Hi All!
Interested. May as well complete the set.
1x Nichia 219b, Desert
1x SST20 10W NW 4000K, Clear
Thanks
Hi All!
Thanks
Interested XPL HI 6500 CW
Lumens added for each emitter option:
7x Nichia 219B R9080 CRI98 3800 lumens
7x SST20 4000K NW CRI95 3800 lumens
7x SST20 5000K NW 4800 lumens
7x SST20 6500K CW CRI66 4800 lumens
7x CREE XPL HI V3 CW 6500K 6900 lumens
7x CREE XPL HI V2 NW 5000K 6200 lumens
On the ROT66, the XPL HI 5000k was a V3 bin. Why are they using a V2 bin for the E07???
Possibly a Typo on their website. When you select the emitter for purchase, it lists V3 Bin.
I hope it is a typo. Fireflies need to clarify because they specify the V2 and V3 at different output. If the flux bin is the same, the output should be the same regardless of color temperature. For the ROT66, they specify both V3 to be 10,000 lumens.
Freeme, how long until we get YOUR code? Want a 219B before Jack runs out.
Interested
Interested.
Interested !
I was going to order this. But i think im better of with the D4S.
There seems to be some complications with the PL47, so I’m not going to order this one, yet. Maybe when I receive the PL47 and can see for myself if there are any problems with it…
I’m hoping to see the E07 and the D4S side by side. I’m hopeful that soon someone on here will be able to compare them once the E07 is in their hot little hands!
Will start approximately in a day time.
Interested. Code please.
freeme, thanks for the code. If the PL47 I ordered over 5 weeks ago ever shows up, and works correctly, I might order an E07.
Ordered thanks alot
Ordered clear ano
Ordered
Ordered.
Ordered. Clear/4000k/purple/blue. I’m all tingly inside
