13703 posts / 0 new
cabfrank
Last seen: 4 hours 46 min ago
TK, really amazing.
M4D M4X
M4D M4X's picture
Last seen: 1 month 3 days ago
cabfrank wrote:
TK, really amazing.
she indeed is!
PLEASE NOTE
i do not work in "reviews, deals and codes" for the time being
maybe M4D M4X will return one day, but until then:
THANK YOU FOR YEARS OF YOUR SUPPORT AND FRIENDLY CONTACTS!
ToyKeeper
ToyKeeper's picture
Last seen: 4 min 15 sec ago
More progress on grey anodizing… I think this was the second attempt to get a nice dark grey color:
About the parts not being together, Neal tells me: “not the production item, they will cut some screws before assemble”.
So the theory seems to be correct. It looks weird because the threads aren’t there. If I understand correctly, the ano factory took these pictures. And since the threads are cut after anodizing (so they can carry current), it wouldn’t be possible to put things completely together at this stage.
Firelight2
Firelight2's picture
Last seen: 1 hour 37 min ago
Thank you for clarifying that TK.
Also, that looks great! Love the dark grey ano! Thumbs Up
Agro
Agro's picture
Last seen: 1 month 1 day ago
djozz wrote:
Quote:
Also, I believe that Emisar D4 tests have shown that FET was not as inefficient as people predicted
A led driven to the max is inefficient for two causes: high current and high heat. A FET driver at PWMed lower modes has one cause (heat) removed so the led during the pulses runs at higher output than if at max continuously.
It really works like that. Example: I made a 18650 zoomie with a Osram KW CSLNM1-TG and FET+1 driver. If I use a high current cell it is overdriven at max resulting in angry blue light. But at slightly lower setting (so still high in the FET region of regulation) the led colour is normal. The led still receives the same current (but pulsed) so the difference I presume is caused by less heat.
OK, I found that:
http://budgetlightforum.com/comment/1168928#comment-1168928
ToyKeeper wrote:
djozz wrote:
the PWM is so fast that the peaks do not end up fully at 3A, this could be checked on a scope
IIRC, maukka scoped this on the D4 a few pages ago and found that theory to be true. The pulses have a slow enough rise and fall time to act as a very weak lowpass filter, so short pulses never reach full height. (edit: scoped output, but that works because the LED activation time is much faster than the FET driving it)
Still…is it caused by FET model? Battery chemistry? Something in the circuit?
ToyKeeper
ToyKeeper's picture
I think it may be caused by a small resistor in the circuit which is specifically designed to take the edge off each FET pulse. This was done to prevent excess voltage spikes and electrical noise within the driver, but it also seems to have the effect of increasing FET efficiency slightly.
teacher
teacher's picture
Last seen: 2 years 1 month ago
Thank you TK for the info & the picture…. that is looking good!! Thumbs Up
ludolf
Last seen: 15 hours 37 min ago
Please add me to the list. One piece with LH351D emitter.
Thanks.
pinkpanda3310
pinkpanda3310's picture
Last seen: 1 week 4 hours ago
Aah, that makes sense.
I’m not really fazed about the colour. So long as it insulates the sleeve where it’s supposed to. The pictured light must be proto 3 ?
I’m very happy that we’re getting some communication now.
teacher
teacher's picture
pinkpanda3310 wrote:
(snip)
Amen!! Thumbs Up
Thank you TK for picking up the communication sharing roll on this ‘Group Buy’!!
I can only imagine how difficult that has been for you since you were virtually receiving no information to share with us until recently.
Your efforts are noted & appreciated.
For without your efforts I imagine most of us mortals would be completely ‘in the dark’ concerning the FW3A.
Tjohn
Tjohn's picture
Last seen: 6 days 2 hours ago
ToyKeeper wrote:
More progress on grey anodizing… I think this was the second attempt to get a nice dark grey color….
