Feeler thread / sneak preview: Wuben TO50R HC ("The Flashlight")
In!
What’s the latest on the charging port? Since Wuben already uses USB-C in the A21, will the TO50R also have it?
I hope we soon hear how it stands with the TO50R
yes
i’d be more interested if it was under 100mm long, but no one else seems to care about that
wle
+1 for USB-C
It’s 99% sure that it will be Micro-USB. We decided so because of better availability -> being able to charge the light “everywhere”.
USB-C is the future, but unfortunately, the Micro-USB availability is still way higher.
also has usb c on the t70 1x26650 light
wle
If has micro-usb, I’m out :cry:
Yep. Seems I’m also not meant to buy this one.
Only failure availibility seems to be better with micro USB, I’d say :smiley:
+1, I don’t see reason to buy new items with microUSB.
Interested.
I’d like the UI printed on the underside of the bill/visor on a gimme cap.
USB-C please! All of the new Acebeam lights have USB-C too. I was planning to buy a bunch of these but if no USB-C then maybe not.
Any update on this?
Putting the final touches to the FW at the moment.
Soon…
Can hardly wait
It will use a different firmware than the usual low-med-high-turbo-SOS common in most Wuben flashlights?
Right. I have designed a new UI for this light, trying to make it as easy and pleasant to use as possible:
  • Click on, click off
    • #1 requirement for any flashlight is to get it on or off quickly and effortlessly
    • Click on/off works instantly, no matter how fast you turn the light on or off - no risk for accidental strobe or other "double-click features"
    • Suitable also for signaling!
  • Click W to change mode
    • 4 modes in the main cycle -> find the correct mode quickly
    • Need 2 modes up? Just click twice - no risk for accidental strobe or other annoyances!
  • The whole UI is based on click and press actions (and nothing else!) => no difficult double/triple/quad clicks!
    • Empirical studies show that especially older people have problems with double clicks
    • No risk for accidental double clicks that may turn the light on strobe or simply blind you!
  • Shortcuts to lowest mode and turbo mode
    • A typical situation is that you quickly need one of these modes without knowing which mode was last used
  • Momentary turbo (from off or any mode)
    • Imagine walking with the light on 250lm mode, you hear something, press W-button for a momentary turbo to see what's there, and finally release button to get back to 250lm mode and continue your walk.. :)
  • Hidden Strobe, Beacons & SOS
    • In case you happen to need them..
UI diagram: (Modes are not final. Anything can still change. No promises, no lies!)
Thanks for the update!
Here’s a link to the bigger version of the UI diagram.
I know it’s early still, but any idea how much current is pulled on each mode?
