Thanks Hank! That’s awesome! I’m going to place an order! I’ve been asking for someone to make some 3000k, thanks for this!
Gregor, the CRI on the SST20 4000k is beatifil. It rivals the best 219b R9080, and runs cooler . It should have a wide hotspot too. Just a wonderful emitter. otherwise get an XPL-HI if you want throw…Hanks’s 3A tint is killer good and clean! I should say XPl-HI my favorite in this torch currently all around…the kcd of the SST20 is also impressive; can’t wait to see the comparisons from out in the wild come in!
That makes sense. The emitter of the SST-20 is smaller than the XP-L emitter => more throw
Also, the SST-20 costs around 0,60€ in quantities of 1000 while an XP-L Hi is around 2,50€ in quantities of 1000.
That alone is a difference in material costs. But please don’t ask me why the difference is 4,50€ per emitter.
I recall some of the more knowledgeable folks hereabouts mentioning mixing several different LEDs to get better color rendering.
If y’all can specify a good combination of emitters, would it be interesting to ask for that configuration?
_
I’m not that Hank, I’m the other one.
I’d especially like to see what the 5000K one looks like. I’ve been wondering about SST20 5000K for a while.
People may take it for granted that Emisar lights come with good emitter choices, but compared to almost every other brand, it’s really special and unusual. Take Olight for example… almost everything is cool white, and one of their recent lights only comes in 7500K. :person_facepalming: It’s kind of amazing that Emisar has so many choices.
Vinh’s lux meter seems to use a different scale than most people use. The correction factor seems to be about 0.75 or so, if you want to compare the numbers against other people’s. For example, the D1S (stock with no mods) is listed as 130 kcd on Intl-Outdoor or 170 kcd in Vinh’s shop. 0.76 correction factor. Every other light I’ve checked (or measured) also follows a similar pattern with a factor pretty close to that.
LMAO Literally what I was thinking when I read what Hank said and continued to read on lol…. Had been debating on getting an XP-L HD variation but now the SST-20 has been thrown in the mix.
Anyone give any details about how the beam of the SST-20 will be?
Vinh says 42kcd for the XP-L HI V2 3A, which is not as bright as the V3 1A. 45kcd is what the cool white gives.
However I the differece between leds is not 25%, so this doesn’t account for 0.76.
Measuring photometric intensity is easier than total lumens but a reliable detector is still necessary and that’s not easy to find. See the recent efforts by djozz.
So, we need someone who has calibrated the luxmeter with Maukka’s calibrated lights to check this issue.