Hopefully there is a cold blue steel tone to the original, similar to what is seen on my old Nokia 830 dumb phone.
If so, would some call it ‘gun metal’ ?
JasonWW
JasonWW's picture
Last seen: 36 min 41 sec ago
Did they mention whether the dark lines/overlap are now gone or perhaps hidden? If so, I’d call it a successfull compromise and move forward.
Jerommel
Jerommel's picture
Last seen: 1 year 4 months ago
Well, it’s still a nice looker, despite it not being clear or light grey dyed.
DB Custom
DB Custom's picture
Last seen: 21 hours 7 min ago
Right you are Jerommel, it IS a nice looking light, just not the light we signed up for in the beginning.
nottawhackjob
Last seen: 2 hours 51 min ago
IMO other than the electronic switch I honestly don’t see watt all the hoopla is about this flash vs watts already out there.
Outwardly IMO it’s an average design with essentially a TI patina. Ok. Woo hoo.
Now if it had a rotary mechanical sideswitch dimmer that was hidden behind a sliding cover that could give me some “hardness”. Or if heads with different led configurations were swappable by just unscrewing then yeah definely woo hoo. Basically a glorified P60. Or magnetic charging, woo hoo.
For this amount of effort and angst I almost expect Bluetooth, a wireless remote, and a camera. Oh, and of course a talking free battery. LOL
Ya know watt? I guess I’m prolly unenLIGHTened.
“In many things in order to truly understand the small picture you have to understand the big picture first.”
True Color Rendition (TCR)/Simplified Definition: “On a scale of 1 to 10, with 10 being the highest rating, a TCR will equate to what true colors you see in sunlight vs the same object’s colors you see when illuminated with a flashlight. The closer the two are, the higher the TCR rating will be.”
The TCR Reference Standard is the Walmart Ozark Trail OT 50L , Model No. 6103.
It has a TCR rating of ‘10’. $1.00 including batteries.
chadvone
chadvone's picture
Last seen: 1 day 12 hours ago
Yeah, its a big deal to me.
nottawhackjob
Ok I can see that. For me though I’m just kinda too old KISS fashioned on certain things.
To wit, a good precise uber reliable momentary switch (forward clicky) IS my electronic switch. LOL
Man, I’m dating myself. Wait that doesn’t sound right. Shocked
DB Custom
DB Custom's picture
What a wonderful offer tatasal! I can’t accept it though, you hold onto that beauty and enjoy it please.
PM sent….
cabfrank
Nottawhackjob, the size and the firmware are elite for an edc. That is what does it for me. I suppose you are correct in that it is not a giant leap ahead, because of the Emisar, which is similar in some ways. I like them both, but have been holding off, waiting for this one.
SKV89
Last seen: 19 hours 11 min ago
CRX wrote:
Well, instead of waiting around or moaning about the FW3A’s production  I had to get creative and make my own version ;)
The more I look at this the nicer this looks. I like the quad better than triple. Perhaps Lumintop should make a FW4A since there isn’t a rear clicky quad in existence and it will be more efficient. Perhaps use 21700 batteries instead of 18650.
cabfrank
That would be great, after this one.
nvanlaar
nvanlaar's picture
Last seen: 3 weeks 2 days ago
+1 Thumbs Up
“Facts don’t care about your feelings.”
~Ben Shapiro
hank
hank's picture
Last seen: 2 days 8 hours ago
It’s alive …. and twitching!
I want one.
CRX
CRX's picture
Last seen: 5 months 1 day ago
Thanks mate, now there is a copper version Wink
Yes, lets not distract them Big Smile
teacher
teacher's picture
+1 . Wink
joechina
Prototype 3 was sent to Germany, unfortunately not to Toykeeper.
I wouldn’t call this a prototype, only anodisation samples to deside the color.
Tom Tom
Last seen: 2 years 6 months ago
Random Dan wrote:
Perhaps since Lumintop only intended to test anodizing, they didn’t bother cutting actual threads? That’s why the tubes look different and why the parts couldn’t be threaded together.
