Vapcell INR21700 K29 2900mah 20A li ion battery New arrival
592 posts / 0 new
mihlit
Last seen: 7 months 2 days ago
I don’t know how big the 16340 market is, but I was just buying new batteries and there was not much to choose from. So I’d appreciate if there were some (new) good 16340 cells.
MascaratumB
MascaratumB's picture
Last seen: 22 min 47 sec ago
+1 here for the 16340s development!
I have now more 16340 flashlights that need high drain cells for them, so I will be looking for some more news about it Dennis! And when I get back to market to buy cells, your store will be on my radar for sure! Nice to have cell manufacturers/sellers on BLF Wink
moderator007
moderator007's picture
Last seen: 6 months 1 week ago
Here are a few lights that use a 16340, they are several more that’s still not in that list.
A lot of newer lights are pushing the current limits on most 16340’s, we have no true 16340 high current cell. What is needed is a high capacity cell that can deliver around 2 amps at 800 to 1000 mah and a high current cell (INR16340) that can deliver around 5 amps or more at 600 mah or so.
Basically, just take the Aspire (Vapecell) INR18350 1100 mah cell and shrink it down into the 16340 size. You’ll have a best seller on your hands. Thumbs Up
Barkuti
Barkuti's picture
Last seen: 2 days 3 hours ago
moderator007 wrote:
A lot of newer lights are pushing the current limits on most 16340's, we have no true 16340 high current cell. What is needed is a high capacity cell that can deliver around 2 amps at 800 to 1000 mah and a high current cell (INR16340) that can deliver around 5 amps or more at 600 mah or so.
Why so low specifications? Wink Dream on!
The TrustFire IMR16340 650mAh (red-gold) is one of the current references:
I've seen that wide tri-lobe/leg top in some other rewrapped 18650s, BlueSwordM said me here chinese OEM BAK was making them (the 18650s).
With more than 40% innards volume versus 18650s I think aiming for well above 1000mAh and mid to high discharge rate is doable.
E-Moli One Energy Corp (Molicel) may be a nice choice to aim for developing newer small cells, they make really good cells. Check this Mooch Poll: What is most important to you in a new battery? @ E-CigaretteForum
Cheers Party
Deleting a just published post causes the forum thread answer notification to fail. Thus, if you need to change your just published post, edit it. Thanks.
Please avoid fully quoting lenghty posts, namely with nested quotes. Trim quotes down to the essential. Helps with neatness and legibility. Thanks.
I recommend saying no to Covid vaccine. Listen to your soul. Innocent
eas
eas's picture
Last seen: 1 year 8 months ago
I think the problem for 16430 is that other than flashlight enthusiasts, the market for high-drain cells is fairly small.
18650s have a whole host of high-volume applications. 21700 get volume from the EV market.
The 18350 doesn’t have the same sorts of volumes, but it did get enough of a boost from the vape market to make a good step forward.
Maybe someone needs to promote a small vape device that depends on the 16430. Maybe something you can stick in your nostril and leave there, or your ear!
moderator007
I’ve seen that wide tri-lobe/leg top in some other rewrapped 18650s, BlueSwordM said me here chinese OEM BAK was making them (the 18650s).
Cheers Party
Those are my favorite 16340 cells for high current lights. Even though the graph looks good at 3 amp discharge when you apply that to a flashlight, it’s still under performs. Voltage sag creeps up really quick on these cells even though they are the best 16340 cell for high currents.
From my testing at a 3 amp load the cell is at about 3.5v within seconds of applying the load, then in about 20 to 30 seconds after that its at 3.4v or so. At 3.4v it holds fairly well, dropping voltage gradually for several minutes until it gets to 3.0v. I got a little over 500 mah in 10 1/2 minutes with a 3 amp load at a cut off of 3.0v. Not really what I would call a great cell but it is currently about the best 16340 cell around for now.
Stippier
Stippier's picture
Last seen: 2 years 4 months ago
Will these become available with a buttontop?
Any chance on a black friday sale for 6,99?
AAA: UF-T1, ITP A3 EOS, Tank007 E09
AA/14500: Xeno E03 XM-L T6 NW, Solarstorm SC01, Astrolux S3 (BLF X5), nameless EA41 copy, Ultrafire C3 XR-E Q5
18650: Ultrafire WF-502B XM-L, Ultrafire WF-504B P7, Ultrafire C8, SkyRay King 3x XM-L (gold)
djozz
djozz's picture
Last seen: 1 hour 7 min ago
Mine came in today.
moderator007
What discharge current was that at Djozz?
MascaratumB
Hum, will these be “good” to the Led4Power LD-A4 (3A) drivers?
I am thinking of modding a light with that driver and single emitter for a good output and “decent” runtime! If these cells are good for those Amps, I may get some Wink
SKV89
Last seen: 5 hours 46 min ago
djozz wrote:
Mine came in today.
Wow it’s legit! Thanks!
moderator007
SKV89 wrote:
djozz wrote:
Mine came in today.
Yeah, but at what current. Most 14500 lights now a days draw 2 to 3 amps.
I liked to see a 3 amp test before I replace my Efest 14500’s. I’m still on the fence about these.
I may have to bite the bullet and order a set to test on the icharger.
djozz
djozz's picture
The discharge current during the test in the Opus is 500mA.
I’d like to see a full test by HKJ up to 15A to see how these hold up in voltage and capacity against the purple Efest 14500 cells at high current (the Vapcell test at 3A already shows a lower voltage).
