Enerpower 18650 3.2V 1100mAh (Blue)
Official specifications:
Standard capacity: 1100mAh
Capacity range: 1050 ~ 1200mAh
Standard voltage: 3.2V
Internal resistance (1kHz): <=18mOhm
Maximum charge current: 5.5A
Discharge cut-off voltage: 2.5V
Fast discharge current: 11A
Maximum continuous discharge current: 33A
Pulse discharge current: 40A for 10seconds
Cycle characteristic: 500cycles (100% DOD), 1000cycles (80% DOD), 3000cycles (50% DOD)
Working temperature: Charge 0°C ~ 55°C, Discharge –20°C ~ 60°C
Storage temperature: 3 months: –20°C ~ 45°C
This is high current LiFePO4 batteries.
The batteries tracks nicely. The voltage is lower than normal LiIon, but it is stable during most of the discharge.
Conclusion
High current at fairly stable voltage, but not much capacity.
This is a good LiFePO4 high current cell.
Notes and links
Compare to 18650 and other batteries
