【 Valid until Dec 13th 】 KLARUS 360X3 ✺ All-new 360º "Switch Ring" Tactical Flashlight ✺ Interest list
KLARUS 360X3
All-new 360º "Switch Ring" Tactical Flashlight XHP70.2
  • The 3rd generation tactical tail dual-switch. All-new 360º "Switch Ring" for omnidirectional control molded from premium grade soft silicone; high elasticity yields larger operation area for quick and accurate reaction.
  • CREE XHP70.2 P2 LED with max output up to 3200 lumens (with included 18650 battery), far exceeds the competition.
  • Easy Interface: One-Touch Strobe, One-Touch Turbo, One-Touch Low, Mode Memory Function, SOS, Switch Lockout Function, Quick Change Settings.
  • Incorporates multiple breakthrough technologies: Intelligent Thermal Protection System (ITS), Intelligent Battery Identification System (IBIS), Intelligent Charging System (ICS), Multiple Safety Systems.
  • Patented tail cap dual-switch and side switch design, adaptable for different scenarios, easy to use.
  • Two Interfaces: Tactical Setting; Outdoor Setting.
  • Tactical Setting: Specially designed for self-defense and tactical use. Classic KLARUS XT series control interface. One-Touch Strobe; One-Touch Turbo; perfect candidate for any mission.
  • Outdoor Setting: Designed with the wilderness in mind. One-Touch Low; One-Touch Turbo; Multiple output levels, SOS function; suitable for all needs in Hunting, Hiking, Camping or Search and Rescue.
  • Intelligent Thermal Protection System(ITS): monitors and auto-adjusts output levels in real-time, keeps LED and crucial component safe for the best balance of performance and safety.
  • Intelligent Battery Identification System (IBIS): Adjusts output according to the currently installed 18650 battery discharge rate, compatible with 18650 Li-ion batteries, CR123A batteries and Klarus 16340 batteries.
  • Intelligent Charging System (ICS): Micro-USB charging port with real-time monitoring of charging status to prevent overcharging. Max charging current limited to 1A (avoiding damage to charging devices), ensuring optimum charging status.
  • Multiple Safety Protections: Over-Charging Protection, Over-Discharging Protection, High Current Protection, High Temperature Protection, Reverse Polarity Protection, Impact
  • Both tail and side switches can be put into lockout mode, this prevents accidental operations; stops battery drains during storage or travel and avoids eye injuries.
  • Springs at bezel and tail end resist shock and drop damages.
  • Reverse Polarity Protection eliminates damage from incorrect battery orientation.
  • Aero-space Aluminum alloy body with CNC machining; Mil-spec hard anodizing (HA III); lightweight yet robust construction.
  • Stainless bezel ring offers protection for crucial components and can function as an emergency glass breaker during emergencies.
  • Integrated light head design for high efficiency heat dissipation.
  • Tempered glass lens with scratch resistant AR coating.
  • Premium quality soft silicone embedded into the flashlight body, achieving tactical slip-proof grip with max comfort. This design excels at improving light retention in extreme cold environments.
If you are interested, notify in this thread (not in PM)
Interest list
  1. Fin17
  2. HONDARIDER
  3. blueb8llz
  4. blueb8llz
  5. casi29061965
  6. royalomaha
  7. ...
I’ve been curious about XHP70.2 lights and am glad to see more models coming out.
I’m wondering about why the High level is only 400 lumens. It’s a big jump from 400 to 3200. Is it because an XHP70.2 will run down an 18650 pretty quickly in the higher levels?
Interested, price dependent of course. See it has the Klarus lumen jump. 400 to 3200.
Is that their signature leap in lumens? I haven’t looked too closely to their specs before.
Interested in at least two. Kinda odd about the big lumen jump though??
And I’m also concerned about the 360 switch. I feel that the user can easily accidentally access the instant strobe or the low mode if they are not careful or have big thumbs or gloves on. But that 360 switch is a big reason to why I wanna try this light out also hahha
Interested, depending on price.
Interest
would be nice if they made available to purchase just the tailcap so we can use it in the XT11GT
Interest list updated
Interested
Interested
Interested, thank you.
I’m interested!
Coupon code sent to anyone interested.
OFFER VALID UNTIL DECEMBER 13
Interested :-)
Also interested
Interested
PM's sent to all who interested
GGot mine in. And it’s actually a nice light. I love the feel of the rubber handle. The 360 thingy is quite cool. But like I imagined, it does get in the way sometimes pressing the tail switch. The bottom part of your thumb activates the strobe. So as long as your weary or careful. It shouldn’t activate.
But it does seem underpowered. I’m only getting 2400 lumens. Here’s the kicker. So I put in a high drain….30q…… doubled the output! Now I’m getting 4800 lumens! That’s an insane amount from a single cell light. You guys better swoop one up before klarus decides to regulate the driver hahah
Edit: actually it’s a purple Efest 2500 that is able to push this light to 4800 lumens.
All other high drains will only give 2400 lumens. What is it that’s inside the purple efest cell that’s allowing this to happen?? So so weird
