Interested in NW in black. Could I get a code? Thanks.
Got my MT03 TA finally, very nice light and heat up faster than my old MT03 12000lm. But it can’t be completely turn off, it continue to output very dim light which is lower than moon mode. I didn’t measure how much current it consume with these very dim light.
I managed to completely switched it off without output any light one time when i tried to on off it multiple times, but it has a beating sounds when it’s completely off. This is first time i heard hearbeat of a flashlight. but i can’t make it happen anymore.
Still trying to figure it out, anyone encounter this?
I’ve heard some of the recent MT03 and MT09R lights having a bit of leakage like yours. Texas_Ace showed Haikelite exactly how to build these drivers and with what exact parts. Unfortunately, they seemed to have changed a few components just save a penny here or there or maybe they recieved some counterfeit components.
To find the source of the leakage does require a soldering iron and maybe a hot air station. The most likely component “leaking” current past are the 2 FETs. The little one can be unsoldred to check it, but the big one has to have hot air to check it.
You can request a new driver from Haikelite, but whether you get it or how long it takes is an unknown.
Thanks for your help JasonWW. I will contact Haikelite and report here what they can offer.
I turned off blue led while off thinking it could be leaked from that part of circuit, but it is not helping. And leave it off all night didn’t help too. The very dim light actually is not stable like moon mode, they flicker a bit but never turn off.
The flickering is very odd indeed, it says that for some reason a cap somewhere must be discharging / recharging and this is causing the flicker.
It is possible a fake LDO could cause this I suppose, but pretty unlikely. I am not really sure what could cause this behavior to be honest. It is a very simple setup to avoid issues like this and as far as I know all the 100 lights I built are still working fine with no issues. So I know it is not the base design but sadly that is about all I know.
Thanks for insight of the potential rootcause.
One thing I don’t understand when I managed to get it to be completely off one time, it had tick tick sound like every 0.8s, I hold the light close to my ear to confirm, the sound didn’t want to stop at all. I wonder could it be something is either leaking as sound energy or light energy.
If you can pull the driver out and figure out where the sound is coming from it might be possible to figure out the issue.
I can’t make it completely off anymore, so far it happened one time only. I give it some try from time to time but not able to see it off completely anymore. I remember it was after i double clicked to turbo and then switched off, and it got completely off. Then i heard ticking sound, i hold mt03 near to my ear and confirmed it’s from the light.
I will try to pull the driver out after talking to Haikelite for solutions.
I measured standby current consumption as below:
MT03 12000LM 149uA
MT03 21000LM blue led off 360uA to 460uA
The LED leakage seems to be getting brighter. I have to take out batteries to be safe.
hmm, that is strange that it is leaking that bad.
It could be a sign of a failing FET, which is quite possible since they did not use the FET I speced out for this driver.
Those drain numbers are not crazy high in my opinion.
The 360uA to 460uA is a little bit high. It’s still no where near as high as the Thorfire S70S which has a 4,430uA drain (4.43 milliamps). Now that is pretty bad.
So all 3 xhp70.2 in your MT03 are glowing slightly and the drain is only 460uA? I would have guessed it would be much higher. Wierd.
Do you happen to have a hot air station or just a soldering iron?
This was mentioned in the Zanflare T1 thread as well. I’ve encountered this problem a couple of days ago with my T1, where the light was off, but it showed a very dim flickering output. Just an hour ago things got worse, and there is no off position anymore; the dim flickering light is now a constant CW on. It appears to be like a dam breach where in the beginning there is just little water escaping, but after many hours and days the hole gets bigger and bigger until the structure completely fails.
This seems to be the case with DENGOH’s MT03 as well.
Two completely different lights. I doubt they have the same cause. More than likely it’s just a coincidence.
Ya, beside current consumption, it looks quite bad now as all four quads are quite evenly lit. When I reported this issue, two out of the four quads were much dimmer. So I decided to take out the battery.
I wonder what’s the standby current of good stock MT03 TA. I think we should compare the number of same light to see how bad my MT03 TA is.
I have solder iron, no hot air unless I ask my friend for help.
I am thinking could it be some output capacitors gone bad. The ticking sound could be from capacitors, no?
My knowledge of electronics is limited. I was thinking of how a capacitor is often used to filter AC ripple from a DC voltage line. When these caps go bad they can often create an internal short and cause current to flow. I don’t know if any capacitors are used in that manner on TA’s driver. From what I understand, you have the positive voltage going through the led and down to one side of the FETs and nothing is supposed to go through it unless the MCU signals the FET to allow it. This is why TA and myself think that one of the FETs might be bad and leaking current through.
IIRC, the new driver is a 2 channel. If the 2 FETS are working properly no voltage should be going through the light. Of course, the MCU gets its power bypassing the FETs. It goes through an LDO to drop the voltage to the MCU. Maybe there is some kind of short in this part of the circuit? A counterfeit ATiny85 leaking current? IDK, I can only speculate. I don’t have one of these lights.
Thanks to you and Texas_Ace for analyzing. Those are valuable info.
I wonder is there published circuit diagrams for this MT03 TA? Or maybe some generic circuit diagram that I can try to understand how it works.
I did find this. I had forgotten about it. This is the MT09R driver which should be identical to the MT03 driver.
If you want, I can explain how the power goes through it. My knowledge is limited, though.
C3 and C4 look interesting.
Ha, these pictures were on a page back and only 2 months ago. I had completely forgot about them. Lol
Yes, it will help a lot if you can explain roughly how it works.
For example while measuring current consumption, it will draw about 7mA initially. And then it settled down to 360uA to 460uA. I wonder does the MCU in sleep mode after the initial 7mA.
Ya, I am suspecting the C3 and C4 too. What if one of them gone bad and becomes let’s say for example 500k ohm and will it causes very small current to flow through the LED?
Correct in that the MCU goes into a sleep mode after 7 seconds or so.
Correct that either C3 or C4 could do that.
I’ve made a big mess of the picture. Lol. The dark lines are the ground areas. The red lines are the positive areas.
U4 is the little FET.
U2 is the big FET.
U1 is the MCU.
The LDO is labeled.
The 5 orange circles are some of the potential leakage points.
Leakage from the MCU or LDO has to go through R5.
You might be able to unsolder the little FET, but the big one requires hot air. You can also try removing C3 and C4. You can remove R5 to cut all power beyond it which includes the LDO and MCU.
I’m not sure if the FETs can just be measured. I assume the positive and negative sides should be open.
You might also measure the caps resistance. I gave no idea what it should be. Super high resistance of some kind.
C1 or C2 might also be potential areas.
