the list.
Thanks,
Ajohn151