A hint that these still do pretty alright is the following: I checked the current in my direct drive 14500 zoomie with KW CSLNM1-TG led, two dark purple Efest cells and two Vapcell 1000mAh 14500 cells, right next after each other:
Vapcell1 4.68 A
Efest1 5.11 A
Vapcell2 4.78 A
Efest2 5.07 A
So just 7% less current in a 5A flashlight. If the Vapcell 1000mAh 14500 cell can hold up the capacity at this current remains to be seen (the purple Efest does hold its capacity up to 5A, at 7A the capacity starts dropping)
djozz
djozz's picture
Quote:
,does many people need high drian 14500 battery ? thanks .
Sure we do Smile
The best is high drain combined with high capacity of course but I understand if that is a trade-off.
The best high current 14500 cell is, as far as I know, the purple Efest 650mAh 14500 battery. The high current is really impressive for a small battery. If you can find a battery with that performance and more than 650mAh capacity, or that capacity and even higher current, that would be fantastic.
264
264's picture
I drool for one.
Smile
264
264's picture
vapcell Dennis wrote:
264 wrote:
I drool for one. Smile
please place an order from vapcell store. Big Smile
I am at your site an have the batteries in my cart. (Vapcell 14500) One thing I am just a bit confused about is: “Are they button top or flat top batteries”? Some of the photos look as if they are flat top others show a button. I need button top cells. Thanks.
Pete7874
Pete7874's picture
Last seen: 1 hour 11 min ago
Both options are available. Aliexpress gives you the option to choose the one you want. Look under “Color”.
264
264's picture
Thanks Pete7874
I missed that simple choice of flat top/button top option. Alibaba does not seem to have all the kinks worked out with the Paypal system. Wanted to use my Paypal line of credit but was not allowed to be used on Alibaba or at the store. Made me grumpy. Could just have used a credit card but did not wish too.
Pete7874
Pete7874's picture
It allows me to use PayPal just fine, alas, there is an additional fee for using PayPal.
264
264's picture
I was not clear I could have used a credit card Via Paypal but did not wish to. I wanted to use my Paypal line of credit instead.
moderator007
djozz wrote:
Sure we do Smile
!{width:100%}https://farm5.staticflickr.com/4845/46087401712_ee455793a0_o.jpg!
Agreed! The Efest 14500 is best at handling high current in the lights I have used them in.
I modded a Ultratac A1 using a Mountain Electronics 17mm boost driver running a XHP50.2 and it draws 6.5 amps from the cell.
d_t_a
Last seen: 10 hours 45 min ago
Any chance yet of having a suitable shipping method to my country, the Philippines?
I know some AliExpress stores that sell batteries, but cannot ship bare batteries to my country.
So what they did was to bundle cheap generic flashlight and put their battery inside those flashlight — based on my experience some time ago.
What I did: I ordered a couple of 26650 from an AliExpress store, I was not expecting it to arrive (will just dispute if it didn’t arrive).
Then surprisingly, the battery arrived placed inside “generic” flashlight (the flashlight is bad looking, but it worked when I tested it) — so the ‘generic flashlight’ is “free” with the 26650 battery I ordered.
I’m not sure how to do that with your 14500 battery. Maybe can place them inside some cheap AA/14500 flashlight host, then ship your 14500 battery inside the flashlight host.
toddcshoe
toddcshoe's picture
Last seen: 4 hours 31 min ago
Grab the PayPal debit card. You can use it just like a normal debit card but it uses only your PayPal balance. It’s free to get one.
"Everywhere I go, there I am"
mihlit
What about a powerbank? It’s just a plastic box with a few connectors. You can put more than 1 battery inside Smile If it is enough to workaround that no shipping rules
Jerommel
Jerommel's picture
Last seen: 1 year 4 months ago
Wow, these are really 1000mAh ! Thumbs Up
Pete7874
Pete7874's picture
So, what are the downsides of this new Vapcell 14500 battery? Faster self discharge? Fewer cycles? Something else?
I mean, this cell offers roughly 25% more capacity than all other cells currently on the market. Why isn’t anyone else producing such cells? What’s the catch? Or is it just some new technology that just hit the market that wasn’t previously available?
Not trying to be skeptical or poke holes. Just trying to understand what allowed for this large capacity increase and if there are any downsides.
Thanks!
djozz
djozz's picture
There was already the Soshine 900mAh 14500, also fairly new and not high-drain. I have them too and could check them in the same flashlight. HKJ has posted a test a while ago.
I think that the technology of chinese batteries is getting slowly better.
SKV89
djozz wrote:
There was already the Soshine 900mAh 14500, also fairly new and not high-drain. I have them too and could check them in the same flashlight. HKJ has posted a test a while ago. I think that the technology of chinese batteries is getting slowly better.
Yeah,made in China is progressing, changing the world’s view on Made in China Beer
Im waiting for Chinese battery manufacturer to achieve 7000mah for 26650, so there will be a good reason to use 26650 flashlights over 21700mah flashlights. If Chinese manufacturer can make 5000mah now, hopefully we will see 7000mah 26650 very soon.
Pete7874
Pete7874's picture
Vapcell 14500 is lithium cobalt, not lithium manganate
Lithium Cobalt Oxide(LiCoO2), Lithium Nickel Manganese Cobalt Oxide (LiNiMnCoO2 or NMC), or Lithium Nickel Cobalt Aluminum Oxide (LiNiCoAlO2)?
Thanks!
TexasToasted
TexasToasted's picture
Last seen: 18 hours 11 min ago
Button top version now in stock at Illumn
