I’ve seen one fanwork of The Martian where Watney uses an RTG to warm up the rover while he goes looking for Pathfinder. After much failure and overheating, he makes it work.
A “people recognizing” light is already in the works. But it is for car headlights that selectively dim parts of their beam to avoid blinding everyone on the road.
Petzl has a crude version of this in their $400 industrial headlamps. A pair of IR transcievers mounted in the headlamps will automatically crank down the output when it is pointed at someone also wearing a $400 headlamp.
I still have one; readapted with a reflector with three low power LEDs; it will give about 60 lumens, but to get around at home it’s fine; I run it with two “D” “SUPERPILA” at nikel cadmium dating back to the 80s, but they still work
Black photons — invisible at the source, which only become visible when reflected from something more solid than air.
Useful when trying to illuminate something that would like to shoot back.
this is a bit off topic, but is there a term for the effect you see when you shine a laser on a surface? Kinda looks like thousands of tiny dark particles moving about, I don’t know how to describe it, it’s cool tho.
Interesting tidbit on speckle patterns (interesting if your into firearms accessories), it’s the mechanism used to create the reticle inside an eotech [or any other real] holographic weapons sight.
