I like this very much CRX! 60 KCD for small zoomie!
For White flat fans. Seems that we all getting all kind of different results in our mods. But I am pretty sure that sweet spot for last 2 I build is around 5.5-5.8A.
Someone says 6 and someone says 7 which is freaking lol And Djozz says 4.5
I built RGBW_Clicky into an S41 host for my GAW.
Emitters are:
R: XP-E
G: XP-E2
B: XT-E
W: XP-L HI
Any single channel high is 2A, turbo (all 4 @ 100%) draws >5A from my vapcels. Now that it’s done I see I probably shouldnt have used an XT-E behind a multi-lens optic like the carlco quad but I like how there arnt just 3 boring XP-E2 colors so I’m not gonna change it.
I got this set up so it draws around 5.2A from a fully charged cell so I think it’s in the good range.
I was a little apprehensive sticking a fully charged Aspire 18350 in it with the FET driver so started with the cell at about 50% and worked my way up
I really don’t know how you are making all your builds. So much passion into each build… So this is build/creation and not just a mod like most of us do…
I guess you didn’t lose any intensity
The 2mm² variant has more current capability, mine is fed by a Liitkala 26650 through a TA FET driver.
550kCd in an Amutorch JM70
My first mod! I know its baby stuff compared to what most people are doing around here, but it’s my first and I’m proud of it. Thanks to this thread by NeutralFan Convoy C8 Mod - The WOW Factor I gathered the courage to finally try an LED and Driver swap.
Modded Thorfire C8s
XP-L HI V3 1A on Noctigon 20mm MCPCB
FET + 7135 Driver with Guppy Firmware
22 AWG Wires with Spring Bypass
AR Coated Lens
Arctic Silver Premium Thermal Compound
Swapped the original LED from the Fomolov 18650s for an XP-L HI NW.
I have no hot air station available, so I reflowed with my usual method - PCB placed above a candle's flame.
Thank you! Yes, I’ve gained some much needed confidence too. I’m planning my next mod that will be a Convoy S2+ build for practice before I attempt to mod my Thrunite TN31.
