That makes sense. The emitter of the SST-20 is smaller than the XP-L emitter => more throw
Also, the SST-20 costs around 0,60€ in quantities of 1000 while an XP-L Hi is around 2,50€ in quantities of 1000.
That alone is a difference in material costs. But please don’t ask me why the difference is 4,50€ per emitter.
I recall some of the more knowledgeable folks hereabouts mentioning mixing several different LEDs to get better color rendering.
If y’all can specify a good combination of emitters, would it be interesting to ask for that configuration?
_
I’m not that Hank, I’m the other one.
I’d especially like to see what the 5000K one looks like. I’ve been wondering about SST20 5000K for a while.
People may take it for granted that Emisar lights come with good emitter choices, but compared to almost every other brand, it’s really special and unusual. Take Olight for example… almost everything is cool white, and one of their recent lights only comes in 7500K. :person_facepalming: It’s kind of amazing that Emisar has so many choices.
Vinh’s lux meter seems to use a different scale than most people use. The correction factor seems to be about 0.75 or so, if you want to compare the numbers against other people’s. For example, the D1S (stock with no mods) is listed as 130 kcd on Intl-Outdoor or 170 kcd in Vinh’s shop. 0.76 correction factor. Every other light I’ve checked (or measured) also follows a similar pattern with a factor pretty close to that.
LMAO Literally what I was thinking when I read what Hank said and continued to read on lol…. Had been debating on getting an XP-L HD variation but now the SST-20 has been thrown in the mix.
Anyone give any details about how the beam of the SST-20 will be?
Vinh says 42kcd for the XP-L HI V2 3A, which is not as bright as the V3 1A. 45kcd is what the cool white gives.
However I the differece between leds is not 25%, so this doesn’t account for 0.76.
Measuring photometric intensity is easier than total lumens but a reliable detector is still necessary and that’s not easy to find. See the recent efforts by djozz.
So, we need someone who has calibrated the luxmeter with Maukka’s calibrated lights to check this issue.
With the vaporizer crowd and power tool manufacturers flocking to the 21700 format, I do find myself wishing that a 21700 battery tube were available since that formfactor may yet see some improvements on its already-impressive power/density characteristics.
I had a similar issue and thought it was a driver or firmware or mechanical issue. Turned out to be a simple mechanical issued alright - the tube:head connection wasn’t as snug as it could be. Tightened it up and the issue disappeared.
Interesting. Looking again now, he also no longer lists 170 kcd for the stock D1S. I wonder if he updated his meter, or otherwise changed measurements to improve accuracy. That would be welcome news.
OTOH, the D4vn still lists 40 kcd, but on mine I measured 28.6 kcd.
Here it is (left) next to a D4-219C 80 CRI model (right), underexposed to show the size of the hotspots better:
It’s certainly the throwiest D4 I’ve seen, but I measured mine as only 41% throwier than an XP-L HI model, not 98% throwier as claimed.
I think his lux readings are weird. Some seem to measure high, some low. For instance, he measured the stock GT at under 1m cd, while others measured it around 1.1-1.2m cd.
On the other hand, he measures the ROT66 with LH351Ds at over 20kcd, while my Zebralight SC600 MK3 HI, measured at 18kcd, definitely has a more intense hotspot in comparison.
All that aside, his measurements of the White Flat 2mm are probably reasonably accurate, and such a high performing emitter would be pretty great to have stock in the D4S.
Recently I collected all measurements that I could find for a number of lights:
In some cases there are Vinh’s numbers.
In 1 case the number is indeed an outlier, in others its not.
GT Mini: Vn 170 kcd, others average 128.5 kcd
Cat V6: Vn 175 kcd, others average 178 kcd
T27: Vn 335 kcd, 1 other 340 kcd
Do you think it would be sensible to mix SST-20 3000K 95CRI and SST-20 4000K 95CRI on the D4S to gain a beam profile with 3.500K color temperature? Would this even work as the 3000K version is probably subject to become warmer and less efficient in conjunction with the 4000K SST-20 at full brightness level? (...thinkin' about Vf, thermal specs, maximum current, etc.).
Whew to my eyes that is one green beam; doesn’t matter if it throws a mile, no ty.
On a good note I ordered a 3000k SST20. Super excited about that. I.already have 2 D4S, a Nichia and XPL-HI 5000k. I hope the SST20 is as nice as djozz found with his testing! Should be amazing in this quad! Thanks again Hank!
