On the ROT66, the XPL HI 5000k was a V3 bin. Why are they using a V2 bin for the E07???
Possibly a Typo on their website. When you select the emitter for purchase, it lists V3 Bin.
I hope it is a typo. Fireflies need to clarify because they specify the V2 and V3 at different output. If the flux bin is the same, the output should be the same regardless of color temperature. For the ROT66, they specify both V3 to be 10,000 lumens.
Freeme, how long until we get YOUR code? Want a 219B before Jack runs out.
Interested
Interested.
Interested !
I was going to order this. But i think im better of with the D4S.
There seems to be some complications with the PL47, so I’m not going to order this one, yet. Maybe when I receive the PL47 and can see for myself if there are any problems with it…
I’m hoping to see the E07 and the D4S side by side. I’m hopeful that soon someone on here will be able to compare them once the E07 is in their hot little hands!
Will start approximately in a day time.
Interested. Code please.
freeme, thanks for the code. If the PL47 I ordered over 5 weeks ago ever shows up, and works correctly, I might order an E07.
Ordered thanks alot
Ordered clear ano
Ordered
Ordered.
Ordered. Clear/4000k/purple/blue. I’m all tingly inside
ordered, yellow, Nichia 219B, purple
besides the cash, why would i go for sst20? more flood and cri?
and which 21700 should i take(for max peformance and runtime)
SST20 is less floody than the other options. Hell it probably throws more than the XPL HI.
