Ever thought of dropping in an LED upgrade on either of them?
No, but I did just decide they belong on the long shelf I made this year, along with my other queens. Amazingly, the Navy one looks almost like it’s never been used, only one small scratch on it, and the switch has very positive, secure action. All 4 diffusers are still in the tail cap. Keep the batteries out of them, of course.
How about a flashlight that is cooled by “li-900”, the ceramic that was used in space shuttle tiles? You could cast a triple spacer for a convoy s2 out of this stuff! Does anyone here have connections at Lockheed?
It would be nice to have a 3000 lumen pocket light that can run on turbo till the battery dies.Remember this is just fiction.
Those tiles are the exact opposite of what you want. They’re extremely good insulators. For good cooling you need good conductors of heat.
One I wished for long ago — a fan-folding combination reflector and heat radiator.
Hey, an old magnesium bulb flash. I’m pretty sure I have one lying around somewhere (but can’t find it right now).
just infinite light, tiny size, infinite run time*, lumens and pattern adjustable infinitely and quickly
most important - no blinky modes
*(or zero charge time)
wle
How about an RTG-driven flashlight? :-D (just kidding of course)
https://en.m.wikipedia.org/wiki/Atomic_battery
NASA used these on space exploration missions like Voyager.
I’ve seen one fanwork of The Martian where Watney uses an RTG to warm up the rover while he goes looking for Pathfinder. After much failure and overheating, he makes it work.
Hmm, maybe a flashlight using parasitic WiFi energy suck to recharge.
Would it need a trailing antenna?
The TL-122 is an old design, before WWII… But that of the photo appears be a MX-991/U, more modern (Vietnam).
https://olive-drab.com/od_soldiers_gear_flashlight.php
Edit: Fulton still manufactures it… Fulton Industries | Product Categories | Government & Military
But I’m hoping y’all can come up with some novel, innovative, surprising, new ideas —- science fictiony ideas —- for flashlights of the future.
Dream a little!
Okay, a dystopian future flashlight — built-in facial recognition.
Scan it over the crowd and it brightens to pick out the [insert your personal paranoid fantasy here] people.
A “people recognizing” light is already in the works. But it is for car headlights that selectively dim parts of their beam to avoid blinding everyone on the road.
Petzl has a crude version of this in their $400 industrial headlamps. A pair of IR transcievers mounted in the headlamps will automatically crank down the output when it is pointed at someone also wearing a $400 headlamp.
I still have one; readapted with a reflector with three low power LEDs; it will give about 60 lumens, but to get around at home it’s fine; I run it with two “D” “SUPERPILA” at nikel cadmium dating back to the 80s, but they still work
Cross-reference for historians: flashlights in use by astronauts and cosmonauts at present:
What kind of flashlight is in picture #20?
0-degree divergence light source
Black photons — invisible at the source, which only become visible when reflected from something more solid than air.
Useful when trying to illuminate something that would like to shoot back.
Rufusbduck was ahead of his time with this build.
Just an idea courtesy of slim and only a faint notion how to pull it off. Some copper, brass, aluminum, and hopefully the ingenuity to make it work. Here’s the idea [image] And some of the raw materials. [image] Doing this well and in time will be a stretch but here goes nuthin. I couldn’t find thin wall brass tubing in an affordable length so I’m going to try to roll sheet brass into shape. I’m also going to try and fit 3 - 18650 cells(2 in the handle and 1 up the pipe. [image] I succee…
