I don’t think anybody has mentioned this here, and there are alot of people asking for Clear Anodized finish… well, looks like your wish has been granted… See below from FF light website:
Some time ago I searched….there are many TIRs around 35 mm, they are used to make MR16 light bulbs. I don’t have any notes, but a quick search finds a few:
Im hoping FF can tell us which Optic they are using or show us a compatible optic with bigger TIR cups for more throw. Im imagining a focuswd 5000 lumens beam with 200kcd throw using the White Flats
You’re unlikely to find a throwier alternative that would be compatible. That’s because larger cups = higher cups. Maybe with a bezel not fully screwed in…
It’s larger and 12 degree spot vs 25 degree from this one. In addition, since it’s only 4 LEDs each LED will be driven harder so of course it will throw better. A 7 LED single cell light is not designed to be a good thrower, ever.
Right contactcr, it’s not an even comparison… different beasts.
I have yet to see an TIR optic that actually throws anyway. Certainly not one with multiples that utilize small individual TIR’s. I’ve even used 60mm single TIR’s and they don’t have the concentrated hot spot in my experience. So a 9mm to 14mm TIR is surely going to be at a disadvantage.
Wider TIR’s will throw off the center point, so if an optic has the same 35mm diameter and same number of emitters with wider optics they will be on a differenter center almost assuredly. Not necessarily taller, they build em all kinds of ways, but wider shifts the center, can’t help it.
I think I’m going to hold on as well. I was expecting it to challange D4S in the throw department while being more suited for EDC. Don’t really have use for such flood light, especially having PL47 (hopefully soon )
