I have bought my Aunt a Convoy S2+ for Xmas and need to give her a charger as well. I was hoping you all could give me suggestions for something $10 and under. One that came with a single battery would be nice as well. She is not a flashlight person just needs a decent light for around the house and will need to be able to recharge the battery.
I donât know what country you are in, that data is missing from your profile, but if your in the US you might consider the Xtar Ant MC1 Plus from MTN E. Shipping is fast.
Itâs got a 1A charge rate and a little readout to tell you when itâs done. You just need a usb jack and cable to power it.
What I typically buy family members is the Eagle Eye X2R and a protected cell. Itâs a simple 3 mode tail clicky with built in USB.
Taking the battery in and out can be tricky for new people. Make sure she knows how to tell the positive from negative on the battery and that the positive goes toward the leds.
I was gonna make the same suggestion â XTAR MC1+
Itâs cheap, performs well, and is simple to use. Plug it in just like a phone, and once all the blue lights illuminate and stop flashing, the cell is fully charged.
Still comes with a cable and carry pouch, so itâs nice little package. Quite satisfying for the $4-5 it can be had for.
i would say get the xtar vc2, doesnt cost much and shows u nice progress how much it charges etc visual easy to understand and if has a spare battery can charge 2 at the same time, imo good charger.
also its safe charging at only 0,5A not that it matters perhapsâŚ
Given that itâs for someone whoâs ânot a flashlight personâ, you might want to let her avoid having to actually remove the cell, charge it, put it back in (hopefully not backwards), and so on, and so on.
Murky marketing strikes again. Of course, only the newer âANTâ model has the progress display.
VC2 has a display, but not as much of a no-brainer; not everyone thinks in terms of volts and amps. And worst of all, it become useless if that special input cable is lost, and is much harder to replace than a typical micro-USB cable.
Polarity is at least something anyone who has ever used a battery-power device has encountered, so itâs not an entirely foreign concept.