Good call. And thank you TK so much for confirming it with Neal.
Not sure why doing a nice anodise should be proving so tricky, isn’t that what anodisers should just know how to do, it’s their job after all ? Perhaps it’s to do with the alloy used. ISTR that it also took Convoy a while to develop their clear anodise to their satisfaction.
A clear anodise on a “raw” machined finish is also merciless in exposing the slightest defects in workmanship, when the machining marks are to be a design feature, not something to be covered up. Just handling the pieces, moving them around, keeping them almost surgically clean before processing, etc. needs care, individual bubble wrap etc. if you don’t want them dinged up, then a good hard anodise to then protect them. Unlikely to be real mil-spec HA3 stuff, but still something good, semi-hard.
It was probably unrealistic to hope for anything like that at this price-point.
Bead blast, a quick dunk in the tanks, then just chuck them all in a bin together is the production-engineering easy way out.
The solo artisan perfectionist, toiling at their lathe, can make things much more beautiful, and go from concept to execution in a few hours, but that doesn’t easily scale, as I think we are discovering.
Sitting behind a CAD screen, rendering, then perhaps coding for CNC (that’s usually a different, more practical, and dare I say more skilled discipline), is not quite the same thing as making swarf, and sometimes pieces don’t turn out quite the way it was hoped, or are simply un-manufacturable, and another iteration is required, and things can become delayed interminably. The skill is not to let that happen. And to use a team to review, accept constructive criticism, involve the production people as early as possible, and not just live in an ivory tower.
It looks as if they have got a nice looking bland result.
For those interested, you could take a look at e.g http://www.metroplating.co.uk and study their “services” options. Each provides a succinct summary of each process. Specialist finishers like these are crucial to the UK’s manufacturing competitiveness, particularly in motorsport, aerospace and defence, and metroplating one of the best and most nimble IME. There are hundreds more though to choose from, just Google e.g. “anodising uk”.
Or have a go yourself. It’s not difficult. Research it, or just buy a kit from e.g. http://www.gaterosplating.co.uk/index.php?route=common/home or https://www.chronos.ltd.uk/acatalog/Anodising_Kits.html
Something for modders to experiment with, and a bit more creative than e.g. just baking your torches.
Start with something cheap, strip off the old with sodium hydroxide (e.g. some drain cleaners), maybe buff it up a bit, and get practicing. Some battery acid, inkjet printer ink, some sort of DC power supply, a cathode, some Al wire, and you’r good to go. Perhaps in time for the 2019 Old-Lumens challenge. Use titanium instead, and apply by brush, use masking, and you could make a really unique work of art.
ToyKeeper
ToyKeeper's picture
They did not mention. I did ask though.
All I have is a couple of pictures, and the pictures don’t show any seams.
ToyKeeper
ToyKeeper's picture
FWIW, Neal has asked to have a working sample made and sent to me for testing.
The firmware used should be this one: http://toykeeper.net/torches/fsm/anduril.2018-12-02.FW3A.hex
Recommended fuse values are:
  • Low: 0xE2
  • High: 0xDE
  • Extended: 0xFF
So, BOD is enabled. Without BOD, it’s very difficult to exit momentary mode because the standby drain is too low. It took several minutes to drain far enough to cause the driver to reboot, and with BOD it’s only a few seconds. This should also help avoid other theoretical issues with low voltage.
Factory reset isn’t included, because it’d cause too much delay making sure there are no bugs. I did a quick proof of concept but there were too many issues to move ahead with the change right before production. So I went back to the 12-02 version which, despite the date indicated, has been under test for about three weeks on various lights. It’s virtually identical to the 11-11 version.
Anyway, it seems things are finally moving quickly.
chadvone
chadvone's picture
Does BOD mean brown out detection?
the ability to stay on through super short power cycle?
If so I think this would be a good thing.
Is it a good thing?
