There are not any known issues that Iâm aware of. The built in charging rate is a bit low at 0.5A. It means it takes longer to charge, but that may not be a big deal for most.
Whoever said 3000 lumen is crazy. You have 2 different emitters and 2 different models, S43 and S43S.
The S43 with the neutral white Nichia 219C emitters should be about 1600-1700 lumen.
The S43 with the cool white xpg3 emitters should be about 2100 lumen or thereabouts.
Then the S43S is an upgraded version that can draw higher amperage from a battery. This might bump itâs specs up maybe 200 lumen more.
Thanks for the answers. That was enough to make me make a decision - I wonât recommend that light. The tipping point was reading about the inefficiencies mentioned in the review thread.
Just got hold of the s43s and its pretty nice bearing in mind its a budget unit.
Some pics if anyone is interested. The turbo stepdown is better then the s42 and heat is better also probably due to the massive lump of copper.
i have a 18650 tube and and short tube as well.
Your friend must be a hard core flashlight guy to care so much about the efficiency. Does he also care a lot about driver efficiency? That may rule out a lot of lights, as well.
300 PLN, so about $78 including cell and charger (built-in charging is preferred).
I recommended Emisar D4, it was my only recommendation truly faithful to the requirements (small, BRIGHT, very good quality). But since the person liked the idea of a built-in USB charger, I know he likes gadgets and he likes to travel - I also recommended Folomov EDC-C4 as its powerbank feature might be more valuable than the output.
ADDED:
Since he cares a lot about output and S43 doesnât deliver, largely because of a major design flaw - I decided itâs not worth recommending. D4 costs $12 more (with shorty tube and 219C) and delivers 75% higher output. The person wants small weight and here D4 is better as well. The XP-L HI option may be interesting as well, if he wants D4 Iâll talk the LED choice with him.
ADDED: Also, itâs quite funny S43 output is closer to that of EDC-C4 that to that of Emisar D4âŠ.It sits half way between a boring work light and a flashy toy - in both output and features.
I would recommend the Olight S2R Baton II. Itâs over a thousand lumens, great beam, uses Olight proprietary charging system which I personally love. It is reliable, has good run times, is comoact, has a proper warranty and customer service. For a non-Flashaholic itâs ideal.
Got one for my brother in law whoâs a non-flashaholic and it is his favourite light. Not sure if you have a Olight dealer in your country thoughâŠ
Otherwise clicky switch lights are very reliable and easy to repair in case of a rare failure.
For the record, the S43 driver is exactly the same efficiency as any other 7135 based driver, they all do exactly the same thing, using exactly the same components. That includes the D4 driver, The D4 is technically using a TA driver.
The only difference between the D4 and S43 driver is the pinout used for the MCU and the S43 has the add-on charging board.
Now the optic in the S43 is not the best and the bezel does reduce some of the light output lowing the OTF lumens and thus the efficiency of the light.
Just wanted to clear up that the efficiency drop is after the driver.
Oh and I am pretty sure that most of the low output that the S43 has in stock form is due to the springs, bypasses should bump the output up to close to if not the same as the D4 seeing as everything else between the lights is basically the same with the bin of the LEDâs being a a possible exception. I warned them that the springs were sub-par but at this time I was not able to get them to fix it.
How does the D4 deliver 75% higher output when it uses the same leds, driver and battery? It makes you scratch your head and wonder âHmmm, something doesnât sound rightâ. Anyway, good luck on the search. :+1:
I actually did think about it and I donât see the community measurements unbelievable.
Optical losses - we know that S43 has them high. Emisar likely has them lower, but obviously non-0.
Electrical resistance - Emisar is known to be superb in this regard, S43? Doesnât seem bad, but itâs likely worse.
LEDs - Emisar uses the top bin for the CRI. How about Mateminco / Astrolux?
Due to the way a linear driver such as these in the D4 and S43 work, this has no effect on efficiency in the lower modes, technically it makes the driver itself more efficient if you want to get really picky.
What it does do though is limit the maximum output. This is where a fair amount of the lower max output on the S43 comes from.
Thank you both for recommendations. Frankly I believe that for this friend, both S2R Baton II and U18 may be technically inferior to EDC-C4, but they should be of a little higher quality. Local availability of Olight is a plus as well because that friend isnât happy to wait for long holiday season shipping. Though the price with shipping within country is actually slightly above the budget.
Iâve been thinking about a range of clicky lights, frankly I believe that a $7 S2+ would be good enough for the actual needs of the friend. But I know too well that âwantâ often is more important than âneedâ. I already asked how strict I should be at limiting size, maybe that will unlock some clicky options like BLF A6.
Thanks, though I really donât think this size class is interesting for the friend. I havenât heard back since yesterday, so I donât know if any major size increase is on the cards, but SP33 next to shorty D4âŠ.not really comparable.
Yes and no. The driver itself is the same design in both lights, I think the D4 just uses a better FET so it is slightly lower resistance.
The real reason the S43 has lower output is the optic is a fair amount less efficient then the D4, so not as many lumens make it out the front of the light.
